HP Laser MFP 135w won’t print more than one copy of a document
Hello everyone. My HP Laser MFP 135w device fails to print more than one copy of a document, even when I specify multiple copies in the print settings. Everything works correctly when using Windows. Could you please advise on how to configure the printer to produce multiple copies?
Waiting for someone to blindly ask questions is also counter-productive – typically, nobody has a
at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
While information from *-fetch type apps might be fine for someone wishing to buy your computer, for Support purposes it’s better to ask your system directly; ![]()
inxi --filter --verbosity=8
inxi -zv8
- inxi man pages (Arch Manual)
This would seem beyond the scope of user to user help on this forum, unless someone happened to own your exact printer model.
If there might be a problem with the driver, HP Support may be helpful, however (to me) it seems likely to be a configuration problem.
Perhaps some of these links may be useful:
https://support.hp.com/au-en/product/troubleshooting/hp-laser.../24494382
This is very likely associated with the libcupsfilters problem in Stable Update 2026-09-07. Along with the inability to print multiple copies, you might also have problems printing landscape. I did. There were a number of posts about it leading up to this one by @Rmano which should lead you in the right direction. Downgrading using manjaro-downgrade to libcupsfilters ver 2.1.1-4 fixed it for me.
My partner’s system had a similar problem printing multiple pages on Epson Stylus Office BX535WD inkjet printer.
LibreOffice Writer print dialog shows Collate option is enabled but greyed out and cannot be disabled.
Switched to testing branch and updated to include libcupsfilters 2.2.1.r28.gce65eb74-1
Update created a .pacnew file /etc/cups/cupsd.conf.pacnew – merged with /etc/cups/cupsd.conf
LibreOffice print dialog now shows the Collate option is not enabled or greyed out,
and printer can now print more than one copy of a text document
As far as I can see there is a HP driver for Linux available for this printer:
https://support.hp.com/us-en/drivers/closure/hp-laser-mfp-130-printer-series/model/24494382
How to install (if downloaded to ~/Downloads):
$ cd ~/Downloads
$ tar -xvzf uld-hp_V1.00.39.12_00.15.tar.gz
$ cd uld-hp
$ chmod +x install.sh
$ sudo ./install.sh
If the installation script does not run, ensure you are in the correct directory and that the script is executable.
Already done. Guess the problem is libcupsfilters, not to the printer driver. Please fix it on next major distributive update
