I’ve found this case on Launchpad which sounds quite similar: Bug #1712019 “Driverless printing only prints a blank sheet 17.1...” : Bugs : cups package : Ubuntu
From there i found some hints how to generate additional information, which might help:
~ driverless ✔
ipps://HP%20Color%20LaserJet%20MFP%20M277n%20(C06DC7)._ipps._tcp.local/
~ lpstat -v ✔
Gerät für Hewlett-Packard_HP_Color_LaserJet_MFP_M277n: dnssd://HP%20Color%20LaserJet%20MFP%20M277n%20(C06DC7)._ipp._tcp.local/?uuid=564e424b-4b35-334b-3731-3c5282c06dc7
~ ipptool -tv "ipps://HP%20Color%20LaserJet%20MFP%20M277n%20(C06DC7)._ipps._tcp.local" get-printer-attributes.test 1 ✘
"/usr/share/cups/ipptool/get-printer-attributes.test":
Get-Printer-Attributes:
attributes-charset (charset) = utf-8
attributes-natural-language (naturalLanguage) = en
printer-uri (uri) = ipps://NPIC06DC7.local:443/ipp/print
requested-attributes (1setOf keyword) = all,media-col-database
Get printer attributes using get-printer-attributes [PASS]
RECEIVED: 900918 bytes in response
status-code = successful-ok (successful-ok)
printer-uri-supported (1setOf uri) = ipp://NPIC06DC7.local:631/ipp/print,ipps://NPIC06DC7.local:443/ipp/print
uri-security-supported (1setOf keyword) = none,tls
uri-authentication-supported (1setOf keyword) = requesting-user-name,requesting-user-name
printer-name (nameWithoutLanguage) = NPIC06DC7
printer-location (textWithoutLanguage) =
printer-more-info (uri) = https://NPIC06DC7.local:443/hp/device/info_config_AirPrint.html?tab=Networking&menu=AirPrintStatus
printer-info (textWithoutLanguage) = HP Color LaserJet MFP M277n
printer-make-and-model (textWithoutLanguage) = HP Color LaserJet MFP M277n
printer-state (enum) = idle
printer-state-reasons (keyword) = none
ipp-versions-supported (1setOf keyword) = 1.0,1.1,2.0
ipp-features-supported (keyword) = airprint-1.4
operations-supported (1setOf enum) = Print-Job,Print-URI,Validate-Job,Create-Job,Send-Document,Send-URI,Cancel-Job,Get-Job-Attributes,Get-Jobs,Get-Printer-Attributes,Identify-Printer
multiple-document-jobs-supported (boolean) = false
multiple-operation-time-out (integer) = 120
multiple-operation-time-out-action (keyword) = abort-job
charset-configured (charset) = utf-8
charset-supported (1setOf charset) = utf-8,us-ascii
natural-language-configured (naturalLanguage) = en
generated-natural-language-supported (naturalLanguage) = en
document-format-default (mimeMediaType) = application/pdf
document-format-supported (1setOf mimeMediaType) = image/urf,application/pdf,application/postscript,application/vnd.hp-PCL,application/vnd.hp-PCLXL,application/PCLm,application/octet-stream,image/jpeg
reference-uri-schemes-supported (1setOf uriScheme) = http,https
printer-is-accepting-jobs (boolean) = true
queued-job-count (integer) = 0
pdl-override-supported (keyword) = attempted
printer-up-time (integer) = 561735
compression-supported (keyword) = none
color-supported (boolean) = true
page-ranges-supported (boolean) = true
job-creation-attributes-supported (1setOf keyword) = copies,finishings,sides,orientation-requested,media,print-quality,printer-resolution,output-bin,media-col,output-mode,ipp-attribute-fidelity,job-name,page-ranges,multiple-document-handling,pdf-fit-to-page,print-scaling,print-color-mode,print-content-optimize,manual-duplex-sheet-count,margins-pre-applied,pclm-source-resolution
media-supported (1setOf keyword) = na_letter_8.5x11in,na_legal_8.5x14in,na_executive_7.25x10.5in,na_foolscap_8.5x13in,na_oficio_8.5x13.4in,na_index-4x6_4x6in,na_index-5x8_5x8in,iso_a4_210x297mm,iso_a5_148x210mm,iso_a6_105x148mm,jis_b5_182x257mm,jis_b6_128x182mm,om_small-photo_100x150mm,prc_16k-195x270_195x270mm,prc_16k-184x260_184x260mm,roc_16k_7.75x10.75in,jpn_hagaki_100x148mm,jpn_oufuku_148x200mm,na_number-10_4.125x9.5in,na_monarch_3.875x7.5in,iso_b5_176x250mm,iso_c5_162x229mm,iso_dl_110x220mm,custom_min_3x5in,custom_max_8.5x14in
