[ARM Stable Update] 2023-12-05 - Kernels, Firefox, Thunderbird, LibreOffice, KDE
Hello ARM community.
We updated kernels, renewed KDE Gear, KDE Frameworks and offer other related goodies for you.
Update Announcement
Some highlights:
  • Some Kernels got updated
    • Linux-Firmware got updated
    • PinePhone kernels got updated to latest 6.4 series
  • Firefox is now at 119.0.1 and Thunderbird at 115.4.2
  • Systemd is now at 254.6
  • KDE Frameworks is at 5.112.0
  • KDE Gear 23.08.3 got released
  • Some missing Plasma Mobile rebuilds got added
  • changes in JDK / JRE 21 packages
    • see Known Issues below for more info
  • LibreOffice 7.5.8
  • last Qt5 based LXQt release got added 1.4.0
  • Pipewire 0.3.84
  • The usual python and KDE-git updates (which moved to Qt6)
Tips And Tricks
Error about missing openssl 1.1 library
Since the update to the new OpenSSL 3.0, some applications might still be looking for version 1.1 og openssl.
Fortunately Arch Linux created a compatability package for such events called openssl-1.1.
So if you encounter any such errors, please install the above mentioned package.
Applications currently known to specifically look for 1.1 is silver. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install openssl-1.1 as part of this update.
How to get Waydroid working
If you follow these steps, you should have Waydroid working fine.
Remember, Waydroid only works on wayland!
  • Install waydroid-image and all it’s dependencies.
  • Run pkexec setup-waydroid.
  • You should now be able to launch Waydroid. The first launch takes a while.
sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev
This means the kodi.service file need to replace whatever login manager you have installled. In my case I would:
over_voltage=5
arm_freq=2000
#gpu_mem=64     #disable this
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
dtoverlay=vc4-kms-v3d,cma-512
#max_framebuffers=2    #disable cause kodi uses more
disable_fw_kms_setup=1
Some notes:
The default user will be kodi
Upstream Notifications:
Older notifications
The PHP package has been updated to 8.2. If you still need 8.1, use php-legacy packages.
Arch Linux - News: PHP 8.2 update and introduction of legacy branch
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to libxcrypt:
Arch Linux - News: Sorting out old password hashes
The ghostpcl and ghostxps requires manual intervention (if you have these installed):
The nss package requires manual intervention:
The packages hplip and firewalld requires manual intervention:
Package Changes (Wed Nov 15 03:52:53 CET 2023)
  • arm-stable core aarch64: 49 new and 46 removed package(s)
  • arm-stable extra aarch64: 1466 new and 1442 removed package(s)
  • arm-stable kde-unstable aarch64: 319 new and 317 removed package(s)
A full list of all package changes can be found here.
  • Run this command to switch branch: sudo pacman-mirrors -aS testing && sudo pacman -Syyu. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in Testing Updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
  • Yes there was an issue. I was able to resolve it myself. (Please post your solution)
0 voters
Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through donations and corporate sponsorships to support its growth and development. These donations are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or conferences and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to donate!
Known Issues and Solutions
This is a wiki post, please edit it when you find a solution to an issue you encountered
:arrow_right: 2023-12-05
2023-06-06
If you have a lot of pip/AUR packages to upgrade to Python 3.11
Short version, for experienced users:
[HowTo] Python upgrade: reinstall AUR and pip packages
Long version with full details:
[HowTo] After a Python interpreter upgrade, reinstall non-working Python packages
Many applications (firefox, thunderbird, etc) slow to start on desktops other than Gnome
There is a bug with xdg-desktop-portal-gnome (more details here).
Workaround for gtk-based desktops (including Xfce)
sudo pacman -Rdd xdg-desktop-portal-gnome
sudo pacman -S xdg-desktop-portal-gtk
Workaround for KDE
sudo pacman -S xdg-desktop-portal-kde
Workaround for Lxqt
sudo pacman -S xdg-desktop-portal-lxqt
Workaround for desktops using hyprland
sudo pacman -S xdg-desktop-portal-hyprland
Workaround for desktops using wlroots
sudo pacman -S xdg-desktop-portal-wlr
If you installed python311 from the AUR, you need to uninstall it before running this update.
2023-02-16
Docker 23 not starting
Since the update to Docker 23, upstream is now inforcing new paths for apparmor related stuff. But there has been changes to dependencies yet. So Docker 23 will error on start.
Fix: Install apparmor from the repositories.
2023-01-03
Reduced video playback performance in mpv
There has been reports of video playback performance in mpv has regressed since an update to mpv.
Fix: MPV now needs a vd-lavc-dr=no parameter to play hw acceleration supported 1080p videos smoothly.
Touch input on Firefox with Phosh not working in Firefox 108
Since the update to Firefox 108, the touch input does not work. Seems to be an issue with a couple of the changes the mobile-config brings in. PostMarketOS likely won’t fix this in their source, so we might need to carry a patch for this.
2022-11-20
OpenSSL 1.1 library not found
Some applications might still be looking for openssl 1.1.
Solution: Install openssl-1.1 package with sudo pacman -S openssl-1.1.
2022-10-31
Firefox shows wrong colors when playing video on Raspberry Pi 4
Since Mesa 22.2, Firefox has been showing weird colors when playing video on the Raspberry Pi 4. This is caused by an issue in upstream mesa, which was recently fixed.
Fix: Update to mesa 22.2.3-0.1 in the repository, which includes this fix.
Chromium in Wayland crashes with --in-process-gpu
Since Mesa 22.2.0, Chromium running in wayland sessions seems to crash when running with the --in-process-gpu option. Running in X11 seems fine, although it’s slow.
Fix: Update to Mesa 22.3.2 was reported to work here.
2022-10-21
Plasma Mobile Dialer seems to be unreliable
Plasma Dialer 22.09 seems to have issues switching audio profiles and as such might require manual switching. Sometimes audio is completely missing.
Reduced video performance on youtube
Some may encounter reduced video playback performance on YouTube in Firefox with the new Mesa 22.2 drivers.
No workaround at this time.
Old Issues
Phosh crashes when closing apps
An upstream issue results in the Phosh shell to crash when you close the app in the app switcher, with animations turned off.
Fix: Enable animations in Tweaks application
Mouse cursor is slow on Raspberry Pi
Due to a change in the Raspberry Pi kernels upstream, they no longer support FKMS. This can result in slow performance when using the FKMS drivers with the newer Raspberry Pi kernels.
