Hi, I use a Huawei laptop Matebook D 2018 with AMD Ryzen.
Huawei on Windows has a battery protection mode and this tool is present on linux firmware too. I read that Huawei WMI version 3.3 is merged on kernel >= 5.5 so it wil be included but seems not working for me
Kernel: 5.17.6-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.17-x86_64
root=UUID=ee6cbac7-ba22-4004-a228-4a0a18e05d5a rw quiet apparmor=1
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.3 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HUAWEI product: KPL-W0X v: M1D
serial: <superuser required>
Mobo: HUAWEI model: KPL-W0X-PCB v: M1D serial: <superuser required>
UEFI: HUAWEI v: 1.23 date: 09/28/2021
ID-1: BAT1 charge: 54.9 Wh (100.0%) condition: 54.9/56.3 Wh (97.5%)
volts: 8.1 min: 7.6 model: DYNAPACK HB4593R1ECW type: Li-ion
serial: <filter> status: full cycles: 103
Info: model: AMD Ryzen 5 2500U with Radeon Vega Mobile Gfx bits: 64
type: MT MCP arch: Zen family: 0x17 (23) model-id: 0x11 (17) stepping: 0
microcode: 0x8101007
L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1407 high: 1527 min/max: 1600/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1474 2: 1394
3: 1367 4: 1527 5: 1367 6: 1368 7: 1385 8: 1380 bogomips: 31949
Type: spectre_v2
mitigation: Retpolines, IBPB: conditional, STIBP: disabled, RSB filling
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Huawei driver: amdgpu v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 02:00.0
chip-ID: 1002:15dd class-ID: 0300
Device-2: Quanta hm1091_techfront type: USB driver: uvcvideo bus-ID: 3-1:2
chip-ID: 0408:1020 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x14d4 built: 2016
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 13.0.1 DRM 3.44
5.17.6-1-MANJARO)
v: 4.6 Mesa 22.0.3 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Huawei
bus-ID: 02:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Huawei
driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x,snd_pci_acp5x,snd_sof_amd_renoir pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 02:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: AMD Family 17h/19h HD Audio vendor: Huawei driver: snd_hda_intel
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 02:00.6
chip-ID: 1022:15e3 class-ID: 0403
Sound Server-1: ALSA v: k5.17.6-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-2:2 chip-ID: 8087:0a2b class-ID: e001
Local Storage: total: 238.47 GiB used: 48.33 GiB (20.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: LITE-ON model: CV8-8E256
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 402 scheme: GPT
ID-1: / raw-size: 15.5 GiB size: 15.15 GiB (97.77%) used: 10.04 GiB (66.2%)
fs: ext4 dev: /dev/sda5 maj-min: 8:5
used: 38.2 MiB (39.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: N/A mobo: N/A gpu: amdgpu temp: 54.0 C
Processes: 247 Uptime: 32m wakeups: 1 Memory: 6.74 GiB used: 1.9 GiB (28.2%)
Init: systemd v: 250 tool: systemctl Compilers: gcc: 11.2.0 clang: 13.0.1
Packages: pacman: 1197 lib: 327 flatpak: 0 Shell: Zsh v: 5.8.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.16