media-size-supported (1setOf collection) = {x-dimension=21590 y-dimension=27940},{x-dimension=21590 y-dimension=35560},{x-dimension=18415 y-dimension=26670},{x-dimension=21590 y-dimension=33020},{x-dimension=21590 y-dimension=34036},{x-dimension=10160 y-dimension=15240},{x-dimension=12700 y-dimension=20320},{x-dimension=21000 y-dimension=29700},{x-dimension=14800 y-dimension=21000},{x-dimension=10500 y-dimension=14800},{x-dimension=18200 y-dimension=25700},{x-dimension=12800 y-dimension=18200},{x-dimension=10000 y-dimension=15000},{x-dimension=19500 y-dimension=27000},{x-dimension=18400 y-dimension=26000},{x-dimension=19685 y-dimension=27305},{x-dimension=10000 y-dimension=14800},{x-dimension=14800 y-dimension=20000},{x-dimension=10477 y-dimension=24130},{x-dimension=9842 y-dimension=19050},{x-dimension=17600 y-dimension=25000},{x-dimension=16200 y-dimension=22900},{x-dimension=11000 y-dimension=22000},{x-dimension=7620-21590 y-dimension=12700-35560}
media-default (keyword) = iso_a4_210x297mm
media-col-supported (1setOf keyword) = media-size,media-top-margin,media-left-margin,media-right-margin,media-bottom-margin,media-type,media-source,media-source-properties,duplex-supported
media-col-default (collection) = {media-size={x-dimension=21000 y-dimension=29700} media-top-margin=423 media-bottom-margin=423 media-left-margin=423 media-right-margin=423 media-source=auto media-type=stationery duplex-supported=0}
media-col-database (1setOf collection) = media-ready (keyword) = iso_a4_210x297mm
media-col-ready (collection) = {media-size={x-dimension=21000 y-dimension=29700} media-top-margin=423 media-bottom-margin=423 media-left-margin=423 media-right-margin=423 media-source=tray-1 media-type=stationery duplex-supported=0}
media-left-margin-supported (integer) = 423
media-right-margin-supported (integer) = 423
media-top-margin-supported (integer) = 423
media-bottom-margin-supported (integer) = 423
media-source-supported (1setOf keyword) = auto,manual,tray-1,tray-2
printer-input-tray (1setOf octetString) = type=other;mediafeed=-2;mediaxfeed=-2;maxcapacity=-2;level=-2;status=0;name=auto;,type=sheetFeedManual;mediafeed=297000;mediaxfeed=210000;maxcapacity=1;level=-2;status=0;name=manual;,type=sheetFeedAutoNonRemovableTray;mediafeed=297000;mediaxfeed=210000;maxcapacity=1;level=-2;status=0;name=tray-1;,type=sheetFeedAutoNonRemovableTray;mediafeed=-2;mediaxfeed=-2;maxcapacity=150;level=-2;status=0;name=tray-2;
media-type-supported (1setOf nameWithoutLanguage) = stationery,HPMatte90gsm,HPMatte105gsm,HPMatte120gsm,HPMatte160gsm,HPCover,HPGlossy130gsm,photographic-glossy,HPTrifoldGlossy160gsm,HPGlossyPhoto,stationery-lightweight,extraLight,intermediate,midweight,stationery-heavyweight,extraHeavy,photographic-high-gloss,extraHeavyGloss,cardGlossy,transparency,labels,stationery-letterhead,envelope,envelope-heavyweight,stationery-preprinted,stationery-prepunched,stationery-colored,stationery-bond,recycled,rough,heavyRough,photographic-film
pages-per-minute (integer) = 19
pages-per-minute-color (integer) = 19
jpeg-k-octets-supported (rangeOfInteger) = 0-11719
jpeg-x-dimension-supported (rangeOfInteger) = 0-8192
jpeg-y-dimension-supported (rangeOfInteger) = 1-8192
pdf-k-octets-supported (rangeOfInteger) = 0-75000
pdf-versions-supported (1setOf keyword) = adobe-1.2,adobe-1.3,adobe-1.4,adobe-1.5,adobe-1.6,adobe-1.7,iso-19005-1_2005,iso-32000-1_2008
urf-supported (1setOf keyword) = V1.4,CP99,W8,OB10,PQ3-4-5,ADOBERGB24,DEVRGB24,DEVW8,SRGB24,IS1,MT1-2-3-5-12,RS600
printer-uuid (uri) = urn:uuid:564e424b-4b35-334b-3731-3c5282c06dc7
marker-names (1setOf nameWithoutLanguage) = Cyan Cartridge HP CF401X,Magenta Cartridge HP CF403X,Yellow Cartridge HP CF402X,Black Cartridge HP CF400X