Solution: Open /boot/config.txt, change fkms to kms in the dtoverlay line. Save the file and reboot.
[Waydroid container cannot access internet
Cause: new default waydroid configuration issue, tracked here.
Short-term Solution:
  1. create /etc/nftables.d/waydroid.nft with the following contents:
#!/usr/sbin/nft -f
table inet filter {
    chain input {
        iifname "waydroid0" accept comment "Allow incoming network traffic from WayDroid"
    chain forward {
        iifname "waydroid0" accept comment "Allow outgoing network traffic from WayDroid"
        ct state {established, related} counter accept comment "accept established connections"
```Hello ARM community,
this is my fourth **stable** update for our aarch64 architecture.
Most already know that we had some staff changes in our Manjaro ARM team. You might already have noticed that Dan [left the team](https://blog.strits.dk/i-no-longer-work-for-manjaro/) and the company. Therefore we have also to see when the next install medias for ARM SBCs and devices will been created. Dan did a lot for the ARM branch of Manjaro, including endless testing of boards and devices. Before releasing any image for an ARM device it needs to been tested on the device itself. You can find untested [development builds](https://github.com/orgs/manjaro-arm/repositories) at github.
Therefore I'll act as the interim release manager until we found the right staff member for this job.
## Donate
Manjaro, like many other open-source projects, relies on the generosity of its community through [donations](https://manjaro.org/donate/) and corporate sponsorships to support its growth and development. These [donations](https://manjaro.org/donate/) are essential in covering the various expenses incurred in the operations of the project such as server costs, software development tools, infrastructure expenses, training, flying people to events or [conferences](https://blog.manjaro.org/fosdem-2023/) and the salaries of key developers. With the help of these donations, Manjaro is able to secure the necessary financial stability that allows the project to continuously improve and remain active. If you love Manjaro, consider to [donate](https://manjaro.org/donate/)!
## Update Announcement
With this update we have mostly updates to [Apple Silicon](https://gitlab.manjaro.org/manjaro-arm/packages/apple-silicon) and mobile.
*Some highlights:*
- Some **Kernels** got renewed
- **Apple-Silicon** packages got renewed to the latest issued by Asahi Linux. [Graphic stack](https://asahilinux.org/2023/06/opengl-3-1-on-asahi-linux/) got improved a lot. However, our installer is still internal
- **Calls** is now at [44.2](https://gitlab.gnome.org/GNOME/calls/-/raw/91e5cad939f6753bc232c8990be295b068473949/debian/changelog)
- the app **vakzination** got rebuild to fix so-file issues
- **libpamac** got renewed to [11.5.4](https://gitlab.manjaro.org/applications/libpamac/-/tags/11.5.4)
- Usual **KDE-git** updates
*End Of Life kernels (will be removed from repo soon):*
* `linux60` (EOL on 2023-01-12) (removed from repository)
## Tips And Tricks
[details="Error about missing openssl 1.1 library"]
Fortunately Arch Linux created a compatability package for such events called `openssl-1.1`.
Applications currently known to specifically look for 1.1 is `silver`. We have not been able to rebuild it yet. So if you are on our Gnome or Sway editions, please install `openssl-1.1` as part of this update.
[/details]
[details="How to get Waydroid working"]
*Remember, Waydroid only works on wayland!*
* Install `waydroid-image` and all it's dependencies.
* Run `pkexec setup-waydroid`.
* You should now be able to launch Waydroid. The first launch takes a while.
[/details]
[details="How to use Kodi RPI on Manjaro ARM"]
`sudo pacman -S kodi-rpi kodi-rpi-dev kodi-rpi-eventclients kodi-rpi-tools-texturepacker libcec-rpi linux-rpi4 xf86-video-fbdev`
### Have it set up is to boot straight in to kodi
`sudo systemctl disable lightdm.service`
`sudo systemctl enable kodi.service`
over_voltage=5
arm_freq=2000
kernel=kernel8.img
arm_64bit=1
disable_overscan=1
#enable sound
dtparam=audio=on
hdmi_drive=2
#enable vc4
Some notes:
[/details]
## Upstream Notifications:
[details="Older notifications"]
The PHP package has been updated to 8.2. If you still need 8.1, use `php-legacy` packages.
https://archlinux.org/news/php-82-update-and-introduction-of-legacy-branch/
If you used the Manjaro ARM Installer or is using PinePhone or PineTab, you need to redo your passwords, because of an update to `libxcrypt`:
https://archlinux.org/news/sorting-out-old-password-hashes/
The `ghostpcl` and `ghostxps` requires manual intervention (if you have these installed):
https://www.archlinux.org/news/ghostpcl9532-2-and-ghostxps9532-2-updates-require-manual-intervention/
The `nss` package requires manual intervention:
https://www.archlinux.org/news/nss3511-1-and-lib32-nss3511-1-updates-require-manual-intervention/
The packages `hplip` and `firewalld` requires manual intervention:
https://www.archlinux.org/news/hplip-3203-2-update-requires-manual-intervention/
https://www.archlinux.org/news/firewalld081-2-update-requires-manual-intervention/
[/details]
## Package Changes (Fri May 19 13:30:34 CEST 2023)
 - arm-stable community aarch64:  20 new and 20 removed package(s)
 - arm-stable core aarch64:  24 new and 23 removed package(s)
 - arm-stable extra aarch64:  4 new and 4 removed package(s)
 - arm-stable kde-unstable aarch64:  289 new and 289 removed package(s)
