Been using it for a year now and absolutely love it, just drag and drop ISOs to the stick. Even works with Windows ISOs. Couldn’t be easier.
does this work with other os as well
i just did it on a vfat usb and it went fine plus the verification,
how come my USB appears to be empty in Dolphin and says 14GIB free of 14 GIB?
fdisk -l
shows the ISO.
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 64 7469523 7469460 3.6G 0 Empty
/dev/sda2 7469524 7477715 8192 4M ef EFI (FAT-12/16/32)
Edit
after a reboot the USB showed as Manjaro…
A post was split to a new topic: How to install imagewriter?
You might want to add somewhere between steps 4 and 6 :
“open a terminal and cd to where you downloaded the disc image”
If that is really needed
to try and make it even more fool proof
then that has to be done in between step 1 and 2
… else the checksum verification would not work
paths and path names and orientation, where you are and how to get from there to somewhere else, can be a bit challenging, yes
but go to that level? come on …
where did i find the *.sha1 (the checksum file)? On manjaro.org/download/ i find the *.iso only.
Under the download page, ex:
Click on “More” and there you can download the Signature and/or the sha256 Checksum.
The guide will need to be updated to reflect the use of sha256
But the process is the same - simply replace sha1
with sha256
, and run, ex: sha256sum
Thanks
wget https://download.manjaro.org/xfce/24.1.0/manjaro-xfce-24.1.0-241001-linux610.iso.sha256
but it doesn’t work:
$ sha1sum -c manjaro-xfce-24.1.0-241001-linux610.iso.sha256
sha1sum: manjaro-xfce-24.1.0-241001-linux610.iso.sha256: keine korrekt formatierte Prüfsummenzeile gefunden
You would need to use sha256sum
The guide has also been updated.
Thanks it works
