Using KDE version of Manjaro, 64 bit. When I hover over the qBittorrent tray icon, the text which appears seems to be misrendered HTML:
I’ve marked the below answer as the solution to your question as it is by far the best answer you’ll get.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (I just want to avoid even more subjective opinions being posted and confusing you even more)
P.S. In the future, please mark a solution like this:
TLDR; this is intended, application need to respect the coding chart imposed by KDE for this issue to be fixed. Report this specific issue to each individual software pages (already done for qbittorrent // EDIT: and supposedly fixed too https://github.com/qbittorrent/qBittorrent/commit/89277a2f52b2bcade3798f85f262dc4e9724667c).