:: Different overlay package(s) in repository community aarch64
                         PACKAGE           2023.06.09           2023.06.12
           apple-silicon-configs           20221206-1           20230517-1
                 asahi-fwextract            0.5pre2-3              0.5.4-1
                   asahi-scripts           20221206-1           20230606-2
                       bitwarden           2023.5.0-1           2023.5.0-2
                      callaudiod              0.1.9-1              0.1.9-2
                            code             1.78.2-1             1.79.0-1
                        electron             23.1.2-1             23.3.6-1
                      electron20            20.3.11-1                    -
                      electron21             21.4.2-1             21.4.4-1
                      electron22             22.3.2-1            22.3.12-1
                     gnome-calls               44.1-2               44.2-1
              gnome-shell-mobile44.0+r283+g034144c20-144.1+r326+g9b7df11f1-1
         mesa-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
   mesa-apple-silicon-edge-debug 23.1.0_pre20230311-1 23.2.0_pre20230606-1
                   mutter-mobile44.0+r88+g780aadd4e-244.1+r191+g5e72de83d-2.0
                           phosh             0.28.0-10.28.0+13+g31896512-1
                  phosh-antispam              3.2.0-2              3.3.0-1
                     vakzination            23.01.0-1            23.01.0-2
vulkan-swrast-apple-silicon-edge 23.1.0_pre20230311-1 23.2.0_pre20230606-1
                    wire-desktop          3.30.3018-1          3.31.3060-1
                      electron24                    -             24.5.0-1
:: Different overlay package(s) in repository core aarch64
                           linux              6.3.5-1              6.3.7-1
                       linux-aml             6.1.31-1             6.1.33-1
               linux-aml-headers             6.1.31-1             6.1.33-1
             linux-apple-silicon                6.2-1                6.3-1
        linux-apple-silicon-edge                6.2-1                6.3-1
     linux-apple-silicon-headers                6.2-1                6.3-1
                   linux-headers              6.3.5-1              6.3.7-1
                       linux-lts             6.1.31-1             6.1.33-1
               linux-lts-headers             6.1.31-1             6.1.33-1
                 linux-pinephone              6.3.5-1              6.3.7-1
         linux-pinephone-headers              6.3.5-1              6.3.7-1
              linux-pinephonepro              6.3.5-1              6.3.7-1
      linux-pinephonepro-headers              6.3.5-1              6.3.7-1
                      linux-rpi4             6.1.31-1             6.1.32-1
              linux-rpi4-headers             6.1.31-1             6.1.32-1
             linux-rpi4-mainline              6.3.5-1              6.3.6-1
     linux-rpi4-mainline-headers              6.3.5-1              6.3.6-1
                   linux-rpi4-rc            6.4.rc4-1            6.4.rc5-1
           linux-rpi4-rc-headers            6.4.rc4-1            6.4.rc5-1
                            m1n1              1.2.6-1              1.2.9-1
             uboot-apple-silicon            2023.01-1            2023.04-1
              uboot-pinephonepro     5:2023.07rc2-0.3     5:2023.07rc2-0.4
     uboot-pinephonepro-rockchip     5:2023.07rc2-0.3     5:2023.07rc2-0.4
                uboot-odroid-n2l                    -            2023.04-1
:: Different overlay package(s) in repository extra aarch64
                        libpamac             11.5.3-1             11.5.4-1
         libpamac-flatpak-plugin             11.5.3-1             11.5.4-1
            libpamac-snap-plugin             11.5.3-1             11.5.4-1
                           snapd             2.59.5-1             2.59.5-2
:: Different overlay package(s) in repository kde-unstable aarch64
                         akonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
                akonadi-calendar23.04.1.r2364.g2c16022-123.04.2.r2364.g2c16022-1
          akonadi-calendar-tools23.04.0.r1047.g7a009d5-123.04.2.r1050.g9ba89ef-1
                akonadi-contacts23.04.1.r3474.gc4e5f229-123.04.2.r3474.gc4e5f229-1
           akonadi-import-wizard23.04.1.r1941.g5abcbc9-123.04.2.r1941.g5abcbc9-1
                    akonadi-mime23.04.1.r1873.gae00608-123.04.2.r1874.gf4c29c4-1
                   akonadi-notes23.04.1.r1169.gb451bbe-123.04.2.r1169.gb451bbe-1
                  akonadi-search23.04.1.r1395.gc9cd29c-123.04.2.r1397.gfd9883c-1
                  akonadiconsole23.04.0.r1747.g17f7951-123.04.2.r1748.gb566587-1
                       akregator23.04.0.r6725.g3b691ed9-123.04.2.r6726.g5325284a-1
                        analitza23.04.1.r2396.gb2b30fe1-123.04.2.r2396.gb2b30fe1-1
                             ark23.04.0.r5088.g2a7f46b3-123.04.2.r5090.g5033a623-1
                      artikulate23.04.1.r1522.g9344e4f-123.04.2.r1522.g9344e4f-1
                     audiocd-kio23.04.1.r1206.ge338398-123.04.2.r1208.g061a22c-1
                           baloo5.106.0.r3244.geafae07a-15.106.0.r3245.g9755144d-1
                   baloo-widgets23.04.1.r878.g2e8ea3c-123.04.2.r878.g2e8ea3c-1
                         blinken23.04.1.r740.g6d13ea0-123.04.2.r740.g6d13ea0-1
                       bluedevil1:5.27.5.r2612.ge033d939-11:5.27.5.r2613.gb31f376a-1
