[HowTo] systemd mount unit samples
Difficulty: ★★☆☆☆
Example mount units for systemd
The examples here are a supplement to the guide on systemd mount units
Unit file names
Mount unit
  • Mount units must be named the mount point with the extension of .mount
    e.g. mountpoint /data/backup - unit file data-backup.mount
Automount unit
  • Automount units use the name of the mount unit but an extension of .automount
    e.g. data-backup.automount
Content of a mount unit
Depending on the Type, the What is different and so is the Options
What do you want to mount (disk, server, share)?
Where do you want it to mount (a path on your system)?
Which Type is your mount (filesystem, cifs, nfs)?
What Options should the mount use(rw, auto, netdev)?
Example
If you want to mount a Samba share named video provided by a local NAS named server
  • What is the name of server and the share e.g. //server/video
  • Where is the path where you can browse the data provided by the share e.g. /data/smb/video
  • Type will be cifs because that is what this type of connection is called
  • Options will instruct the system it is a net device _netdev, it should be possible to read and write rw, and connect using a specific workgroup, username and password.
Sample MOUNT unit for SMB share
It is also possible to store the username and password in a safe location readable only by root.
Replace the $VARIABLES with the values for your system
The package smbclient is enough.
/etc/systemd/system/data-smb-video.mount
[Unit]
Description=NAS SMB video share
After=network.target
[Mount]
What=//server/video
Where=/data/smb/video
Type=cifs
Options=_netdev,iocharset=utf8,rw,file_mode=0777,dir_mode=0777,user=$SMBUSER,password=$SMBPASS,workgroup=$WORKGROUP
TimeoutSec=30
[Install]
WantedBy=multi-user.target
NOTE: According to the archlinux wiki the uid and gid can cause I/O errors.
Warning: Using uid and/or gid as mount options may cause I/O errors, it is recommended to set/check correct File permissions and attributes instead. - Samba - ArchWiki
More information on Samba can be found on the archlinux wiki
Sample MOUNT unit for DISK device
[Type] and [Options] are optional for disk devices.
To reduce unnecessary writings to SSD devices the noatime option is recommended.
/etc/systemd/system/data-build.mount
[Unit]
Description=Mount build partition
[Mount]
What=/dev/disk/by-uuid/899b1bc4-219c-4b92-8539-0aa118d9780a
Where=/data/build
#Type=
#Options=
[Install]
Sample MOUNT unit for NFS share
/etc/systemd/system/data-nfs-video.mount
[Unit]
Description=Video
[Mount]
What=diskstation:/volume1/video
Where=/data/nfs/video
Type=nfs
Options=_netdev,auto
[Install]
Sample MOUNT unit for FTP server
Using curlftpfs
You can put the user and password in a .netrc file in the home directory of the user that executes CurlFtpFS. It can have 600 permission. It’s still clear text but at least is not accessible by all.
The format is:
machine ftp.host.com
login myuser
password mypass
curlftpfs on archlinux wiki
Replace the $VARIABLES with the actual values for your use case.
/etc/systemd/system/data-ftp-server.mount
[Unit]
Description=My FTP server (ftp.server.tld)
[Mount]
What=curlftpfs#ftp.server.tld
Where=/data/ftp/server
Type=fuse
Options=rw,nosuid,uid=$UID,gid=$GID,allow_other,user=$FTPUSER:$FTPPASS
[Install]
Sample NFS AUTOMOUNT unit
/etc/systemd/system/data-nfs-video.automount
[Unit]
Description=Automount video share
ConditionPathExists=/data/nfs/video
[Automount]
TimeoutIdleSec=10
[Install]
WEBDAV
See davfs2 - ArchWiki
Install davfs2 from the repo
Sample WEBDAV MOUNT unit
/etc/systemd/system/data-webdav-service.mount
[Unit]
Description=Mount WebDAV Service
After=network-online.target
Wants=network-online.target
[Mount]
What=http(s)://address:<port>/path
Where=/data/webdav/service
Options=rw,_netdev
Type=davfs
TimeoutSec=15
[Install]
Edit the file /etc/davfs2/secrects and append your webdav service and credentials
http(s)://address:<port>/path    davusername    "davpassword"
Or create a user file at ~/.davfs2/secrets for user specific mounts
Sample AUTOMOUNT units
Same rule applies as for mount units. It must be the path to the mountpoint with the .automount extension e.g. data-backup.automount
Network device
This is sample for webdav.
/etc/systemd/data-webdav-service.automount
[Unit]
[Automount]
Where=/data/webdav
TimeoutIdleSec=300
[Install]
WantedBy=remote-fs.target
Disk device
cat /etc/systemd/system/data-backup.automount
[Unit]
Description=Automount backup partition
ConditionPathExists=/data/backup
[Automount]
Where=/data/backup
TimeoutIdleSec=10
[Install]
