Problems with GTA San Andreas running with DXVK - Wine
I’m trying to run GTA San Andreas on Wine with DXVK (I have Vulkan 1.3.276 and Mesa drivers 1:23) but when I want to run it I obtan this in the command prompt
MESA-INTEL: warning: Bay Trail Vulkan support is incomplete
0024:err:winediag:ntlm_check_version ntlm_auth was not found. Make sure that ntlm_auth >= 3.0.25 is in your path. Usually, you can find it in the winbind package of your distribution.
0024:err:ntlm:ntlm_LsaApInitializePackage no NTLM support, expect problems
0024:fixme:ntdll:NtQuerySystemInformation info_class SYSTEM_PERFORMANCE_INFORMATION
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 78A4F080, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 75D74C80, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 789E1490, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 78976918, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 78936898, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 788E3240, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 787ACF40, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 7875D3E0, 43) stub
0024:fixme:ntdll:EtwEventSetInformation (deadbeef, 2, 75A8AD88, 43) stub
0024:err:winediag:wined3d_dll_init Using the Vulkan renderer.
0024:fixme:d3d:adapter_vk_init_driver_info Failed to retrieve GPU description for device "Intel(R) HD Graphics (BYT)" 8086:0f31.
0128:fixme:avrt:AvSetMmThreadCharacteristicsW (L"Audio",0456FF30): stub
info:  Game: gta_sa.exe
info:  DXVK: v2.3
info:  Vulkan: Found vkGetInstanceProcAddr in winevulkan.dll @ 0x73b73830
info:  Built-in extension providers:
info:    Win32 WSI
info:    OpenVR
info:    OpenXR
info:  OpenVR: could not open registry key, status 2
info:  OpenVR: Failed to locate module
info:  Enabled instance extensions:
info:    VK_EXT_surface_maintenance1
info:    VK_KHR_get_surface_capabilities2
info:    VK_KHR_surface
info:    VK_KHR_win32_surface
warn:  Skipping Vulkan 1.2 adapter: Intel(R) HD Graphics (BYT)
warn:  DXVK: No adapters found. Please check your device filter settings and Vulkan setup. A Vulkan 1.3 capable driver is required.
info:  Process set as DPI aware
It’s strange because other games that I have that use Vulkan (PPSSPP and Duckstation) works very fine. How can I solve this?
My PC specs:
Architecture:            x86_64
  CPU op-mode(s):        32-bit, 64-bit
  Address sizes:         36 bits physical, 48 bits virtual
  Byte Order:            Little Endian
CPU(s):                  2
  On-line CPU(s) list:   0,1
Vendor ID:               GenuineIntel
  Model name:            Intel(R) Celeron(R) CPU  N2808  @ 1.58GHz
    CPU family:          6
    Model:               55
    Thread(s) per core:  1
    Core(s) per socket:  2
    Socket(s):           1
    Stepping:            8
    CPU(s) scaling MHz:  100%
    CPU max MHz:         2249,1001
    CPU min MHz:         499,8000
    BogoMIPS:            3167,61
    Flags:               fpu vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe sysca
                         ll nx rdtscp lm constant_tsc arch_perfmon pebs bts rep_good nopl xtopology tsc_reliable nonstop_tsc cpuid aperfmperf tsc_know
                         n_freq pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm sse4_1 sse4_2 movbe popcnt tsc_deadline_timer rdr
                         and lahf_lm 3dnowprefetch epb pti ibrs ibpb stibp tpr_shadow flexpriority ept vpid tsc_adjust smep erms dtherm ida arat vnmi
                         md_clear
Virtualization features:
  Virtualization:        VT-x
Caches (sum of all):
  L1d:                   48 KiB (2 instances)
  L1i:                   64 KiB (2 instances)
  L2:                    1 MiB (1 instance)
NUMA:
  NUMA node(s):          1
  NUMA node0 CPU(s):     0,1
  Gather data sampling:  Not affected
  Itlb multihit:         Not affected
  L1tf:                  Not affected
  Mds:                   Mitigation; Clear CPU buffers; SMT disabled
  Meltdown:              Mitigation; PTI
  Mmio stale data:       Unknown: No mitigations
  Retbleed:              Not affected
  Spec rstack overflow:  Not affected
  Spec store bypass:     Not affected
  Spectre v1:            Mitigation; usercopy/swapgs barriers and __user pointer sanitization
  Spectre v2:            Mitigation; Retpolines, IBPB conditional, IBRS_FW, STIBP disabled, RSB filling, PBRSB-eIBRS Not affected
  Srbds:                 Not affected
  Tsx async abort:       Not affected
Thanks.
Check if you have the package libwbclient installed. If you do there may be another problem.
This may indicate there may be a feature from Vulkan which is incomplete in MESA implementation or is not supported by your specific graphic card.
Have you looked for answers in WineHQ?
Sometimes good answers can also be found in Protondb.
https://www.protondb.com/search?q=gta%20san%20andreas
DXVK doesn’t agree.
Presumably 1.2 is fine for PPSSPP and Duckstation.