                          bomber23.04.1.r636.g7e6e493-123.04.2.r636.g7e6e493-1
                            bovo23.04.1.r857.ga9f1dbe-123.04.2.r857.ga9f1dbe-1
                          breeze5.27.5.r2628.g5d279205-15.27.5.r2629.g4afc46e7-1
                            buho  3.0.0.r5.gec42169-1  3.0.0.r6.ga4c2c66-1
                 calendarsupport23.04.0.r849.gde62582-123.04.2.r849.gde62582-1
                          cantor23.04.1.r3600.g19ed0b66-123.04.2.r3603.gdbbd804e-1
                        cervisia23.04.0.r1778.g9b84f0b-123.04.2.r1779.gefbddbb-1
                        discover5.27.5.r9333.gc4c0ad257-15.27.5.r9335.g725681901-1
                         dolphin23.04.1.r7416.ge5abe2c67-123.04.2.r7417.gbb08c70a9-1
                 dolphin-plugins23.04.0.r760.gb6391fd-123.04.2.r761.g1abd322-1
                          dragon23.04.1.r1194.g8f5664a-123.04.2.r1196.g94b6111-1
                         drkonqi5.27.5.r930.g8cb1aea1-15.27.5.r931.g9c42ce25-1
                           elisa23.04.1.r3313.g2ebf6bd6-123.04.2.r3320.g8d11cf2f-1
                      elisa-qtmm23.04.1.r3313.g2ebf6bd6-123.04.2.r3320.g8d11cf2f-1
                      eventviews23.04.0.r1026.g54d1d27-123.04.2.r1028.gdd65a38-1
                    ffmpegthumbs23.04.1.r263.g8a8b7c2-123.04.2.r263.g8a8b7c2-1
                       filelight23.04.0.r1408.g2f2b5a1-123.04.2.r1410.g253b29d-1
                       granatier23.04.1.r1051.g5e93a6c-123.04.2.r1051.g5e93a6c-1
                 grantlee-editor23.04.0.r941.gb634afb-123.04.2.r941.gb634afb-1
                   grantleetheme23.04.1.r504.g1f1c47b-123.04.2.r504.g1f1c47b-1
                        gwenview23.04.1.r7161.ga483380d-123.04.1.r7164.g47e8bdb0-1
                 incidenceeditor23.04.1.r1050.g7b9c8a1-123.04.2.r1051.g7c3d773-1
                       itinerary23.04.0.r2712.g01b4fc49-123.04.2.r2715.gae36bdb6-1
                             juk23.04.1.r3265.g77d80714-123.04.2.r3266.gf840340e-1
                             k3b1:23.04.1.r6998.g1cf60e813-11:23.04.2.r6999.g329361b61-1
           kaccounts-integration23.04.1.r1364.gbf22267-223.04.2.r1364.gbf22267-1
             kaccounts-providers23.04.1.r443.g3e40fe3-123.04.2.r443.g3e40fe3-1
               kactivitymanagerd5.27.5.r1462.g861f9de-15.27.5.r1463.gd454806-1
                    kaddressbook23.04.1.r6417.g5c6a2248-123.04.2.r6420.gbc60dd46-1
                         kajongg23.04.1.r4419.gdcdf2ee5-123.04.2.r4422.g451e34a3-1
                          kalarm23.04.0.r8339.g365a6581-123.04.2.r8395.g124644f6-1
                        kalgebra23.04.1.r2162.g0ded608-123.04.2.r2162.g0ded608-1
                         kalzium23.04.1.r4512.ge103ed83-123.04.2.r4516.g80a9ab41-1
                          kamera23.04.1.r828.gd491cfd-123.04.2.r828.gd491cfd-1
                          kamoso23.04.0.r1557.ga018c91-123.04.2.r1557.ga018c91-1
                        kanagram23.04.1.r1406.gbc68a1f-123.04.2.r1406.gbc68a1f-1
                          kapman23.04.1.r734.gc63a2da-123.04.2.r734.gc63a2da-1
                    kapptemplate23.04.0.r1063.g5fded2a-123.04.2.r1063.g5fded2a-1
                           kasts23.01.0.r165.gb1d8d47-123.01.0.r168.g21952c6-1
                            kate23.04.0.r20721.gd208dfe5a-123.04.2.r20730.geefd3ba2d-1
                         katomic23.04.1.r1046.g9ed1b51-123.04.2.r1046.g9ed1b51-1
                         kbackup23.04.0.r544.g81bfeb6-123.04.2.r544.g81bfeb6-1
                       kblackbox23.04.1.r846.gb0bfda4-123.04.2.r847.gdc37f08-1
                         kblocks23.04.1.r826.g2447c84-123.04.2.r826.g2447c84-1
                      kbookmarks5.106.0.r535.g5dd2497-15.106.0.r536.g60642fc-1
                         kbounce23.04.1.r932.gc80ffc9-123.04.2.r932.gc80ffc9-1
                       kbreakout23.04.1.r999.gbfe0cbd-123.04.2.r999.gbfe0cbd-1
                          kbruch23.04.1.r956.g4a4b7e8-123.04.2.r956.g4a4b7e8-1
                     kcachegrind23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
              kcachegrind-common23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
                           kcalc23.04.0.r1736.ga499fae-123.04.2.r1736.ga499fae-1
                       kcalutils23.04.1.r1084.gf8302135f-123.04.2.r1084.gf8302135f-1
                     kcharselect23.04.0.r625.g019cf4f-123.04.2.r625.g019cf4f-1
                          kclock23.01.0.r72.g6533949-123.01.0.r74.g352cc69-1
                        kcmutils5.106.0.r752.g861104da-15.106.0.r754.g9772c61d-1
                   kcolorchooser23.04.1.r337.gde9049d-123.04.2.r337.gde9049d-1
                         kconfig5.106.0.r1082.g1b47e6c3-15.106.0.r1083.g3c6d59de-1
                       kcontacts1:5.106.0.r3432.g80b99ae8-11:5.106.0.r3433.g729e4154-1
                           kcron23.04.0.r907.g9637eb7-123.04.2.r907.g9637eb7-1
                   kde-cli-tools5.27.5.r2130.ge8132be-15.27.5.r2133.g1787873-1
                 kde-dev-scripts23.04.0.r4182.gbd504fa-123.04.2.r4182.gbd504fa-1
                   kde-dev-utils23.04.0.r663.g74eae5a-123.04.2.r666.g0d5e900-1
                  kdebugsettings23.04.0.r1367.g2b9cccc-123.04.2.r1368.gba99146-1
                      kdeconnect23.04.0.r3842.gdf9be7e6-123.04.2.r3849.g4ef7c262-1
                     kdeedu-data23.04.1.r22.g793df3b-123.04.2.r22.g793df3b-1
          kdegraphics-mobipocket23.04.1.r290.g16b2e58-123.04.2.r290.g16b2e58-1
        kdegraphics-thumbnailers23.04.1.r295.g3da9b35-123.04.2.r297.g9dbad70-1
                 kdelibs4support5.106.0.r1205.g6356e0ee-15.106.0.r1206.ga4526feb-1
