[HowTo] Troubleshooting locale errors
Difficulty: ★☆☆☆☆
Locale error message
From my notepad
When you get errors like below - it is not obvious what causes it
$ rofi
(process:1628): Rofi-WARNING **: 07:34:43.942: Failed to set locale.
Check your settings
:information_source: Obviously you need to replace the locale with something relevant for your system. I have written this using my system’s locale - en_DK for messages and da_DK for the rest of the system.
Check locale settings
$ localectl
   System Locale: LANG=en_DK.UTF-8
                  LC_NUMERIC=da_DK.UTF-8
                  LC_TIME=da_DK.UTF-8
                  LC_MONETARY=da_DK.UTF-8
                  LC_PAPER=da_DK.UTF-8
                  LC_NAME=da_DK.UTF-8
                  LC_ADDRESS=da_DK.UTF-8
                  LC_TELEPHONE=da_DK.UTF-8
                  LC_MEASUREMENT=da_DK.UTF-8
                  LC_IDENTIFICATION=da_DK.UTF-8
       VC Keymap: dk-latin1
      X11 Layout: dk
       X11 Model: pc105
Check installed locales
$ locale -a
C
en_DK.utf8
en_US.utf8
POSIX
The installed locales does not match the settings listed by localectl - as you can see the da_DK part is missing.
Fix locale error
It is recommended to use the utf8 version unless you have compelling reasons to select otherwise.
Method 1
Edit /etc/locale.gen and ensure that all in-use locales has been uncommented. For fallback messages enable en_US as well
$ sudo nano /etc/locale.gen
#cy_GB ISO-8859-14
da_DK.UTF-8 UTF-8
#da_DK ISO-8859-1
#en_CA ISO-8859-1
en_DK.UTF-8 UTF-8
#en_DK ISO-8859-1
#en_SG ISO-8859-1
en_US.UTF-8 UTF-8
#en_US ISO-8859-1
Method 2
Based on the comment by @nam1962 (see below).
Check if the locale you want to use is available in the locale list (/etc/locale.gen)
$ cat /etc/locale.gen | grep 'da_DK'
#da_DK.UTF-8 UTF-8
#da_DK ISO-8859-1
Use sed command
  • To enable a locale (uncommenting the line)
    $ sudo sed -i '/en_DK.UTF-8/s/^#//g' /etc/locale.gen
    $ sudo sed -i '/en_US.UTF-8/s/^#//g' /etc/locale.gen
  • To disable a locale (aka commenting the locale)
    $ sudo sed -i '/en_DK.UTF-8/s/^/#/g' /etc/locale.gen
Rebuild locales
$ sudo locale-gen
Generating locales...
  da_DK.UTF-8... done
  en_DK.UTF-8... done
  en_US.UTF-8... done
Generation complete.
Recheck your locales
$ locale -a
C
da_DK.utf8
en_DK.utf8
en_US.utf8
POSIX
Verify it works
➜  ~ rofi -r
Rofi is unsure what to show.
Please specify the mode you want to show.
    rofi -show {mode}
The following modi are enabled:
 * window
 * run
 * ssh
The following can be enabled:
 * windowcd
 * drun
 * combi
 * keys
To activate a mode, add it to the list of modi in the modi setting.
Now it is fixed
Enjoy
Moved to #contributions:Tutorials so it appears at the top instead of all the way at the bottom of #contributions
I have french user I installed, they don’t even know nano exists.
Thus I told them :
sudo sed -i '/fr_FR.UTF-8/s/^#//g' /etc/locale.gen
sudo locale-gen
For other languages, just replace fr_FR with the proper locale
[Edit] to reverse & comment out :
sed -i '/fr_FR.UTF-8/s/^/#/g' /etc/locale.gen
with the proper locale :wink:
Nice idea - I will add it to the guide :slight_smile: thank you.
Thank you for praising :wink:
By the way, my checking outcome is a little different :
[meuh@ordi1 ~]$ localectl
   System Locale: LANG=fr_FR.UTF-8
   VC Keymap: fr
  X11 Layout: fr
   X11 Model: pc105
[meuh@ordi1 ~]$ locale -a
C
en_US.utf8
fr_FR.utf8
POSIX
[meuh@ordi1 ~]$
