this is the bit that i don’t understand as i do not have a 11-huion-tablet.conf in the indicated directory.
i have followed all instructions and even installed kcm-wacomtablet, all that’s left now is to configure the buttons on my tablet. plz help
If you do not have the /etc/x11/xorg.conf.d/11-huion-tablet.conf file, then you create it. You ca do it from terminal with this command:
sudo touch /etc/x11/xorg.conf.d/11-huion-tablet.conf
Then you can open it with kate:
kate /etc/x11/xorg.conf.d/11-huion-tablet.conf
and add the following lines to it:
# Huion tablets
Section "InputClass"
Identifier "Huion class"
MatchProduct "TABLET"
MatchIsTablet "on"
MatchDevicePath "/dev/input/event*"
Driver "wacom"
EndSection
Identifier "Huion buttons"
MatchIsKeyboard "on"
Driver "evdev"
EndSection
Identifier "Huion scroll"
MatchIsPointer "off"
MatchIsKeyboard "off"
MatchIsTouchpad "off"
MatchIsTablet "off"
MatchIsTouchscreen "off"
Driver "evdev"
EndSection
When you save the file you will be asked for your password. Once is saved, reboot the system and test again for available settings.