          kdenetwork-filesharing23.04.0.r1094.gdc7ac35-123.04.2.r1094.gdc7ac35-1
                        kdenlive23.04.0.r18149.gc00260e0d-123.04.2.r18192.g6154d791d-1
                   kdepim-addons23.04.0.r5271.g0cc67708c-123.04.2.r5272.g9f5ee3de1-1
                  kdepim-runtime23.04.1.r15928.gea73e40e2-123.04.2.r15929.ge2729f0ab-1
                kdeplasma-addons5.27.5.r9399.gb86d9f13b-15.27.5.r9401.gdeff16fd2-1
                kdesdk-kioslaves23.04.0.r505.g1f7909e-123.04.2.r505.g1f7909e-1
             kdesdk-thumbnailers23.04.0.r133.g989c6a3-123.04.2.r135.gbc52836-1
                             kdf23.04.0.r976.g86e7b91-123.04.2.r976.g86e7b91-1
                         kdialog23.04.0.r1365.g0fe2062c1-123.04.2.r1366.g0832b04ba-1
                        kdiamond23.04.1.r798.gcc46502-123.04.2.r799.g7596172-1
                  keditbookmarks23.04.0.r2838.ga35a913a2-123.04.2.r2841.ga0c18fdc0-1
                        keysmith23.01.0.r64.gb6f41d9-123.01.0.r65.ge941e7e-1
                   kfilemetadata5.106.0.r973.g7c395e2-15.106.0.r976.g53923f5-1
                           kfind23.04.0.r2820.g86338ab1e-123.04.2.r2821.g789620dbc-1
                         kfloppy23.04.0.r874.g96209b6-123.04.2.r875.gf2f65d2-1
                     kfourinline23.04.1.r1108.g0461ef3-123.04.2.r1108.g0461ef3-1
                      kgeography23.04.1.r1255.g7d31981-123.04.2.r1255.g7d31981-1
                            kget23.04.0.r3369.g22d0c200-123.04.2.r3370.g179d7f65-1
                    kglobalaccel5.106.0.r663.g659f251-15.106.0.r664.gc538ad5-1
                     kgoldrunner23.04.1.r1380.g1aa9eee-123.04.2.r1382.gb59d5d2-1
                        khangman23.04.1.r1700.g5d32616-123.04.2.r1700.g5d32616-1
                     khelpcenter23.04.0.r2896.g2d2d1f04-123.04.2.r2899.ge7acf8e8-1
                        khotkeys5.27.5.r2245.g85c7f71-15.27.5.r2246.gb2a103e-1
                           khtml5.106.0.r682.g121f508-15.106.0.r683.g14a5880-1
                     kiconthemes5.106.0.r702.ga973b2a-15.106.0.r703.gcc16d7d-1
             kidentitymanagement23.04.1.r4007.g36e0f760-123.04.2.r4008.gcb17bd07-1
                             kig23.04.1.r3343.g58ce31b1-123.04.2.r3345.g046a3f87-1
                            kigo23.04.1.r659.ge608c95-123.04.2.r660.gd1de2ff-1
                        killbots23.04.1.r873.ge3deff6-123.04.2.r875.gdec0ee7-1
                 kimagemapeditor23.04.1.r584.ge06fa84-123.04.2.r586.g0bf89e6-1
                           kimap23.04.1.r1301.ge04dd9b-123.04.2.r1301.ge04dd9b-1
                     kinfocenter5.27.5.r2383.g18c0d4d0-15.27.5.r2386.g8d0d365c-1
                             kio5.106.0.r6191.g0e6c01e0c-15.106.0.r6196.g811fae761-1
                      kio-extras23.04.0.r7573.g6950463ed-123.04.2.r7575.g0680a0462-1
                      kio-gdrive23.04.0.r725.g39de711-123.04.2.r725.g39de711-1
                 kirigami-addons1:0.8.0.r47.g3604f34-11:0.8.0.r49.gcf3d908-1
                kirigami-gallery23.04.0.r353.gb960590-123.04.2.r353.gb960590-1
                       kirigami25.106.0.r3710.g21106c6e-15.106.0.r3713.g74155121-1
                          kiriki23.04.1.r533.g282d39b-123.04.2.r534.g7e28ff1-1
                     kitemmodels5.106.0.r649.g736563f-15.106.0.r650.g0952af4-1
                           kiten23.04.1.r1286.g11f5f88-123.04.2.r1286.g11f5f88-1
                      kitinerary23.04.1.r2949.gc43adca3-123.04.2.r2957.gf62f9635-1
                    kjumpingcube23.04.1.r917.gcd4e342-123.04.2.r917.gcd4e342-1
                           kldap23.04.1.r1092.g385db87-123.04.2.r1092.g385db87-1
                       kleopatra23.04.0.r7300.ge249c30e-123.04.2.r7308.g8cbe0a3d-1
                        klettres23.04.1.r1050.ga7614e7-123.04.2.r1050.ga7614e7-1
                        klickety23.04.1.r775.g8f86b24-123.04.2.r775.g8f86b24-1
                          klines23.04.1.r893.g05309f8-123.04.2.r894.g7c56c56-1
                            kmag23.04.1.r819.gc83e844-123.04.2.r819.gc83e844-1
                       kmahjongg23.04.1.r1664.g1390305-123.04.2.r1665.g515b2d5-1
                           kmail23.04.0.r27005.g05f2056d5-123.04.2.r27037.g58218c12c-1
            kmail-account-wizard23.04.0.r985.ge4a7cf5-123.04.2.r985.ge4a7cf5-1
                  kmailtransport23.04.1.r1937.g588a092-123.04.2.r1938.g5961f5b-1
                           kmbox23.04.1.r653.gf9238bc-123.04.2.r653.gf9238bc-1
                       kmenuedit5.27.5.r1180.g3ed6ce1-15.27.5.r1181.g0e27bea-1
                           kmime23.04.1.r1629.ga926427-123.04.2.r1629.ga926427-1
                          kmines23.04.1.r1845.g02b3b61-123.04.2.r1845.g02b3b61-1
                            kmix23.04.0.r2556.g2f7272a2-123.04.2.r2582.g1d516924-1
                      kmousetool23.04.1.r523.g55db80d-123.04.2.r524.g2d95fcf-1
                          kmouth23.04.1.r829.g82e5da8-123.04.2.r830.gdd57bdd-1
                          kmplot23.04.1.r1593.g76d6ade-123.04.2.r1594.gf6720cc-1
                    knavalbattle23.04.1.r1514.gde963e6-123.04.2.r1514.gde963e6-1
                        knetwalk23.04.1.r788.g017a27e-123.04.2.r788.g017a27e-1
                       knewstuff5.106.0.r1552.g5bf8c87f-15.106.0.r1554.gb67db719-1
                         knights23.04.1.r1243.ga2b1ca6-123.04.2.r1243.ga2b1ca6-1
                          knotes23.04.0.r3917.gc00720f7-123.04.2.r3918.gb55dded6-1
                            kolf23.04.1.r1604.gce02248-123.04.2.r1604.gce02248-1
                       kollision23.04.1.r606.ga16e446-123.04.2.r606.ga16e446-1
