[HowTo] Rescue your system: error: hook ... Invalid value Path
What causes this?
The issue is usually provoked when you don't maintain your system at regular intervals - and I am not thinking yearly - because such neglect will often result in similar problems.
As the issue stems from a change in pacman code - you may be affected if you install from an ISO previous to 18.1.5.
More technical it is a change to pacman and libalpm from 5.1 to 5.2. Users keeping their system up-to-date are not affected - users neglecting updates or installing from an older ISO are affected.
Reproduce
Due to several issues I decided to provoke such situation then describe the steps to fix it.
To reproduce the issue I used an Openbox ISO from the archive - 18.0.3 - early 2019 and did a complete install - reboot and a full update
$ sudo pacman -Syu
error: hook /usr/share/libalpm/hooks/update-mime-database.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-sysctl.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-tmpfiles.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/20-systemd-sysusers.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-hwdb.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-udev-reload.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-update.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/xorg-mkfontscale.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-catalog.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-binfmt.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/99-grub.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/30-systemd-daemon-reload.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/90-mkinitcpio-install.hook line 2: invalid value Path
error: hook /usr/share/libalpm/hooks/60-mkinitcpio-remove.hook line 2: invalid value Path
Because the hooks cannot be processed - then upon reboot - your system will lack initramfs, resulting in a message similar to this
error: file '/boot/vmlinuz-5.4.17-x86_64 not found
error: you need to load kernel first
Then nothing - just sits there.
Rescue
You need an ISO. Boot your system using the ISO and chroot into the installation.
# manjaro-chroot -a
If that does not work for you - you need to mount your partitions - a default Manjaro system uses two partitions root and $esp. If you have a customized partition layout you know how to mount it.
Device names can be in the form /dev/sd - /dev/nvme - even /dev/emmc. Use lsblk to identify the device path.
Mount the root on /mnt
# mount /dev/sdy2 /mnt
Then mount the $esp on /mnt/boot/efi
# mount /dev/sdy1 /mnt/boot/efi
Chroot into the system
# manjaro-chroot /mnt /bin/bash
Update pacman
First step is to update pacman - this may succeed or it may not
# pacman -S pacman
Depending on the result continue below
success
Continue with Repair system
failure
Uninstall packages depending pacman e.g. pamac and retry updating pacman.
If this fails - use wget or curl to fetch the current pacman package - unpack the archive to place the files at their designated locations.
Find the current pacman version - use a web browser point to a mirror and locate the package
https://manjaro.moson.eu/stable/core/x86_64/
Or a search using pamac - (replace mirror in below wget with the first mirror in your mirror list).
# pamac search pacman | grep core
Locate the version e.g. 5.2.1-4
Ensure you are in the root / - wget - and unpack the archive.
# cd /
# wget https://manjaro.moson.eu/stable/core/x86_64/pacman-5.2.1-4-x86_64.pkg.tar.zst
# tar -I zstd -xvf pacman-5.2.1-4-x86_64.pkg.tar.zst
Clean up the root
rm -f .BUILDINFO .INSTALL .MTREE .PKGINFO pacman*.pkg.tar.zst
Repair system
symptom
# mkinitcpio -P
==> ERROR: No presets found /etc/mkinitcpio.d
fix
Uninstall mkinitcpio and dependent packages
# pacman -R mkinitcpio
This will result in dependency transaction failure. Add the dependent packages to the command e.g.
# pacman -R mkinitcpio linux419 manjaro-system mkinitcpio-openswap
You will recieve a warning e.g. - press y to continue.
warning: manjaro-system is designated as a HoldPkg.
:: HoldPkg was found in target list. Do you want to continue? [y/N]
Reinstall the removed packages.
Press then Home then use edit the command and replace -R with -Syu and press Enter
When you installation completes you will have the necessary files initramfs and kernel back in place and you can exit chroot and reboot the system.
A post was split to a new topic: Can't get update to work
I had this issue couple weeks ago when I installed from the available openbox community edition, but only these two errors:
As I couldn't find anything about it anywhere, and after 4 installations and re-installations, I looked for those two files online and found versions that seemed newer and had no "path" as value. So I edited the file and tried updating again, it worked, been working so far.
Did I do wrong? Might have been a bit of a kamikaze solution but after so many reinstalls (and considering I had my old Ubuntu install cloned and the /home in another partition) I was kinda just testing whatever >.<
Did you actually read the topic?
Which part of it is hard to understand?
It is explained exactly why it happens and what to do.
I don't have the problem anymore, I managed to fix it, but not in the way you described (it was before you posted this), so I don't know if I did something bad. Hence my reply. The topic is pretty clear, I'm not complaining about it.
I just wondered if my kamikaze fix would be an issue in the long run, as I didn't know what I was doing back then.
