I have a freshly made and validated manjaro-architect iso installed on a flash drive
When I boot from usb, I get all the regular messages on the boot screen that shows all the drives being mounted and processes being initialized.
when it gets to “Started Network Manager Script Dispatcher Service”, it just hangs.
I left it there for 3 hours and it didn’t move.
windows 10
intel core i5
x64
Hi and welcome to the forum
Maybe you perceive it as a hang, are you able to get at a different terminal screen using:
CTRL+ALT+Fn where Fn=F1->F12
If you can then it is an issue with your graphics driver or some other problem related to starting your window manager.
Also please see: (After you boot from the Live media iso)