                     kolourpaint23.04.1.r2534.g3c112dc4-123.04.2.r2536.g4b279d88-1
                         kompare23.04.0.r1285.geebb3f3-123.04.2.r1287.g4bce7f2-1
                       konqueror23.04.0.r15448.g3e8624be9-123.04.2.r15452.g4cd673089-1
                        konquest23.04.1.r1021.gc3687c4-123.04.2.r1021.gc3687c4-1
                         konsole23.04.0.r9075.g95bcf2e0a-123.04.2.r9082.g73d067991-1
                         kontact23.04.0.r5767.g2c999500-123.04.2.r5767.g2c999500-1
                kontactinterface23.04.1.r791.gfca2805-123.04.2.r791.gfca2805-1
                        kontrast23.04.1.r319.gfd12f26-123.04.2.r319.gfd12f26-1
                    konversation23.04.0.r9297.g2379a978-123.04.2.r9297.g2379a978-1
                   kopeninghours23.04.1.r391.gfae8220-123.04.2.r391.gfae8220-1
                          kopete23.04.0.r16568.g7b7a0f0c9-123.04.2.r16570.ga053f12a8-1
                      korganizer23.04.0.r12137.g194a9f057-123.04.2.r12137.g194a9f057-1
                   kosmindoormap23.04.1.r1010.g90a71f2-123.04.2.r1010.g90a71f2-1
                            kpat23.04.1.r2756.g24dba31f-123.04.2.r2756.g24dba31f-1
                    kpimtextedit23.04.1.r1874.g5c1eaaa-123.04.2.r1901.ge91a512-1
                         kpkpass23.04.1.r348.ge38d0dd-123.04.2.r348.ge38d0dd-1
                         kpmcore23.04.1.r1374.g992174e-123.04.2.r1375.g6640766-1
                kpublictransport23.04.1.r2179.g231e3f02-123.04.2.r2180.g8b7136a5-1
                  kqtquickcharts23.04.1.r78.g22ff9c9-123.04.2.r78.g22ff9c9-1
                            krdc23.04.0.r1721.g4d6fa90-123.04.2.r1721.g4d6fa90-1
                        kreversi23.04.1.r1353.gd7e11ea-123.04.2.r1353.gd7e11ea-1
                            krfb23.04.0.r1578.gf2fc9ca-123.04.2.r1578.gf2fc9ca-1
              kross-interpreters23.04.0.r725.gdef2cfe-123.04.2.r725.gdef2cfe-1
                          kruler23.04.1.r852.g9b1eff8-123.04.2.r852.g9b1eff8-1
                         kshisen23.04.1.r1342.g1117378-123.04.2.r1343.gc44c7f9-1
                           ksirk23.04.1.r1141.g8fb1bae-123.04.2.r1142.gf1b7179-1
                           ksmtp23.04.1.r532.g0b9c77f-123.04.2.r532.g0b9c77f-1
                      ksnakeduel23.04.1.r929.g2ef8918-123.04.2.r929.g2ef8918-1
                      kspaceduel23.04.1.r740.gfb3d585-123.04.2.r740.gfb3d585-1
                        ksquares23.04.1.r658.g090ed62-123.04.2.r658.g090ed62-1
                         ksudoku23.04.1.r1202.g30027d1-123.04.2.r1203.ge15bbbe-1
                      ksystemlog23.04.0.r855.g7139f9e-123.04.2.r856.g17b7432-1
                        kteatime23.04.0.r831.g5c745f8-123.04.2.r832.g1a85fd8-1
                     ktextaddons      r481.g1030c42-1      r483.g85d7867-1
                     ktexteditor5.106.0.r3833.gd8abfb98-15.106.0.r3834.gf3e43910-1
                          ktimer23.04.0.r596.g5430a02-123.04.2.r596.g5430a02-1
                           ktnef23.04.1.r816.g405852e-123.04.2.r817.g04882d2-1
                        ktorrent23.04.0.r2990.g519d9ec6-123.04.2.r2994.g1b0408e0-1
                          ktouch23.04.1.r2269.gd0a1621-123.04.2.r2273.gd2d25550-1
                           ktrip23.01.0.r26.g1befab2-123.01.0.r30.g0122db5-1
                      ktuberling23.04.1.r1163.g9378253-123.04.2.r1163.g9378253-1
                         kturtle23.04.1.r1273.gb6e55e2-123.04.2.r1274.g0ebcf61-1
                         kubrick23.04.1.r490.ge5163ce-123.04.2.r491.gb6c8628-1
                  kwalletmanager23.04.0.r1464.g6a4a01b-123.04.2.r1464.g6a4a01b-1
                           kwave23.04.0.r3882.g8e97359f-123.04.2.r3883.g2a03ba6d-1
                        kwayland5.106.0.r1212.g25e86ba-15.106.0.r1213.g6f31cb0-1
                  kwidgetsaddons5.106.0.r1097.g64c59987-15.106.0.r1098.ga70ee848-1
                            kwin5.27.5.r24236.g5a9cfe174a-15.27.5.r24241.g3cf71114cb-1
                       kwordquiz23.04.1.r1319.g5ffc9f9-123.04.2.r1320.g73a22e3-1
                          kwrite23.04.0.r20721.gd208dfe5a-123.04.2.r20730.geefd3ba2d-1
                         kxmlgui5.106.0.r1006.g52234202-15.106.0.r1007.gb507bcd9-1
                      libakonadi23.04.1.r13076.g84e914c45-123.04.2.r13076.g84e914c45-1
                     libgravatar23.04.1.r519.gb7fcd18-123.04.2.r519.gb7fcd18-1
                        libkcddb23.04.1.r850.g0c12974-123.04.2.r851.ga26e08a-1
                 libkcompactdisc23.04.1.r437.g16014b8-123.04.2.r437.g16014b8-1
                       libkdcraw23.04.1.r1160.g580849c-123.04.2.r1160.g580849c-1
                     libkdegames23.04.1.r2335.g052d0506-123.04.2.r2336.gd8f0a978-1
                       libkdepim23.04.1.r1005.g73e26e7-123.04.2.r1005.g73e26e7-1
              libkeduvocdocument23.04.1.r1857.g1f4c062-123.04.2.r1857.g1f4c062-1
                       libkexiv223.04.1.r843.g68c21bb-123.04.2.r843.g68c21bb-1
                        libkgapi23.04.1.r1575.ge3db7440-123.04.2.r1575.ge3db7440-1
                         libkipi23.04.1.r1289.g8cacdbb-123.04.2.r1289.g8cacdbb-1
                         libkleo23.04.1.r1528.g7f9e67d-123.04.2.r1530.gdfe3d6b-1
                    libkmahjongg23.04.1.r532.g735eefe-123.04.2.r532.g735eefe-1
                 libkomparediff223.04.1.r406.ge391412-123.04.2.r406.ge391412-1
                        libksane23.04.1.r657.g70a8a78-123.04.2.r657.g70a8a78-1
                       libksieve23.04.1.r1911.gb2d65ed4-123.04.2.r1912.g9c6669e6-1
                     libktorrent23.04.1.r604.g5eb5b48-123.04.2.r604.g5eb5b48-1