I’m sure that I have Vulkan 1.3
[felipe@suma1025 ~]$ vulkaninfo
VULKANINFO
Vulkan Instance Version: 1.3.276
Instance Extensions: count = 23
	VK_EXT_acquire_drm_display             : extension revision 1
	VK_EXT_acquire_xlib_display            : extension revision 1
	VK_EXT_debug_report                    : extension revision 10
	VK_EXT_debug_utils                     : extension revision 2
	VK_EXT_direct_mode_display             : extension revision 1
	VK_EXT_display_surface_counter         : extension revision 1
	VK_EXT_surface_maintenance1            : extension revision 1
	VK_EXT_swapchain_colorspace            : extension revision 4
	VK_KHR_device_group_creation           : extension revision 1
	VK_KHR_display                         : extension revision 23
	VK_KHR_external_fence_capabilities     : extension revision 1
	VK_KHR_external_memory_capabilities    : extension revision 1
	VK_KHR_external_semaphore_capabilities : extension revision 1
	VK_KHR_get_display_properties2         : extension revision 1
	VK_KHR_get_physical_device_properties2 : extension revision 2
	VK_KHR_get_surface_capabilities2       : extension revision 1
	VK_KHR_portability_enumeration         : extension revision 1
	VK_KHR_surface                         : extension revision 25
	VK_KHR_surface_protected_capabilities  : extension revision 1
	VK_KHR_wayland_surface                 : extension revision 6
	VK_KHR_xcb_surface                     : extension revision 6
	VK_KHR_xlib_surface                    : extension revision 6
	VK_LUNARG_direct_driver_loading        : extension revision 1
Layers:
Presentable Surfaces:
GPU id : 0 (Intel(R) HD Graphics (BYT)):
	Surface types: count = 2
		VK_KHR_xcb_surface
		VK_KHR_xlib_surface
	Formats: count = 2
		SurfaceFormat[0]:
			format = FORMAT_B8G8R8A8_SRGB
			colorSpace = COLOR_SPACE_SRGB_NONLINEAR_KHR
		SurfaceFormat[1]:
			format = FORMAT_B8G8R8A8_UNORM
	Present Modes: count = 4
		PRESENT_MODE_IMMEDIATE_KHR
		PRESENT_MODE_MAILBOX_KHR
		PRESENT_MODE_FIFO_KHR
		PRESENT_MODE_FIFO_RELAXED_KHR
	VkSurfaceCapabilitiesKHR:
		minImageCount = 3
		maxImageCount = 0
		currentExtent:
			width  = 256
			height = 256
		minImageExtent:
			width  = 256
			height = 256
		maxImageExtent:
			width  = 256
			height = 256
		maxImageArrayLayers = 1
		supportedTransforms: count = 1
			SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		currentTransform = SURFACE_TRANSFORM_IDENTITY_BIT_KHR
		supportedCompositeAlpha: count = 2
			COMPOSITE_ALPHA_OPAQUE_BIT_KHR
			COMPOSITE_ALPHA_INHERIT_BIT_KHR
		supportedUsageFlags: count = 6
			IMAGE_USAGE_TRANSFER_SRC_BIT
			IMAGE_USAGE_TRANSFER_DST_BIT
			IMAGE_USAGE_SAMPLED_BIT
			IMAGE_USAGE_STORAGE_BIT
			IMAGE_USAGE_COLOR_ATTACHMENT_BIT
			IMAGE_USAGE_INPUT_ATTACHMENT_BIT
	VkSurfaceProtectedCapabilitiesKHR:
		supportsProtected = false
	VK_EXT_surface_maintenance_1:
		PRESENT_MODE_IMMEDIATE_KHR:
			VkSurfacePresentScalingCapabilitiesEXT:
				supportedPresentScaling:
					None
				supportedPresentGravityX:
					None
				supportedPresentGravityY:
					None
				minScaledImageExtent:
					width  = 256
					height = 256
				maxScaledImageExtent:
					width  = 256
					height = 256
			VkSurfacePresentModeCompatibilityEXT:
				presentModeCount                = 1
				pPresentModes: count = 1
		PRESENT_MODE_MAILBOX_KHR:
					None
					None
					None
					width  = 256
					height = 256
					width  = 256
					height = 256
		PRESENT_MODE_FIFO_KHR:
					None
					None
					None
					width  = 256
					height = 256
					width  = 256
					height = 256
		PRESENT_MODE_FIFO_RELAXED_KHR:
					None
					None
					None
					width  = 256
					height = 256
					width  = 256
					height = 256
Device Properties and Extensions:
GPU0:
VkPhysicalDeviceProperties:
	apiVersion        = 1.2.267 (4202763)
	driverVersion     = 23.3.5 (96481285)
	vendorID          = 0x8086
	deviceID          = 0x0f31
	deviceType        = PHYSICAL_DEVICE_TYPE_INTEGRATED_GPU
	deviceName        = Intel(R) HD Graphics (BYT)
	pipelineCacheUUID = 4a4bb47d-d9ca-1ce3-17ba-3027d19a429b
VkPhysicalDeviceLimits:
	maxImageDimension1D                             = 16384
	maxImageDimension2D                             = 8192
	maxImageDimension3D                             = 2048
	maxImageDimensionCube                           = 16384
	maxImageArrayLayers                             = 2048
	maxTexelBufferElements                          = 134217728
	maxUniformBufferRange                           = 134217728
	maxStorageBufferRange                           = 1073741824
	maxPushConstantsSize                            = 128
	maxMemoryAllocationCount                        = 4294967295
	maxSamplerAllocationCount                       = 65536
	bufferImageGranularity                          = 0x00000001
	sparseAddressSpaceSize                          = 0x00000000
	maxBoundDescriptorSets                          = 32
	maxPerStageDescriptorSamplers                   = 16
	maxPerStageDescriptorUniformBuffers             = 64
	maxPerStageDescriptorStorageBuffers             = 64
	maxPerStageDescriptorSampledImages              = 128
	maxPerStageDescriptorStorageImages              = 64
	maxPerStageDescriptorInputAttachments           = 64
	maxPerStageResources                            = 231
	maxDescriptorSetSamplers                        = 96
	maxDescriptorSetUniformBuffers                  = 384
	maxDescriptorSetUniformBuffersDynamic           = 8
	maxDescriptorSetStorageBuffers                  = 384
	maxDescriptorSetStorageBuffersDynamic           = 8
	maxDescriptorSetSampledImages                   = 768
	maxDescriptorSetStorageImages                   = 384
	maxDescriptorSetInputAttachments                = 256
	maxVertexInputAttributes                        = 29
