Hybrid - Prime Driver problems
Hello! I have a problem with hybrid nvidia
I am a new Linux user and have encountered a problem that I cannot start my Laptop via the rtx 3070 ti chip. That is, when the startup parameter in the BIOS is set to start from a discrete video core, Manjaro does not start. Also, when I set the parameters in envycontrol -s hybrid --rtd3 , nothing starts using the video card. I tried to install video-hybrid-intel-nvidia-470xx-prime, but when the system started, even Chrome did not start, but the system worked when running applications such as Firefox and the command line.
I used to use optimus-manager, and I used many ways to solve my problem, but it didn’t work, and + after I removed it and installed envycontrol, the whole system began to work better
> Blockquote
0000:01:00.0 (0300:10de:24e0) Display controller nVidia Corporation:
video-hybrid-intel-nvidia-prime            2023.03.23               false            PCI
video-hybrid-intel-nvidia-470xx-prime            2023.03.23               false            PCI
          video-nvidia            2024.05.03               false            PCI
    video-nvidia-470xx            2023.03.23               false            PCI
           video-linux            2024.05.06                true            PCI
> Blockquote
  Kernel: 6.9.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.9-x86_64
    root=UUID=65d2c478-f2c5-414d-9e3d-160df84ebcbb rw nvidia-drm.modeset=1
    quiet splash apparmor=1 security=apparmor
    resume=UUID=7719c2b5-bc6c-401f-b49b-e99c9bca8ced udev.log_priority=3
  Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro base: Arch Linux
  Type: Laptop System: LENOVO product: 82RF v: Legion 5 Pro 16IAH7H
    serial: <superuser required> Chassis: type: 10 v: Legion 5 Pro 16IAH7H
  Mobo: LENOVO model: LNVNB161216 v: SDK0T76461 WIN
    serial: <superuser required> part-nu: LENOVO_MT_82RF_BU_idea_FM_Legion 5 Pro
    16IAH7H uuid: <superuser required> UEFI: LENOVO v: J2CN54WW
    date: 07/10/2023
  ID-1: BAT0 charge: 69.0 Wh (97.0%) condition: 71.1/80.0 Wh (88.9%)
    power: 11.3 W volts: 17.4 min: 15.4 model: Sunwoda L21D4PC1 type: Li-poly
    serial: <filter> status: charging cycles: 687
  System RAM: total: 24 GiB available: 23.2 GiB used: 2.75 GiB (11.9%)
  Device-1: Controller0-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 16 GiB speed: 4800 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Crucial Technology part-no: CT16G48C40S5.M8A1
    serial: <filter>
  Device-2: Controller1-ChannelA-DIMM0 type: DDR5 detail: synchronous
    size: 8 GiB speed: 4800 MT/s volts: curr: 1 width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M425R1GB4BB0-CQKOD serial: <filter>
  Info: model: 12th Gen Intel Core i7-12700H bits: 64 type: MST AMCP
    arch: Alder Lake gen: core 12 level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 3
    microcode: 0x432
  Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
    cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
    L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 512 high: 1091 min/max: 400/4600:4700:3500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 992 6: 400 7: 1010 8: 400 9: 1091 10: 400 11: 400 12: 400 13: 400
    14: 400 15: 400 16: 400 17: 400 18: 766 19: 400 20: 400 bogomips: 107560
    de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt
    msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pclmulqdq pdcm pdpe1gb pebs
    pge pku pln pni popcnt pse pse36 pts rdpid rdrand rdseed rdtscp rep_good
    sdbg sep serialize sha_ni smap smep smx split_lock_detect ss ssbd sse sse2
    tsc_deadline_timer tsc_known_freq umip user_shstk vaes vme vmx vnmi
    vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave xsavec xsaveopt xsaves
    xtopology xtpr
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Lenovo
    driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
    built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2 bus-ID: 00:02.0
    chip-ID: 8086:46a6 class-ID: 0300
  Device-2: NVIDIA GA104M [Geforce RTX 3070 Ti Laptop GPU] vendor: Lenovo
    driver: nvidia v: 550.78 alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx
    process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
    lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:24e0 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
    compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :1 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-size: <missing: xdpyinfo>
  Monitor-1: eDP-1 model: BOE Display 0x0a1f built: 2021 res: 2560x1600
