GBD.Bus.Error.org.xfce
Hallo, mein Manjaro Xfce bleibt ganz selben mal hängen. Ich habe mir die Fehlermeldung nicht ganz richtig abgeschrieben. Sie lautet in etwas so:
GDBus.Error.org.xfce.Sessionlauer.Error.Faild.
Die Sitzungsverwaltung darf nicht beschädigt sein, wenn heruntergefahren werden soll.
Danach half nur noch: Stecker ziehen und neu booten, was problemlos klappt.
Was macht man, wenn das System mal wieder hängen bleibt?
Hi @Michi,
Fair warning: I don’t speak German, so I read your post VIA google translate.
Regarding:
See [HowTo] reboot / turn off your frozen computer: REISUB/REISUO as I believe it’s what you’re looking for.
Hope this helps!
Hallo @Mirdarthos
Thank you for your help.
I have looked at the link. This is much too hard for me. I’ve been away from Windows for a year and a half and love my Manjaro Linux - but it overwhelms me enormously what I would have to read and understand here.
My problem that my system stalls every few weeks or months and I can’t do anything except unplug it.
I also looked into REISUB at one time, but it never worked. Is there no “simple” solution that just works?
first provide formated info from:
inxi -Fazy
did the crash happened today? or yesterday?
it happend today
tippe ode-Manjaro ~]$ inxi -Fazy
  Kernel: 5.15.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 11.2.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
    root=UUID=04c6cf0e-5174-4f4b-805f-97eafcd89b32 rw rootflags=subvol=@ quiet
    apparmor=1 security=apparmor
    resume=UUID=b9074fff-5cfa-4c96-ad0a-746b27a87782 udev.log_priority=3
  Desktop: Xfce v: 4.16.0 tk: Gtk v: 3.24.29 info: xfce4-panel wm: xfwm
    v: 4.16.1 vt: 7 dm: LightDM v: 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: TUF Z390-PLUS GAMING v: Rev X.0x
    serial: <superuser required> UEFI: American Megatrends v: 2820
    date: 01/06/2021
  Info: model: Intel Core i7-8700K bits: 64 type: MT MCP arch: Coffee Lake
    family: 6 model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xEC
    L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
    L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4700 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 88824
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
  Type: itlb_multihit status: KVM: VMX unsupported
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    driver: i915 v: kernel ports: active: HDMI-A-2 empty: DP-1,HDMI-A-1
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0300
  Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
    X: loaded: modesetting alternate: fbdev,vesa gpu: i915 display-ID: :0.0
    screens: 1
  Screen-1: 0 s-res: 2560x1440 s-dpi: 96 s-size: 677x381mm (26.65x15.00")
    s-diag: 777mm (30.58")
  Monitor-1: HDMI-A-2 mapped: HDMI-2 model: BenQ PD2705Q serial: <filter>
    built: 2021 res: 2560x1440 hz: 60 dpi: 109 gamma: 1.2
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9 modes:
    max: 2560x1440 min: 720x400
  OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 21.3.8
    direct render: Yes
  Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel
  Sound Server-1: ALSA v: k5.15.32-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.49 running: yes
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15bc class-ID: 0200
  Local Storage: total: 5.69 TiB used: 2.96 TiB (52.0%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 type: SSD serial: <filter> rev: 1B2QEXE7 temp: 32.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital
    model: WD60EFRX-68L0BN1 size: 5.46 TiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5700 serial: <filter>
    rev: 0A82 scheme: GPT
  ID-1: / raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
    used: 24.92 GiB (36.5%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
  ID-2: /boot/efi raw-size: 500 MiB size: 499 MiB (99.80%)
    used: 568 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-3: /home raw-size: 46.38 GiB size: 45.4 GiB (97.89%)
    used: 26.73 GiB (58.9%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
  ID-4: /var/log raw-size: 68.36 GiB size: 68.36 GiB (100.00%)
  ID-1: swap-1 type: partition size: 5.86 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:5
  System Temperatures: cpu: 27.8 C mobo: N/A
  Processes: 303 Uptime: 1h 30m wakeups: 0 Memory: 15.47 GiB
  used: 6.18 GiB (39.9%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.2.0 clang: 13.0.1 Packages: apt: 0 pacman: 1461 lib: 418 flatpak: 0
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.15
r füge den Code hier ein
so you can use this command to check logs from previous boot:
journalctl --boot -1 --no-pager
I hope it’s not too much text:
tiApr 27 13:24:45 T7-Manjaro audit[68563]: USER_AUTH pid=68563 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="michae1" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro audit[68563]: USER_ACCT pid=68563 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="michae1" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro lightdm[68563]: gkr-pam: stashed password to try later in open session
Apr 27 13:24:45 T7-Manjaro kernel: kauditd_printk_skb: 4 callbacks suppressed
Apr 27 13:24:45 T7-Manjaro kernel: audit: type=1100 audit(1651058685.482:138): pid=68563 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="michae1" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro kernel: audit: type=1101 audit(1651058685.482:139): pid=68563 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="michae1" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro audit[68563]: CRED_REFR pid=68563 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="michae1" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro kernel: audit: type=1110 audit(1651058685.575:140): pid=68563 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_shells,pam_faillock,pam_permit,pam_faillock,pam_gnome_keyring acct="michae1" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro systemd[1]: Stopping Session c1 of User lightdm...
Apr 27 13:24:45 T7-Manjaro lightdm[68497]: pam_unix(lightdm-greeter:session): session closed for user lightdm
Apr 27 13:24:45 T7-Manjaro audit[68497]: USER_END pid=68497 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro audit[68497]: CRED_DISP pid=68497 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro kernel: audit: type=1106 audit(1651058685.929:141): pid=68497 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:session_close grantors=pam_unix,pam_systemd acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro kernel: audit: type=1104 audit(1651058685.929:142): pid=68497 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_env,pam_permit acct="lightdm" exe="/usr/bin/lightdm" hostname=? addr=? terminal=:1 res=success'
Apr 27 13:24:45 T7-Manjaro systemd[1]: session-c1.scope: Deactivated successfully.
Apr 27 13:24:45 T7-Manjaro systemd[1]: Stopped Session c1 of User lightdm.
Apr 27 13:24:45 T7-Manjaro systemd-logind[699]: Removed session c1.
Apr 27 13:24:56 T7-Manjaro systemd[1]: Stopping User Manager for UID 967...
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Activating special unit Exit the Session...
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped target Main User Target.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopping Accessibility services bus...
Apr 27 13:24:56 T7-Manjaro gvfsd[68540]: A connection to the bus can't be made
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopping D-Bus User Message Bus...
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopping Virtual filesystem service...
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped D-Bus User Message Bus.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped Accessibility services bus.
Apr 27 13:24:56 T7-Manjaro systemd[1]: run-user-967-gvfs.mount: Deactivated successfully.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped Virtual filesystem service.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Removed slice User Core Session Slice.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped target Basic System.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped target Paths.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped target Sockets.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Stopped target Timers.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed D-Bus User Message Bus Socket.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed GnuPG network certificate management daemon.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed GCR ssh-agent wrapper.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed GnuPG cryptographic agent and passphrase cache.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed p11-kit server.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed PipeWire Multimedia System Socket.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Closed Sound System.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Removed slice User Application Slice.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Reached target Shutdown.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Finished Exit the Session.
Apr 27 13:24:56 T7-Manjaro systemd[68501]: Reached target Exit the Session.
Apr 27 13:24:56 T7-Manjaro systemd[68502]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[lightdm] ruser=[<unknown>] rhost=[<unknown>]
Apr 27 13:24:56 T7-Manjaro systemd[1]: user@967.service: Deactivated successfully.
Apr 27 13:24:56 T7-Manjaro systemd[1]: Stopped User Manager for UID 967.