	maxVertexInputBindings                          = 31
	maxVertexInputAttributeOffset                   = 2047
	maxVertexInputBindingStride                     = 2048
	maxVertexOutputComponents                       = 128
	maxTessellationGenerationLevel                  = 64
	maxTessellationPatchSize                        = 32
	maxTessellationControlPerVertexInputComponents  = 128
	maxTessellationControlPerVertexOutputComponents = 128
	maxTessellationControlPerPatchOutputComponents  = 128
	maxTessellationControlTotalOutputComponents     = 2048
	maxTessellationEvaluationInputComponents        = 128
	maxTessellationEvaluationOutputComponents       = 128
	maxGeometryShaderInvocations                    = 32
	maxGeometryInputComponents                      = 64
	maxGeometryOutputComponents                     = 128
	maxGeometryOutputVertices                       = 256
	maxGeometryTotalOutputComponents                = 1024
	maxFragmentInputComponents                      = 116
	maxFragmentOutputAttachments                    = 8
	maxFragmentDualSrcAttachments                   = 1
	maxFragmentCombinedOutputResources              = 136
	maxComputeSharedMemorySize                      = 65536
	maxComputeWorkGroupCount: count = 3
		65535
		65535
		65535
	maxComputeWorkGroupInvocations                  = 1024
	maxComputeWorkGroupSize: count = 3
		1024
		1024
		1024
	subPixelPrecisionBits                           = 8
	subTexelPrecisionBits                           = 8
	mipmapPrecisionBits                             = 8
	maxDrawIndexedIndexValue                        = 4294967295
	maxDrawIndirectCount                            = 4294967295
	maxSamplerLodBias                               = 16
	maxSamplerAnisotropy                            = 16
	maxViewports                                    = 16
	maxViewportDimensions: count = 2
		16384
		16384
	viewportBoundsRange: count = 2
		-32768
		32767
	viewportSubPixelBits                            = 13
	minMemoryMapAlignment                           = 4096
	minTexelBufferOffsetAlignment                   = 0x00000010
	minUniformBufferOffsetAlignment                 = 0x00000040
	minStorageBufferOffsetAlignment                 = 0x00000004
	minTexelOffset                                  = -8
	maxTexelOffset                                  = 7
	minTexelGatherOffset                            = -32
	maxTexelGatherOffset                            = 31
	minInterpolationOffset                          = -0.5
	maxInterpolationOffset                          = 0.4375
	subPixelInterpolationOffsetBits                 = 4
	maxFramebufferWidth                             = 16384
	maxFramebufferHeight                            = 16384
	maxFramebufferLayers                            = 2048
	framebufferColorSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferDepthSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferStencilSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	framebufferNoAttachmentsSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxColorAttachments                             = 8
	sampledImageColorSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageIntegerSampleCounts: count = 1
		SAMPLE_COUNT_1_BIT
	sampledImageDepthSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	sampledImageStencilSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	storageImageSampleCounts: count = 1
		SAMPLE_COUNT_1_BIT
	maxSampleMaskWords                              = 1
	timestampComputeAndGraphics                     = true
	timestampPeriod                                 = 80
	maxClipDistances                                = 8
	maxCullDistances                                = 8
	maxCombinedClipAndCullDistances                 = 8
	discreteQueuePriorities                         = 2
	pointSizeRange: count = 2
		0.125
		255.875
	lineWidthRange: count = 2
		0
		7.99219
	pointSizeGranularity                            = 0.125
	lineWidthGranularity                            = 0.0078125
	strictLines                                     = false
	standardSampleLocations                         = true
	optimalBufferCopyOffsetAlignment                = 0x00000080
	optimalBufferCopyRowPitchAlignment              = 0x00000080
	nonCoherentAtomSize                             = 0x00000040
VkPhysicalDeviceSparseProperties:
	residencyStandard2DBlockShape            = false
	residencyStandard2DMultisampleBlockShape = false
	residencyStandard3DBlockShape            = false
	residencyAlignedMipSize                  = false
	residencyNonResidentStrict               = false
VkPhysicalDeviceDepthStencilResolveProperties:
	supportedDepthResolveModes: count = 4
		RESOLVE_MODE_SAMPLE_ZERO_BIT
		RESOLVE_MODE_AVERAGE_BIT
		RESOLVE_MODE_MIN_BIT
		RESOLVE_MODE_MAX_BIT
	supportedStencilResolveModes: count = 1
	independentResolveNone = true
	independentResolve     = true
VkPhysicalDeviceDescriptorIndexingProperties:
	maxUpdateAfterBindDescriptorsInAllPools              = 1048576
	shaderUniformBufferArrayNonUniformIndexingNative     = false
	shaderSampledImageArrayNonUniformIndexingNative      = false
	shaderStorageBufferArrayNonUniformIndexingNative     = true
	shaderStorageImageArrayNonUniformIndexingNative      = false
	shaderInputAttachmentArrayNonUniformIndexingNative   = false
	robustBufferAccessUpdateAfterBind                    = true
	quadDivergentImplicitLod                             = false
	maxPerStageDescriptorUpdateAfterBindSamplers         = 1048576
	maxPerStageDescriptorUpdateAfterBindUniformBuffers   = 64
	maxPerStageDescriptorUpdateAfterBindStorageBuffers   = 4294967295
	maxPerStageDescriptorUpdateAfterBindSampledImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindStorageImages    = 1048576
