I’m running Manjaro Cinnamon. This update downloaded and installed a part of gnome, bibata cursor theme, papirus icon theme and some other gnome fancy (for me - useless) stuff and branding worth almost 1GiB of disk space.
System updates shouldn’t install new packages unless they have to.
edit:
the funny thing is that most of them (if not all) have been uninstalled by running pacman -Rusc on bibata cursor theme, so it must have been some kind of dependency here.
Did you accidentally install manjaro-gnome-settings instead of manjaro-cinnamon-settings?
Please post your Pacman log from the update. If you updated today (Dec. 21), then use the following command as is. Otherwise change the date to yesterday if necessary:
grep -i 2022-12-21 /var/log/pacman.log
Please copy and paste it to a pastebin service and link it here.
I’ve removed the extra packages by running pacman -Rusc bibata-cursor-theme, here’s the log from this run:
My system is still up and running, nothing seems broken so far.
This is an almost 2 yr old instance, it seems like it doesn’t have manjaro-cinnamon-settings installed at all. I’ve removed it right after installation while removing papirus theme:
Actually you should have done with manjaro-gnome-settings
No idea how you ended up with it installed. bibata-cursor-theme (which has no dependencies) is a new dependency for manjaro-gnome-settings and manjaro-cinnamon-settings, nothing else changed.
Yeah, I can’t figure it out as well. But at least it went away easily.
And my laptop is not affected by this (I haven’t updated my laptop at the time of reporting this issue).