Apr 27 13:24:56 T7-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 27 13:24:56 T7-Manjaro systemd[1]: Stopping User Runtime Directory /run/user/967...
Apr 27 13:24:56 T7-Manjaro kernel: audit: type=1131 audit(1651058696.122:143): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 27 13:24:56 T7-Manjaro systemd[1]: run-user-967.mount: Deactivated successfully.
Apr 27 13:24:56 T7-Manjaro systemd[1]: user-runtime-dir@967.service: Deactivated successfully.
Apr 27 13:24:56 T7-Manjaro systemd[1]: Stopped User Runtime Directory /run/user/967.
Apr 27 13:24:56 T7-Manjaro audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 27 13:24:56 T7-Manjaro systemd[1]: Removed slice User Slice of UID 967.
Apr 27 13:24:56 T7-Manjaro kernel: audit: type=1131 audit(1651058696.128:144): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@967 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Apr 27 13:25:39 T7-Manjaro kernel: [UFW BLOCK] IN=eno1 OUT= MAC=01:00:5e:00:00:01:e0:28:6d:d9:35:d1:08:00 SRC=192.168.178.1 DST=224.0.0.1 LEN=36 TOS=0x00 PREC=0xC0 TTL=1 ID=32577 DF PROTO=2
ppe oder füge den Code hier ein
after the crash you turn your computer again and didnt reboot or turned it off and then on again?
if your pc is running uninterupted since the crash, run this command:
journalctl --boot=-1 --priority=6 --no-pager
After the crash, i.e. after the computer was frozen solid and nothing worked, I disconnected the power supply, then of course everything was off. After that, however, it booted normally.
Should I still enter the command?
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Reached target Sockets.
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Reached target Basic System.
Apr 27 13:24:38 T7-Manjaro systemd[1]: Started User Manager for UID 967.
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Starting Update XDG user dir configuration...
Apr 27 13:24:38 T7-Manjaro systemd[1]: Started Session c1 of User lightdm.
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Finished Update XDG user dir configuration.
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Reached target Main User Target.
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Startup finished in 84ms.
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Started D-Bus User Message Bus.
Apr 27 13:24:38 T7-Manjaro dbus-daemon[68531]: [session uid=967 pid=68531] Activating via systemd: service name='org.a11y.Bus' unit='at-spi-dbus-bus.service' requested by ':1.1' (uid=967 pid=68511 comm="/usr/bin/lightdm-gtk-greeter ")
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Starting Accessibility services bus...
Apr 27 13:24:38 T7-Manjaro dbus-daemon[68531]: [session uid=967 pid=68531] Successfully activated service 'org.a11y.Bus'
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Started Accessibility services bus.
Apr 27 13:24:38 T7-Manjaro dbus-daemon[68531]: [session uid=967 pid=68531] Activating via systemd: service name='org.gtk.vfs.Daemon' unit='gvfs-daemon.service' requested by ':1.3' (uid=967 pid=68511 comm="/usr/bin/lightdm-gtk-greeter ")
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Created slice User Core Session Slice.
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Starting Virtual filesystem service...
Apr 27 13:24:38 T7-Manjaro dbus-daemon[68531]: [session uid=967 pid=68531] Successfully activated service 'org.gtk.vfs.Daemon'
Apr 27 13:24:38 T7-Manjaro systemd[68501]: Started Virtual filesystem service.
Apr 27 13:24:38 T7-Manjaro polkitd[696]: <no filename>:3: action=[Action id='org.freedesktop.DisplayManager.AccountsService.ReadAny']
Apr 27 13:24:38 T7-Manjaro polkitd[696]: <no filename>:4: subject=[Subject pid=68511 user='lightdm' groups=lightdm seat='seat0' session='c1' local=true active=true]
Apr 27 13:24:38 T7-Manjaro at-spi-bus-launcher[68538]: dbus-daemon[68538]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=967 pid=68511 comm="/usr/bin/lightdm-gtk-greeter ")
Apr 27 13:24:38 T7-Manjaro at-spi-bus-launcher[68565]: dbus-daemon[68565]: writing oom_score_adj error: Permission denied
Apr 27 13:24:38 T7-Manjaro dbus-daemon[693]: [system] Activating via systemd: service name='org.freedesktop.home1' unit='dbus-org.freedesktop.home1.service' requested by ':1.209' (uid=0 pid=68563 comm="lightdm --session-child 15 22 ")
Apr 27 13:24:38 T7-Manjaro dbus-daemon[693]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.home1.service': Unit dbus-org.freedesktop.home1.service not found.
