ClockworkPI DevTerm does not recognize wifi adapter MT7612u
ClockworkPI DevTerm does not recognize wifi adapter MT7612u can this be fixed? thanks
  1. This is not the Wifi module the Clockwork Pi comes with, so it’s not expected to work.
  2. Does that chipset have support in the mainline linux kernel?
  3. If it does, what’s the config option to enable it?
Mediatek usb mt7601u doesn’ t work either. Maybe is all related.
I’m using a Netgear A6210 wifi adapter
Works fine on manjaro or kali on some systems
My current installation is Dev 20220725 Manjaro-ARM-kde-plasma-clockworkpi-a06-20220725.img.xz on github