                        lokalize23.04.0.r2041.gf1d105e8-123.04.2.r2042.g8fbd5973-1
                           lskat23.04.1.r935.g9ea5ee9-123.04.2.r935.g9ea5ee9-1
                      mailcommon23.04.1.r1490.g5da6718-123.04.2.r1491.g3eaf59e-1
                    mailimporter23.04.1.r628.g18495f3-123.04.2.r628.g18495f3-1
                          marble23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
                   marble-common23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
                       marble-qt23.04.1.r13685.g579881495-123.04.2.r13688.gc59f6e9c3-1
                    markdownpart23.04.0.r208.g3c2e1ad-123.04.2.r208.g3c2e1ad-1
                         mauikit 3.0.0.r5.gf252a3be-1 3.0.0.r6.g41bf0289-1
            mauikit-filebrowsing 2.2.2.r53.g41625fa-1 2.2.2.r54.g0550cee-1
                   mbox-importer23.04.0.r651.g97d40f2-123.04.2.r651.g97d40f2-1
                      messagelib23.04.1.r7166.g516798438-123.04.2.r7168.gee6a11b8f-1
                          minuet23.04.1.r700.gfe37472-123.04.2.r700.gfe37472-1
                         neochat23.01.0.r424.gb5c781212-123.01.0.r446.g7c75a2fd0-1
                          okular23.04.1.r10109.g57f5c6933-123.04.2.r10118.gd78752ea3-1
                          oxygen5.27.5.r4586.g91d4055f-15.27.5.r4588.g4b77ceb9-1
                        palapeli23.04.1.r1396.g8e47257-123.04.2.r1396.g8e47257-1
                          parley23.04.1.r4622.g5ab4330b-123.04.2.r4622.g5ab4330b-1
                partitionmanager23.04.0.r1810.g58e6465-123.04.2.r1810.g58e6465-1
                           picmi23.04.1.r640.gcf33236-123.04.2.r640.gcf33236-1
               pim-data-exporter23.04.0.r2921.gfe05d2a1-123.04.2.r2921.gfe05d2a1-1
                pim-sieve-editor23.04.0.r1786.gca81f38-123.04.2.r1786.gca81f38-1
                       pimcommon23.04.0.r2111.ge11b2f04-123.04.2.r2112.g65d25789-1
                   plasma-camera  1.0.r173.g9972dc5-1  1.0.r175.gaa98c44-1
                  plasma-desktop5.27.5.r10256.g344a69a38-15.27.5.r10260.g30bf5d7d7-1
                 plasma-firewall5.27.5.r737.g4a94a16-15.27.5.r738.g4be5574-1
                   plasma-mobile5.27.5.r2229.g8de183099-15.27.5.r2231.g5f81c766d-1
                plasma-mobile-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
                       plasma-nm5.27.5.r3616.g6d6314e9-15.27.5.r3617.gdf2d73b9-1
                       plasma-pa5.27.5.r1235.g5a5d6b8-15.27.5.r1236.g6282ef8-1
                plasma-phonebook23.01.0.r65.g93c377b-123.01.0.r69.g4c89eef-1
                      plasma-sdk5.27.5.r2514.gcb01a3dc-15.27.5.r2517.gfd4eb174-1
            plasma-systemmonitor5.27.5.r736.g4a23fb6-15.27.5.r738.g009565c-1
                    plasma-vault5.27.5.r451.gf48f354-15.27.5.r452.gc5577ab-1
          plasma-wayland-session5.27.5.r13443.g6de6467f1-15.27.5.r13450.g3672104c7-1
                plasma-workspace5.27.5.r13443.g6de6467f1-15.27.5.r13450.g3672104c7-1
                      powerdevil5.27.5.r2737.gb6aea53e-15.27.5.r2741.g7740e71c-1
                           poxml23.04.0.r290.ge730008-123.04.2.r290.ge730008-1
                   print-manager23.04.0.r1280.g3f40324-123.04.2.r1280.g3f40324-1
                     qcachegrind23.04.0.r1278.g5cbbd88-123.04.2.r1281.gbf373a0-1
                            rocs23.04.1.r3193.g2e016f81-123.04.2.r3193.g2e016f81-1
                            sddm0.19.0.r230.g9a07cf0-10.19.0.r231.g40250a6-1
        signon-kwallet-extension23.04.1.r85.g2d8eb31-123.04.2.r85.g2d8eb31-1
                        spacebar23.01.0.r69.g1c98873-123.01.0.r70.gb07b3fa-1
                       spectacle23.04.1.r1759.g862d435-123.04.2.r1761.g8e3afdd-1
                            step23.04.1.r1338.g8d3252b-123.04.2.r1338.g8d3252b-1
                         svgpart23.04.1.r286.g152c942-123.04.2.r286.g152c942-1
                         sweeper23.04.0.r645.g61bef39-123.04.2.r645.g61bef39-1
             syntax-highlighting5.106.0.r2149.gb1306e94-15.106.0.r2150.gef98ada2-1
      telepathy-kde-accounts-kcm23.04.0.r1266.g8bb97ee-123.04.2.r1267.g06f990b-1
          telepathy-kde-approver23.04.0.r336.ge5115f0-123.04.2.r336.ge5115f0-1
      telepathy-kde-auth-handler23.04.0.r317.gfbadbdc-123.04.2.r317.gfbadbdc-1
           telepathy-kde-call-ui23.04.0.r483.gc3f00a3-123.04.2.r483.gc3f00a3-1
  telepathy-kde-common-internals23.04.1.r2075.g4f5cb39-123.04.2.r2075.g4f5cb39-1
      telepathy-kde-contact-list23.04.0.r1137.g995a78f-123.04.2.r1137.g995a78f-1
    telepathy-kde-contact-runner23.04.0.r295.g52d80fe-123.04.2.r295.g52d80fe-1
   telepathy-kde-desktop-applets23.04.0.r1038.ge6891d9-123.04.2.r1038.ge6891d9-1
telepathy-kde-filetransfer-handler23.04.0.r257.gacf7572-123.04.2.r257.gacf7572-1
telepathy-kde-integration-module23.04.0.r438.gd9df304-123.04.2.r438.gd9df304-1
telepathy-kde-send-file23.04.0.r270.gf28ca8f-123.04.2.r270.gf28ca8f-1
telepathy-kde-text-ui23.04.0.r2106.g5f3cd61d-123.04.2.r2106.g5f3cd61d-1
umbrello23.04.0.r8678.ga686a0a74-123.04.2.r8679.gde006014d-1
vakzination23.01.0.r73.g6038668-123.01.0.r74.g7ce6f4c-1
vvave 3.0.0.r7.g6f9bed1-1 3.0.0.r8.g26b46cd-1
xdg-desktop-portal-kde5.27.5.r708.gbc247f6-15.27.5.r709.g9053e1f-1
yakuake23.04.0.r969.g89321fe-123.04.2.r970.gb23b734-1
zeroconf-ioslave23.04.0.r394.gd86416e-123.04.2.r394.gd86416e-1
## Testers needed on arm-testing branch
* Run this command to switch branch: `sudo pacman-mirrors -aS testing && sudo pacman -Syyu`. This will generate a new mirrorlist for you, sync your databases with the new mirror and update your system using the arm-testing branch.