	maxPerStageDescriptorUpdateAfterBindInputAttachments = 64
	maxPerStageUpdateAfterBindResources                  = 4294967295
	maxDescriptorSetUpdateAfterBindSamplers              = 1048576
	maxDescriptorSetUpdateAfterBindUniformBuffers        = 384
	maxDescriptorSetUpdateAfterBindUniformBuffersDynamic = 8
	maxDescriptorSetUpdateAfterBindStorageBuffers        = 4294967295
	maxDescriptorSetUpdateAfterBindStorageBuffersDynamic = 8
	maxDescriptorSetUpdateAfterBindSampledImages         = 1048576
	maxDescriptorSetUpdateAfterBindStorageImages         = 1048576
	maxDescriptorSetUpdateAfterBindInputAttachments      = 256
VkPhysicalDeviceDriverProperties:
	driverID        = DRIVER_ID_INTEL_OPEN_SOURCE_MESA
	driverName      = Intel open-source Mesa driver
	driverInfo      = Mesa 23.3.5-manjaro1.1
	conformanceVersion:
		major    = 0
		minor    = 0
		subminor = 0
		patch    = 0
VkPhysicalDeviceDrmPropertiesEXT:
	hasPrimary   = true
	hasRender    = true
	primaryMajor = 226
	primaryMinor = 1
	renderMajor  = 226
	renderMinor  = 128
VkPhysicalDeviceExternalMemoryHostPropertiesEXT:
	minImportedHostPointerAlignment = 0x00001000
VkPhysicalDeviceFloatControlsProperties:
	denormBehaviorIndependence            = SHADER_FLOAT_CONTROLS_INDEPENDENCE_ALL
	roundingModeIndependence              = SHADER_FLOAT_CONTROLS_INDEPENDENCE_NONE
	shaderSignedZeroInfNanPreserveFloat16 = true
	shaderSignedZeroInfNanPreserveFloat32 = true
	shaderSignedZeroInfNanPreserveFloat64 = true
	shaderDenormPreserveFloat16           = false
	shaderDenormPreserveFloat32           = false
	shaderDenormPreserveFloat64           = true
	shaderDenormFlushToZeroFloat16        = false
	shaderDenormFlushToZeroFloat32        = true
	shaderDenormFlushToZeroFloat64        = true
	shaderRoundingModeRTEFloat16          = true
	shaderRoundingModeRTEFloat32          = true
	shaderRoundingModeRTEFloat64          = true
	shaderRoundingModeRTZFloat16          = true
	shaderRoundingModeRTZFloat32          = true
	shaderRoundingModeRTZFloat64          = true
VkPhysicalDeviceIDProperties:
	deviceUUID      = 8680310f-0e00-0000-0002-000000000000
	driverUUID      = e7372a9e-137b-d676-fbb0-505ee6704543
	deviceNodeMask  = 0
	deviceLUIDValid = false
VkPhysicalDeviceInlineUniformBlockPropertiesEXT:
	maxInlineUniformBlockSize                               = 4096
	maxPerStageDescriptorInlineUniformBlocks                = 32
	maxPerStageDescriptorUpdateAfterBindInlineUniformBlocks = 32
	maxDescriptorSetInlineUniformBlocks                     = 32
	maxDescriptorSetUpdateAfterBindInlineUniformBlocks      = 32
VkPhysicalDeviceLineRasterizationPropertiesEXT:
	lineSubPixelPrecisionBits = 4
VkPhysicalDeviceMaintenance3Properties:
	maxPerSetDescriptors    = 1024
	maxMemoryAllocationSize = 0x80000000
VkPhysicalDeviceMaintenance4PropertiesKHR:
	maxBufferSize = 0x40000000
VkPhysicalDeviceMultiDrawPropertiesEXT:
	maxMultiDrawCount = 2048
VkPhysicalDeviceMultiviewProperties:
	maxMultiviewViewCount     = 16
	maxMultiviewInstanceIndex = 268435455
VkPhysicalDevicePCIBusInfoPropertiesEXT:
	pciDomain   = 0
	pciBus      = 0
	pciDevice   = 2
	pciFunction = 0
VkPhysicalDevicePointClippingProperties:
	pointClippingBehavior = POINT_CLIPPING_BEHAVIOR_USER_CLIP_PLANES_ONLY
VkPhysicalDeviceProtectedMemoryProperties:
	protectedNoFault = false
VkPhysicalDeviceProvokingVertexPropertiesEXT:
	provokingVertexModePerPipeline                       = true
	transformFeedbackPreservesTriangleFanProvokingVertex = false
VkPhysicalDevicePushDescriptorPropertiesKHR:
	maxPushDescriptors = 32
VkPhysicalDeviceRobustness2PropertiesEXT:
	robustStorageBufferAccessSizeAlignment = 0x00000004
	robustUniformBufferAccessSizeAlignment = 0x00000040
VkPhysicalDeviceSampleLocationsPropertiesEXT:
	sampleLocationSampleCounts: count = 3
		SAMPLE_COUNT_1_BIT
		SAMPLE_COUNT_4_BIT
		SAMPLE_COUNT_8_BIT
	maxSampleLocationGridSize:
		width  = 1
		height = 1
	sampleLocationCoordinateRange: count = 2
		0
		0.9375
	sampleLocationSubPixelBits       = 4
	variableSampleLocations          = true
VkPhysicalDeviceSamplerFilterMinmaxProperties:
	filterMinmaxSingleComponentFormats = false
	filterMinmaxImageComponentMapping  = false
VkPhysicalDeviceShaderIntegerDotProductPropertiesKHR:
	integerDotProduct8BitUnsignedAccelerated                                      = false
	integerDotProduct8BitSignedAccelerated                                        = false
	integerDotProduct8BitMixedSignednessAccelerated                               = false
	integerDotProduct4x8BitPackedUnsignedAccelerated                              = false
	integerDotProduct4x8BitPackedSignedAccelerated                                = false
	integerDotProduct4x8BitPackedMixedSignednessAccelerated                       = false
	integerDotProduct16BitUnsignedAccelerated                                     = false
	integerDotProduct16BitSignedAccelerated                                       = false
	integerDotProduct16BitMixedSignednessAccelerated                              = false
	integerDotProduct32BitUnsignedAccelerated                                     = false
	integerDotProduct32BitSignedAccelerated                                       = false
	integerDotProduct32BitMixedSignednessAccelerated                              = false
	integerDotProduct64BitUnsignedAccelerated                                     = false
	integerDotProduct64BitSignedAccelerated                                       = false
	integerDotProduct64BitMixedSignednessAccelerated                              = false
	integerDotProductAccumulatingSaturating8BitUnsignedAccelerated                = false
	integerDotProductAccumulatingSaturating8BitSignedAccelerated                  = false