Apr 27 13:24:38 T7-Manjaro at-spi-bus-launcher[68538]: dbus-daemon[68538]: Successfully activated service 'org.a11y.atspi.Registry'
Apr 27 13:24:38 T7-Manjaro at-spi-bus-launcher[68565]: SpiRegistry daemon is running with well-known name - org.a11y.atspi.Registry
Apr 27 13:24:45 T7-Manjaro lightdm[68563]: gkr-pam: unable to locate daemon control file
yes i understand that it booted normally, but is it running since the crash constantly? so that we can run the log command the exact time the crash happened…
Yes, since the last boot the computer is running normally. I can’t remember if it was the first boot since the crash or the second. But it runs completely normal.
What should I do now?
no no, i mean how many times did you turn on your computer since the crash - that includes also reboots?
Sorry, I can’t be that specific, one, two times at the most. The crash was around 14:30
ok, so it happened 14:30, you than turned on your system, so thats 1, did you turned it off again, or rebooted, since then?
That’s the small problem, I can’t remember if I had only booted once since the crash or twice already. Is that important now?
As I said, I have not had any problems since the crash.
ok, so run this command for logs for the previous boot:
journalctl --boot=-1 --priority=5 --no-pager
run this command for the second previous boot:
journalctl --boot=-2 --priority=5 --no-pager
boot=-1
tippe oder füge den Code hier ein
boot =-2
Apr 26 23:03:38 T7-Manjaro systemd[860]: xdg-document-portal.service: Failed with result 'exit-code'.
Apr 26 23:03:38 T7-Manjaro systemd[860]: xdg-permission-store.service: Main process exited, code=exited, status=1/FAILURE
Apr 26 23:03:38 T7-Manjaro systemd[860]: xdg-permission-store.service: Failed with result 'exit-code'.
Apr 26 23:03:38 T7-Manjaro pulseaudio[1233]: Error opening PCM device front:0: Datei oder Verzeichnis nicht gefunden
Apr 26 23:03:38 T7-Manjaro systemd[860]: xdg-desktop-portal-gnome.service: Main process exited, code=exited, status=1/FAILURE
Apr 26 23:03:38 T7-Manjaro systemd[860]: xdg-desktop-portal-gnome.service: Failed with result 'exit-code'.
Apr 26 23:03:38 T7-Manjaro systemd[860]: xdg-desktop-portal-gtk.service: Main process exited, code=exited, status=1/FAILURE
Apr 26 23:03:38 T7-Manjaro systemd[860]: xdg-desktop-portal-gtk.service: Failed with result 'exit-code'.
Apr 26 23:03:39 T7-Manjaro systemd[861]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8004 service=[systemd-user] terminal=[] user=[michae1] ruser=[<unknown>] rhost=[<unknown>]
Apr 26 23:03:39 T7-Manjaro systemd[1]: user-1000.slice: Consumed 1h 37min 41.097s CPU time.
Apr 26 23:03:39 T7-Manjaro systemd[1]: user.slice: Consumed 1h 37min 41.097s CPU time.
[michae1@T7-Manjaro ~]$
ok so it looks like it was the -2 boot, there are some ‘failed’ logs… are those all logs from the command? please provide more, at least the 30 last lines
wait those are logs dated yesterday night, and the from boot -1 are dated from today 13:24
I am sorry to make so much work for you.
Since last night I have rebooted the computer several times, at least 3 or 4 times.
What should I enter now?