We would then love for you to give feedback in our update posts in #arm:testing-updates. That way we can better find and fix bugs, before they hit arm-stable branch. Thank you!
[poll type=regular]
- No issue, everything went smoothly
- Yes there was an issue. I was able to resolve it myself. (Please post your solution)
- Yes i am currently experiencing an issue due to the update. (Please post about it)
[/poll]
- [Mirror-Check Service](https://repo.manjaro.org/)
2) any time you launch waydroid, run the following after it has started:
echo “ip route add default via 192.168.250.1” |sudo waydroid shell
There are still 4 KDE packages that I had to manually remove for the update to proceed:
  • 3 no longer used libraries: kdav2, kimap2, sink – those are no longer used by anything on my system, so were safe to remove. I believe Kube still uses those, but Manjaro do not ship Kube (it is only in AUR and orphaned there) and AIUI it is not ready to be shipped (and might never be), so those libraries being no longer maintained should not be an issue.
  • 1 application: vakzination – looks like this is no longer maintained? At least Austria does not issue those health certificates anymore (at least currently), so I guess I can do fine without this application, but I am not not sure how other countries handle this. In principle, the file formats allow for all sorts of vaccinations, recoveries and tests to be encoded, not just Covid19, but if governments no longer use these health certificate formats, the application is not of much use anymore.
Update: The update appears to work, mostly. I had to readd my favorites to the (Folio, I still prefer that over Halcyon) homescreen (to the bottom bar), they were somehow forgotten by the update. And I have found one regression so far, reported upstream: https://bugs.kde.org/show_bug.cgi?id=478121 (Elisa mobile UI: playlist drawer cannot be closed anymore).
@Kevin_Kofler here is a new Plamo image for the pinephones for testing: Release Beta 15 RC6 · manjaro-pinephone/plasma-mobile · GitHub
SDDM can not start lxqt-1.4 wayland-session, how to make it work?
I’m interested in arm testing. Do I need to run a particular desktop environment or does it matter?
Well, I would say it depends on what you want to test. If there is a call to test a specific desktop environment (such as the call above to test the Plasma Mobile images for the PinePhone and/or PinePhone Pro), obviously you should test with that one. But I am sure all desktop environments could use some general testing. Best on the testing or even unstable branch, so that you catch regressions before they reach stable.
(In case you wonder, no, I have not gotten around to testing the new images so far. I did upgrade my production installation to the latest updates and, as reported above, that seems to be working well, except for the Elisa regression and the no longer installable Vakzination app. But I have not yet tested the images as such.)
Thanks. I had to remove kpeoplesink as well, after which I could install the updates (FWIW: I never tried to get the 2023-11-15 updates installed after I saw the KDE dependencies were broken and no fix was reported yet, didn’t have time to dig into it at that point).
Actually had to remove peruse as well, as it blocked removing baloo, kconfig, kiconthemes, knewstuff and plasma-framework, but that’s from extra (I only installed it to test it a bit but haven’t used it since anyway).
Can we please have an elisa-qtmm build with this regression fix:
applied?
I pushed a rebuild including the patch to stable. The updated version will land in unstable …
@Kevin_Kofler can you be more specific what the issue with Vakzination is?
Hi,
Thanks a lot to the dev for their hard work !
@manjaroarmteam @spikerguy
Some kde graphic bugs are solved with this up date.
Feedback => kde, Odroid devices, Manjaro arm stable branch.
Odroid c2
up date => ok
built image and boot => ok
Odroid c4
up date => ok
Odroid n2
up date => ok
Odroid m1
up date => ok
Enjoy !
post scriptum : firefox and linux are growing up in November 2023
[kevin@plasma-mobile ~]$ sudo pacman -Sy vakzination
[sudo] password for kevin:
 mobile                946.0   B  3.00 KiB/s 00:00 [######################] 100%
 core                  262.3 KiB  1093 KiB/s 00:00 [######################] 100%
 extra                   9.2 MiB  1638 KiB/s 00:06 [######################] 100%
 community              29.0   B  1812   B/s 00:00 [######################] 100%
resolving dependencies...
warning: cannot resolve "ki18n", a dependency of "vakzination"
warning: cannot resolve "kconfig", a dependency of "vakzination"
warning: cannot resolve "prison", a dependency of "vakzination"
:: The following package cannot be upgraded due to unresolvable dependencies:
      vakzination
:: Do you want to skip the above package for this upgrade? [y/N]
:: unable to satisfy dependency 'ki18n' required by vakzination
:: unable to satisfy dependency 'kconfig' required by vakzination
:: unable to satisfy dependency 'prison' required by vakzination
(Note that it says “cannot be upgraded”, but there is actually no previous version installed, because I had to uninstall it to be able to upgrade the rest of the system, due to the same dependency issue.)
The community repo hasn’t existed for some time; it has been merged with extra; unless there is a separate ARM community repo I’m not aware of.
In any case, the point; it looks like you may have missed a few .pacnew files. You might want to follow up on that. Cheers.
The community repo is empty. (As you can see, the metadata is only 29 bytes.) That is not the issue here.
I didn’t suggest it was. However, this is probably something you should pay some attention to.
Even the pacman.conf.pacnew still lists the community repository. What has been removed is the mobile repository, which (looking at a mirror) contains only one package, maui-migration-0.1-1-any.pkg.tar.zst. I do not see any other relevant changes.
community and mobile repos are depreciated. Those can be removed from pacman.conf. vakzination got a rebuild to fix dependency issues due to KF renames.
I have done that now.
OK, thanks.
Minor issue:
jdk-openjdk and jre-openjdk conflict.
work-around was manually removing jdk-openjdk. Then pacman complains about jre-openjdk-headless, manually upgrading jre-openjdk solves that.