	integerDotProductAccumulatingSaturating8BitMixedSignednessAccelerated         = false
	integerDotProductAccumulatingSaturating4x8BitPackedUnsignedAccelerated        = false
	integerDotProductAccumulatingSaturating4x8BitPackedSignedAccelerated          = false
	integerDotProductAccumulatingSaturating4x8BitPackedMixedSignednessAccelerated = false
	integerDotProductAccumulatingSaturating16BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating16BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating16BitMixedSignednessAccelerated        = false
	integerDotProductAccumulatingSaturating32BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating32BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating32BitMixedSignednessAccelerated        = false
	integerDotProductAccumulatingSaturating64BitUnsignedAccelerated               = false
	integerDotProductAccumulatingSaturating64BitSignedAccelerated                 = false
	integerDotProductAccumulatingSaturating64BitMixedSignednessAccelerated        = false
VkPhysicalDeviceShaderModuleIdentifierPropertiesEXT:
	shaderModuleIdentifierAlgorithmUUID     = 4d455341-2d42-4c41-4b45-330000000000
VkPhysicalDeviceSubgroupProperties:
	subgroupSize              = 32
	supportedStages: count = 2
		SHADER_STAGE_FRAGMENT_BIT
		SHADER_STAGE_COMPUTE_BIT
	supportedOperations: count = 6
		SUBGROUP_FEATURE_BASIC_BIT
		SUBGROUP_FEATURE_VOTE_BIT
		SUBGROUP_FEATURE_BALLOT_BIT
		SUBGROUP_FEATURE_SHUFFLE_BIT
		SUBGROUP_FEATURE_SHUFFLE_RELATIVE_BIT
		SUBGROUP_FEATURE_QUAD_BIT
	quadOperationsInAllStages = false
VkPhysicalDeviceSubgroupSizeControlPropertiesEXT:
	minSubgroupSize              = 8
	maxSubgroupSize              = 32
	maxComputeWorkgroupSubgroups = 32
	requiredSubgroupSizeStages: count = 1
VkPhysicalDeviceTexelBufferAlignmentPropertiesEXT:
	storageTexelBufferOffsetAlignmentBytes       = 0x00000010
	storageTexelBufferOffsetSingleTexelAlignment = true
	uniformTexelBufferOffsetAlignmentBytes       = 0x00000001
	uniformTexelBufferOffsetSingleTexelAlignment = true
VkPhysicalDeviceTimelineSemaphoreProperties:
	maxTimelineSemaphoreValueDifference = 18446744073709551615
VkPhysicalDeviceTransformFeedbackPropertiesEXT:
	maxTransformFeedbackStreams                = 4
	maxTransformFeedbackBuffers                = 4
	maxTransformFeedbackBufferSize             = 0x100000000
	maxTransformFeedbackStreamDataSize         = 512
	maxTransformFeedbackBufferDataSize         = 512
	maxTransformFeedbackBufferDataStride       = 2048
	transformFeedbackQueries                   = true
	transformFeedbackStreamsLinesTriangles     = false
	transformFeedbackRasterizationStreamSelect = false
	transformFeedbackDraw                      = false
VkPhysicalDeviceVertexAttributeDivisorPropertiesEXT:
	maxVertexAttribDivisor = 268435455
VkPhysicalDeviceVulkan11Properties:
	deviceNodeMask                    = 0
	subgroupSize                      = 32
	subgroupSupportedStages: count = 2
	subgroupSupportedOperations: count = 6
	subgroupQuadOperationsInAllStages = false
VkPhysicalDeviceVulkan12Properties:
	conformanceVersion:
		major    = 0
		minor    = 0
		subminor = 0
		patch    = 0
	framebufferIntegerColorSampleCounts: count = 1
		SAMPLE_COUNT_1_BIT
VkPhysicalDeviceHostImageCopyPropertiesEXT:
	copySrcLayoutCount                  = 0
	pCopySrcLayouts:
	copyDstLayoutCount                  = 0
	pCopyDstLayouts:
	optimalTilingLayoutUUID             = 00000000-0000-0000-0000-000000000000
	identicalMemoryTypeRequirements     = false
Device Extensions: count = 103
	VK_EXT_4444_formats                         : extension revision 1
	VK_EXT_calibrated_timestamps                : extension revision 2
	VK_EXT_color_write_enable                   : extension revision 1
	VK_EXT_depth_clamp_zero_one                 : extension revision 1
	VK_EXT_depth_clip_control                   : extension revision 1
	VK_EXT_depth_clip_enable                    : extension revision 1
	VK_EXT_display_control                      : extension revision 1
	VK_EXT_extended_dynamic_state               : extension revision 1
	VK_EXT_extended_dynamic_state2              : extension revision 1
	VK_EXT_external_memory_dma_buf              : extension revision 1
	VK_EXT_external_memory_host                 : extension revision 1
	VK_EXT_host_query_reset                     : extension revision 1
	VK_EXT_image_2d_view_of_3d                  : extension revision 1
	VK_EXT_image_drm_format_modifier            : extension revision 2
	VK_EXT_image_robustness                     : extension revision 1
	VK_EXT_image_view_min_lod                   : extension revision 1
	VK_EXT_index_type_uint8                     : extension revision 1
	VK_EXT_inline_uniform_block                 : extension revision 1
	VK_EXT_line_rasterization                   : extension revision 1
	VK_EXT_memory_budget                        : extension revision 1
	VK_EXT_multi_draw                           : extension revision 1
	VK_EXT_non_seamless_cube_map                : extension revision 1
	VK_EXT_pci_bus_info                         : extension revision 2
	VK_EXT_physical_device_drm                  : extension revision 1
	VK_EXT_pipeline_creation_cache_control      : extension revision 3
	VK_EXT_pipeline_creation_feedback           : extension revision 1
	VK_EXT_primitive_topology_list_restart      : extension revision 1
	VK_EXT_primitives_generated_query           : extension revision 1
	VK_EXT_private_data                         : extension revision 1
	VK_EXT_provoking_vertex                     : extension revision 1
	VK_EXT_queue_family_foreign                 : extension revision 1
	VK_EXT_robustness2                          : extension revision 1
	VK_EXT_sample_locations                     : extension revision 1