    hz: 165 dpi: 189 gamma: 1.2 size: 344x215mm (13.54x8.46") diag: 406mm (16")
    ratio: 16:10 modes: 2560x1600
    drv: nvidia device: 1 drv: iris device: 2 drv: swrast surfaceless:
    drv: nvidia x11: drv: iris inactive: gbm,wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.6-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a6 memory: 22.66 GiB unified: yes
  Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs,snd_sof_pci_intel_tgl
    bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
  API: ALSA v: k6.9.0-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  IP v4: <filter> type: dynamic scope: global broadcast: <filter>
    vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: 3000 bus-ID: 34:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp52s0 state: down mac: <filter>
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:6 chip-ID: 8087:0033
    class-ID: e001
  Local Storage: total: 953.87 GiB used: 73.75 GiB (7.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: MTFDKBA1T0TFH
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1006P7LN temp: 33.9 C
    scheme: GPT
  ID-1: / raw-size: 928.05 GiB size: 912.41 GiB (98.31%) used: 73.74 GiB (8.1%)
    fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
    uuid: 65d2c478-f2c5-414d-9e3d-160df84ebcbb
    used: 4.4 MiB (1.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 3584-1CB3
  ID-1: swap-1 type: partition size: 25.52 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
    uuid: 7719c2b5-bc6c-401f-b49b-e99c9bca8ced
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-2: 2-0:1 info: super-speed hub ports: 1 rev: 3.1
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-1:2 info: Compx AJAZZ 2.4G type: keyboard,HID,mouse
    lanes: 1 mode: 1.1 power: 98mA chip-ID: 3554:f564 class-ID: 0301
  Hub-4: 3-2:3 info: Genesys Logic Hub ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 05e3:0610
  Device-1: 3-5:4 info: Integrated Express ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c102 class-ID: 0301
  Device-2: 3-9:5 info: Integrated Express ITE Device(8295)
    type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
    chip-ID: 048d:c975 class-ID: 0300
  Device-3: 3-10:6 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-3:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
  System Temperatures: cpu: 34.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 416 Power: uptime: 5m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 9.25 GiB services: gsd-power,
    tool: systemctl
  Packages: pm: pacman pkgs: 1323 libs: 396 tools: gnome-software,pamac,yay
    pm: flatpak pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
    running-in: gnome-terminal inxi: 3.3.34
> Blockquote
Blockquote
mhwd -li                                            ✔
> Installed PCI configs:
Hello,
Welcome to Manjaro
Did you mean to attach something?
What is the problem?
This appears to list all available mhwd driver profiles, which is not very helpful.
Most basic things can be found here:
Also attached here is a guide with tips on how to format code and more.
:point_up:
Yeah,Sorry for the lack of information. I am a new Linux user and have encountered a problem that I cannot start my Laptop via the rtx 3070 ti chip. That is, when the startup parameter in the BIOS is set to start from a discrete video core, Manjaro does not start. Also, when I set the parameters in envycontrol -s hybrid --rtd3, nothing starts using the video card. I tried to install video-hybrid-intel-nvidia-470xx-prime, but when the system started, even Chrome did not start, but the system worked when running applications such as Firefox and the command line.
Did you maybe do some hacky things to your DM because of optimus-manager?
(some are required to use it … one of the many reasons it should be avoided)
Another guess thats commonly attached to optimus-manager … did you replace gdm ?
Maybe with something like gdm-prime ?
No, I think not, but I’m not sure. I have 3 folders with gdm-prime, but I think my system is using regular gdm. Also I’m not sure about the DM changes, I’ve done so many things to fix it that I don’t know anymore. Do you know any commands to check this?
pacman -Qs gdm
Heck, might as well check all your foreign packages while we are at it
pacman -Qmq
local/gdm 46.0-1 (gnome)
    Display manager and login screen
local/libgdm 46.0-1
    Display manager and login screen - support library
local/manjaro-gdm-branding 20221120-1
    Manjaro GDM branding
apple-music-bin
google-chrome
python-manjaro-sdk
web-installer-url-handler
