Has anyone been successful in using the print-to-fax command for HP printers?
I have an HP Officejet Pro 6830 printer.
On Windows, I use the HP Universal Fax Driver. It allows me, for instance, to open a PDF document in the PDF reader of my choice, and send it straight to a fax number, via a print command, without needing to physically print up the doc and feed it into the printer.
I tried on Ubuntu to do this, without success, and my local Ubuntu guru couldn’t get it to work, either.
Can I do this on Manjaro? Sounds like a minor thing, but if you send hundreds of pages of faxes, it becomes a big thing.