	VK_EXT_scalar_block_layout                  : extension revision 1
	VK_EXT_separate_stencil_usage               : extension revision 1
	VK_EXT_shader_atomic_float                  : extension revision 1
	VK_EXT_shader_demote_to_helper_invocation   : extension revision 1
	VK_EXT_shader_module_identifier             : extension revision 1
	VK_EXT_shader_subgroup_ballot               : extension revision 1
	VK_EXT_shader_subgroup_vote                 : extension revision 1
	VK_EXT_shader_viewport_index_layer          : extension revision 1
	VK_EXT_subgroup_size_control                : extension revision 2
	VK_EXT_texel_buffer_alignment               : extension revision 1
	VK_EXT_tooling_info                         : extension revision 1
	VK_EXT_transform_feedback                   : extension revision 1
	VK_EXT_vertex_attribute_divisor             : extension revision 3
	VK_EXT_ycbcr_image_arrays                   : extension revision 1
	VK_GOOGLE_decorate_string                   : extension revision 1
	VK_GOOGLE_hlsl_functionality1               : extension revision 1
	VK_GOOGLE_user_type                         : extension revision 1
	VK_KHR_bind_memory2                         : extension revision 1
	VK_KHR_copy_commands2                       : extension revision 1
	VK_KHR_create_renderpass2                   : extension revision 1
	VK_KHR_dedicated_allocation                 : extension revision 3
	VK_KHR_deferred_host_operations             : extension revision 4
	VK_KHR_depth_stencil_resolve                : extension revision 1
	VK_KHR_descriptor_update_template           : extension revision 1
	VK_KHR_device_group                         : extension revision 4
	VK_KHR_draw_indirect_count                  : extension revision 1
	VK_KHR_driver_properties                    : extension revision 1
	VK_KHR_dynamic_rendering                    : extension revision 1
	VK_KHR_external_fence                       : extension revision 1
	VK_KHR_external_fence_fd                    : extension revision 1
	VK_KHR_external_memory                      : extension revision 1
	VK_KHR_external_memory_fd                   : extension revision 1
	VK_KHR_external_semaphore                   : extension revision 1
	VK_KHR_external_semaphore_fd                : extension revision 1
	VK_KHR_format_feature_flags2                : extension revision 2
	VK_KHR_get_memory_requirements2             : extension revision 1
	VK_KHR_image_format_list                    : extension revision 1
	VK_KHR_imageless_framebuffer                : extension revision 1
	VK_KHR_incremental_present                  : extension revision 2
	VK_KHR_maintenance1                         : extension revision 2
	VK_KHR_maintenance2                         : extension revision 1
	VK_KHR_maintenance3                         : extension revision 1
	VK_KHR_maintenance4                         : extension revision 2
	VK_KHR_multiview                            : extension revision 1
	VK_KHR_pipeline_executable_properties       : extension revision 1
	VK_KHR_push_descriptor                      : extension revision 2
	VK_KHR_relaxed_block_layout                 : extension revision 1
	VK_KHR_sampler_mirror_clamp_to_edge         : extension revision 3
	VK_KHR_sampler_ycbcr_conversion             : extension revision 14
	VK_KHR_separate_depth_stencil_layouts       : extension revision 1
	VK_KHR_shader_clock                         : extension revision 1
	VK_KHR_shader_draw_parameters               : extension revision 1
	VK_KHR_shader_float_controls                : extension revision 4
	VK_KHR_shader_integer_dot_product           : extension revision 1
	VK_KHR_shader_non_semantic_info             : extension revision 1
	VK_KHR_shader_subgroup_uniform_control_flow : extension revision 1
	VK_KHR_shader_terminate_invocation          : extension revision 1
	VK_KHR_spirv_1_4                            : extension revision 1
	VK_KHR_storage_buffer_storage_class         : extension revision 1
	VK_KHR_swapchain                            : extension revision 70
	VK_KHR_swapchain_mutable_format             : extension revision 1
	VK_KHR_synchronization2                     : extension revision 1
	VK_KHR_timeline_semaphore                   : extension revision 2
	VK_KHR_uniform_buffer_standard_layout       : extension revision 1
	VK_KHR_variable_pointers                    : extension revision 1
	VK_KHR_vulkan_memory_model                  : extension revision 3
	VK_KHR_workgroup_memory_explicit_layout     : extension revision 1
	VK_KHR_zero_initialize_workgroup_memory     : extension revision 1
	VK_NV_compute_shader_derivatives            : extension revision 1
	VK_VALVE_mutable_descriptor_type            : extension revision 1
VkQueueFamilyProperties:
	queueProperties[0]:
		minImageTransferGranularity = (1,1,1)
		queueCount                  = 1
		queueFlags                  = QUEUE_GRAPHICS_BIT | QUEUE_COMPUTE_BIT | QUEUE_TRANSFER_BIT
		timestampValidBits          = 36
		present support             = true
VkPhysicalDeviceMemoryProperties:
memoryHeaps: count = 1
	memoryHeaps[0]:
		size   = 1610612736 (0x60000000) (1.50 GiB)
		budget = 1610612736 (0x60000000) (1.50 GiB)
		usage  = 0 (0x00000000) (0.00 B)
		flags: count = 1
			MEMORY_HEAP_DEVICE_LOCAL_BIT
memoryTypes: count = 2
	memoryTypes[0]:
		heapIndex     = 0
		propertyFlags = 0x000b: count = 3
			MEMORY_PROPERTY_DEVICE_LOCAL_BIT
			MEMORY_PROPERTY_HOST_VISIBLE_BIT
			MEMORY_PROPERTY_HOST_CACHED_BIT
		usable for:
			IMAGE_TILING_OPTIMAL:
				color images
				FORMAT_D16_UNORM
				FORMAT_X8_D24_UNORM_PACK32
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				FORMAT_D24_UNORM_S8_UINT
				FORMAT_D32_SFLOAT_S8_UINT