marker-colors (1setOf nameWithoutLanguage) = #00FFFF,#FF00FF,#FFFF00,#000000
marker-types (1setOf keyword) = toner,toner,toner,toner
marker-low-levels (1setOf integer) = 3,3,3,3
marker-high-levels (1setOf integer) = 100,100,100,100
marker-levels (1setOf integer) = 81,7,85,98
copies-default (integer) = 1
multiple-document-handling-default (keyword) = single-document
finishings-default (enum) = none
orientation-requested-default (enum) = portrait
print-quality-default (enum) = normal
printer-resolution-default (resolution) = 600dpi
sides-default (keyword) = one-sided
output-bin-default (keyword) = face-down
output-mode-default (keyword) = auto
copies-supported (rangeOfInteger) = 1-999
multiple-document-handling-supported (1setOf keyword) = single-document,separate-documents-uncollated-copies,separate-documents-collated-copies,single-document-new-sheet
finishings-supported (enum) = none
orientation-requested-supported (1setOf enum) = portrait,landscape,reverse-landscape,reverse-portrait,none
print-quality-supported (1setOf enum) = normal,draft
printer-resolution-supported (resolution) = 600dpi
sides-supported (keyword) = one-sided
job-impressions-supported (rangeOfInteger) = 1-99999
job-media-sheets-supported (rangeOfInteger) = 1-99999
output-bin-supported (keyword) = face-down
printer-output-tray (octetString) = type=unRemovableBin;maxcapacity=125;remaining=-3;status=0;name=face-down;stackingorder=firstToLast;pagedelivery=faceDown;
output-mode-supported (1setOf keyword) = auto,auto-monochrome,monochrome,color
printer-icons (1setOf uri) = https://NPIC06DC7.local:443/ipp/images/printer.png,https://NPIC06DC7.local:443/ipp/images/printer-large.png
printer-supply-info-uri (uri) = https://NPIC06DC7.local:443/hp/device/mSupplyStatus.html
printer-device-id (textWithoutLanguage) = MFG:Hewlett-Packard;CMD:PJL,PML,PCLXL,URP,PCL,PDF,POSTSCRIPT;MDL:HP Color LaserJet MFP M277n;CLS:PRINTER;DES:Hewlett-Packard Color LaserJet MFP M277n;MEM:MEM=214MB;COMMENT:RES=600x8;LEDMDIS:USB#ff#04#01;CID:HPLJPDLV1;IPP-E:FF-04-01,FF-04-01,FF-09-01,FF-09-01;eSCL:FF-04-01,FF-04-01,FF-09-01,FF-09-01;MCT:MF;MCL:DL;MCV:2.0;
printer-dns-sd-name (nameWithoutLanguage) = HP Color LaserJet MFP M277n (C06DC7)
printer-geo-location (unknown) = unknown
printer-kind (1setOf keyword) = document,envelope,photo
landscape-orientation-requested-preferred (enum) = 5
identify-actions-default (keyword) = display
identify-actions-supported (keyword) = display
print-scaling-default (keyword) = auto
print-scaling-supported (1setOf keyword) = auto,auto-fit,fill,fit,none
printer-firmware-name (nameWithoutLanguage) = 20180205
printer-firmware-string-version (textWithoutLanguage) = 20180205
printer-firmware-version (octetString) = 20180205
which-jobs-supported (1setOf keyword) = completed,not-completed
printer-organization (textWithoutLanguage) =
printer-organizational-unit (textWithoutLanguage) =
printer-get-attributes-supported (keyword) = document-format
epcl-version-supported (keyword) = epcl1.0
image-enhancement-supported (keyword) = object-tagging
manual-duplex-supported (1setOf boolean) = false,true
pclm-raster-back-side (keyword) = normal
pclm-compression-method-preferred (keyword) = flate
pclm-source-resolution-supported (resolution) = 600dpi
pclm-strip-height-preferred (integer) = 64
pclm-strip-height-supported (1setOf integer) = 16,32,64,128
pdf-fit-to-page-default (boolean) = false
pdf-fit-to-page-supported (1setOf boolean) = false,true
pdf-size-constraints (integer) = 75000000
print-color-mode-default (keyword) = auto
print-color-mode-supported (1setOf keyword) = auto,auto-monochrome,monochrome,color
print-content-optimize-default (keyword) = auto
print-content-optimize-supported (1setOf keyword) = auto,photo,graphics,text,text-and-graphics