				(non-sparse)
			IMAGE_TILING_LINEAR:
				color images
				(non-sparse)
	memoryTypes[1]:
		heapIndex     = 0
		propertyFlags = 0x0007: count = 3
			MEMORY_PROPERTY_HOST_COHERENT_BIT
		usable for:
				color images
				FORMAT_D16_UNORM
				FORMAT_D32_SFLOAT
				FORMAT_S8_UINT
				(non-sparse)
				color images
				(non-sparse)
VkPhysicalDeviceFeatures:
	robustBufferAccess                      = true
	fullDrawIndexUint32                     = true
	imageCubeArray                          = true
	independentBlend                        = true
	geometryShader                          = true
	tessellationShader                      = true
	sampleRateShading                       = true
	dualSrcBlend                            = true
	logicOp                                 = true
	multiDrawIndirect                       = true
	drawIndirectFirstInstance               = true
	depthClamp                              = true
	depthBiasClamp                          = true
	fillModeNonSolid                        = true
	depthBounds                             = false
	wideLines                               = true
	largePoints                             = true
	alphaToOne                              = true
	multiViewport                           = true
	samplerAnisotropy                       = true
	textureCompressionETC2                  = true
	textureCompressionASTC_LDR              = false
	textureCompressionBC                    = true
	occlusionQueryPrecise                   = true
	pipelineStatisticsQuery                 = true
	vertexPipelineStoresAndAtomics          = false
	fragmentStoresAndAtomics                = true
	shaderTessellationAndGeometryPointSize  = true
	shaderImageGatherExtended               = true
	shaderStorageImageExtendedFormats       = true
	shaderStorageImageMultisample           = false
	shaderStorageImageReadWithoutFormat     = false
	shaderStorageImageWriteWithoutFormat    = true
	shaderUniformBufferArrayDynamicIndexing = true
	shaderSampledImageArrayDynamicIndexing  = true
	shaderStorageBufferArrayDynamicIndexing = true
	shaderStorageImageArrayDynamicIndexing  = true
	shaderClipDistance                      = true
	shaderCullDistance                      = true
	shaderFloat64                           = false
	shaderInt64                             = false
	shaderInt16                             = false
	shaderResourceResidency                 = false
	shaderResourceMinLod                    = false
	sparseBinding                           = false
	sparseResidencyBuffer                   = false
	sparseResidencyImage2D                  = false
	sparseResidencyImage3D                  = false
	sparseResidency2Samples                 = false
	sparseResidency4Samples                 = false
	sparseResidency8Samples                 = false
	sparseResidency16Samples                = false
	sparseResidencyAliased                  = false
	variableMultisampleRate                 = true
	inheritedQueries                        = true
VkPhysicalDevice16BitStorageFeatures:
	storageBuffer16BitAccess           = false
	uniformAndStorageBuffer16BitAccess = false
	storagePushConstant16              = false
	storageInputOutput16               = false
VkPhysicalDevice4444FormatsFeaturesEXT:
	formatA4R4G4B4 = true
	formatA4B4G4R4 = false
VkPhysicalDevice8BitStorageFeatures:
	storageBuffer8BitAccess           = false
	uniformAndStorageBuffer8BitAccess = false
	storagePushConstant8              = false
VkPhysicalDeviceBufferDeviceAddressFeatures:
	bufferDeviceAddress              = false
	bufferDeviceAddressCaptureReplay = false
	bufferDeviceAddressMultiDevice   = false
VkPhysicalDeviceColorWriteEnableFeaturesEXT:
	colorWriteEnable = true
VkPhysicalDeviceDepthClampZeroOneFeaturesEXT:
	depthClampZeroOne = true
VkPhysicalDeviceDepthClipControlFeaturesEXT:
	depthClipControl = true
VkPhysicalDeviceDepthClipEnableFeaturesEXT:
	depthClipEnable = true
VkPhysicalDeviceDescriptorIndexingFeatures:
	shaderInputAttachmentArrayDynamicIndexing          = false
	shaderUniformTexelBufferArrayDynamicIndexing       = false
	shaderStorageTexelBufferArrayDynamicIndexing       = false
	shaderUniformBufferArrayNonUniformIndexing         = false
	shaderSampledImageArrayNonUniformIndexing          = false
	shaderStorageBufferArrayNonUniformIndexing         = false
	shaderStorageImageArrayNonUniformIndexing          = false
	shaderInputAttachmentArrayNonUniformIndexing       = false
	shaderUniformTexelBufferArrayNonUniformIndexing    = false
	shaderStorageTexelBufferArrayNonUniformIndexing    = false
	descriptorBindingUniformBufferUpdateAfterBind      = false
	descriptorBindingSampledImageUpdateAfterBind       = false
	descriptorBindingStorageImageUpdateAfterBind       = false
	descriptorBindingStorageBufferUpdateAfterBind      = false
	descriptorBindingUniformTexelBufferUpdateAfterBind = false
	descriptorBindingStorageTexelBufferUpdateAfterBind = false
	descriptorBindingUpdateUnusedWhilePending          = false
	descriptorBindingPartiallyBound                    = false
	descriptorBindingVariableDescriptorCount           = false
	runtimeDescriptorArray                             = false
VkPhysicalDeviceDynamicRenderingFeaturesKHR:
	dynamicRendering = true
VkPhysicalDeviceExtendedDynamicState2FeaturesEXT:
	extendedDynamicState2                   = true
	extendedDynamicState2LogicOp            = true
	extendedDynamicState2PatchControlPoints = false
VkPhysicalDeviceExtendedDynamicStateFeaturesEXT:
	extendedDynamicState = true
VkPhysicalDeviceHostQueryResetFeatures:
	hostQueryReset = true
VkPhysicalDeviceImage2DViewOf3DFeaturesEXT:
	image2DViewOf3D   = true
	sampler2DViewOf3D = false
VkPhysicalDeviceImageRobustnessFeaturesEXT:
	robustImageAccess = true
VkPhysicalDeviceImageViewMinLodFeaturesEXT:
	minLod = true
VkPhysicalDeviceImagelessFramebufferFeatures:
	imagelessFramebuffer = true
VkPhysicalDeviceIndexTypeUint8FeaturesEXT:
	indexTypeUint8 = true
VkPhysicalDeviceInlineUniformBlockFeaturesEXT:
	inlineUniformBlock                                 = true
	descriptorBindingInlineUniformBlockUpdateAfterBind = true
VkPhysicalDeviceLineRasterizationFeaturesEXT:
	rectangularLines         = false
	bresenhamLines           = true
	smoothLines              = true
	stippledRectangularLines = false
	stippledBresenhamLines   = true
	stippledSmoothLines      = false
VkPhysicalDeviceMaintenance4FeaturesKHR:
	maintenance4 = true
VkPhysicalDeviceMultiDrawFeaturesEXT:
	multiDraw = true
VkPhysicalDeviceMultiviewFeatures:
	multiview                   = true
	multiviewGeometryShader     = true
	multiviewTessellationShader = true
VkPhysicalDeviceMutableDescriptorTypeFeaturesEXT:
	mutableDescriptorType = true
VkPhysicalDeviceNonSeamlessCubeMapFeaturesEXT:
	nonSeamlessCubeMap = true
VkPhysicalDevicePipelineCreationCacheControlFeaturesEXT:
	pipelineCreationCacheControl = true
VkPhysicalDevicePipelineExecutablePropertiesFeaturesKHR:
	pipelineExecutableInfo = true
VkPhysicalDevicePrimitiveTopologyListRestartFeaturesEXT:
	primitiveTopologyListRestart      = true
	primitiveTopologyPatchListRestart = true
VkPhysicalDevicePrimitivesGeneratedQueryFeaturesEXT:
	primitivesGeneratedQuery                      = true
	primitivesGeneratedQueryWithRasterizerDiscard = false
	primitivesGeneratedQueryWithNonZeroStreams    = false
VkPhysicalDevicePrivateDataFeaturesEXT:
	privateData = true
VkPhysicalDeviceProtectedMemoryFeatures:
	protectedMemory = false
VkPhysicalDeviceProvokingVertexFeaturesEXT:
	provokingVertexLast                       = true
	transformFeedbackPreservesProvokingVertex = true
VkPhysicalDeviceRobustness2FeaturesEXT:
	robustBufferAccess2 = true
	robustImageAccess2  = true
	nullDescriptor      = true
VkPhysicalDeviceSamplerYcbcrConversionFeatures:
	samplerYcbcrConversion = true
VkPhysicalDeviceScalarBlockLayoutFeatures:
	scalarBlockLayout = true
VkPhysicalDeviceSeparateDepthStencilLayoutsFeatures:
	separateDepthStencilLayouts = true
VkPhysicalDeviceShaderAtomicFloatFeaturesEXT:
	shaderBufferFloat32Atomics   = true
	shaderBufferFloat32AtomicAdd = false
	shaderBufferFloat64Atomics   = false
	shaderBufferFloat64AtomicAdd = false
	shaderSharedFloat32Atomics   = true
	shaderSharedFloat32AtomicAdd = false
	shaderSharedFloat64Atomics   = false
	shaderSharedFloat64AtomicAdd = false
	shaderImageFloat32Atomics    = true
	shaderImageFloat32AtomicAdd  = false
	sparseImageFloat32Atomics    = false
	sparseImageFloat32AtomicAdd  = false
VkPhysicalDeviceShaderAtomicInt64Features:
	shaderBufferInt64Atomics = false
	shaderSharedInt64Atomics = false
VkPhysicalDeviceShaderClockFeaturesKHR:
	shaderSubgroupClock = true
	shaderDeviceClock   = false
VkPhysicalDeviceShaderDemoteToHelperInvocationFeaturesEXT:
	shaderDemoteToHelperInvocation = true
VkPhysicalDeviceShaderDrawParametersFeatures:
	shaderDrawParameters = true
VkPhysicalDeviceShaderFloat16Int8Features:
	shaderFloat16 = false
	shaderInt8    = false
VkPhysicalDeviceShaderIntegerDotProductFeaturesKHR:
	shaderIntegerDotProduct = true
VkPhysicalDeviceShaderModuleIdentifierFeaturesEXT:
	shaderModuleIdentifier = true
VkPhysicalDeviceShaderSubgroupExtendedTypesFeatures:
	shaderSubgroupExtendedTypes = true
VkPhysicalDeviceShaderSubgroupUniformControlFlowFeaturesKHR:
	shaderSubgroupUniformControlFlow = true
VkPhysicalDeviceShaderTerminateInvocationFeaturesKHR:
	shaderTerminateInvocation = true
VkPhysicalDeviceSubgroupSizeControlFeaturesEXT:
	subgroupSizeControl  = true
	computeFullSubgroups = true
VkPhysicalDeviceSynchronization2FeaturesKHR:
	synchronization2 = true
VkPhysicalDeviceTexelBufferAlignmentFeaturesEXT:
	texelBufferAlignment = true
VkPhysicalDeviceTimelineSemaphoreFeatures:
	timelineSemaphore = true
VkPhysicalDeviceTransformFeedbackFeaturesEXT:
	transformFeedback = true
	geometryStreams   = true
VkPhysicalDeviceUniformBufferStandardLayoutFeatures:
	uniformBufferStandardLayout = true
VkPhysicalDeviceVariablePointersFeatures:
	variablePointersStorageBuffer = true
	variablePointers              = true
VkPhysicalDeviceVertexAttributeDivisorFeaturesEXT:
	vertexAttributeInstanceRateDivisor     = true
	vertexAttributeInstanceRateZeroDivisor = true
VkPhysicalDeviceVulkan11Features:
	multiview                          = true
VkPhysicalDeviceVulkan12Features:
	samplerMirrorClampToEdge                           = true
	drawIndirectCount                                  = true
	shaderInt8                                         = false
	descriptorIndexing                                 = false
	samplerFilterMinmax                                = false
	vulkanMemoryModel                                  = true
	vulkanMemoryModelDeviceScope                       = true
	vulkanMemoryModelAvailabilityVisibilityChains      = true
	shaderOutputViewportIndex                          = true
	shaderOutputLayer                                  = true
	subgroupBroadcastDynamicId                         = true
VkPhysicalDeviceVulkanMemoryModelFeatures:
VkPhysicalDeviceWorkgroupMemoryExplicitLayoutFeaturesKHR:
	workgroupMemoryExplicitLayout                  = true
	workgroupMemoryExplicitLayoutScalarBlockLayout = true
	workgroupMemoryExplicitLayout8BitAccess        = true
	workgroupMemoryExplicitLayout16BitAccess       = true
VkPhysicalDeviceYcbcrImageArraysFeaturesEXT:
	ycbcrImageArrays = true
VkPhysicalDeviceZeroInitializeWorkgroupMemoryFeaturesKHR:
	shaderZeroInitializeWorkgroupMemory = true
Vulkan 1.3 won’t magically make your hardware 1.3-compliant. Try vulkaninfo --summary.
