[HowTo] Minimal configuration for Manjaro Samba share
Install samba package
Ensure the samba package is installed and the system is fully updated.
sudo pacman -Syu samba
Basic configuration
Create the config file /etc/samba/smb.conf
sudo nano /etc/samba/smb.conf
Insert the following and save the file
[global]
   workgroup = Manjaro
   server string = Samba Server
   server role = standalone server
   log file = /var/log/samba/log.%m
   max log size = 50
   guest account = nobody
   map to guest = Bad Password
[public]
   path = /srv/samba
   public = yes
   writable = yes
   printable = no
Test your config
sudo testparm /etc/samba/smb.conf
Create share and set permissions
Create the shared folder
sudo mkdir -p /srv/samba
Set permissions to any and all
sudo chmod ugo+rwx /srv/samba -R
Start the services
sudo systemctl enable --now smb nmb
Accessing the share
Linux client
Ensure you have the smbclient package installed. Open your file manager and enter the servername or IP address in a filemanager's location bar using the smb protocol
smb://servername
Windows client
Access the share using the filemanager and input the servername in this format - it is of course possible to use the IP address as well.
\\servername
More reading
Samba on Arch Wiki
Sample Samba configuration with comments smb.conf on samba.org
Typing error
log file = /var/log/samba/%m.log
%m.log
I see the wiki has changed since my last read.
I don't think it is a typo - it is intentional as it refers to the log for machine - and it is copied from the sample smb.conf
# this tells Samba to use a separate log file for each machine
# that connects
   log file = /usr/local/samba/var/log.%m
I know - usually log files end with .log and in this case it consolidates listing logs by starting with log.
I copy from my working (old) smb.conf :wink:
~ >>> ls /var/log/samba/
insgesamt 60K
drwx------ 4 root root 4,0K 03.10.2018 21:55 cores/
-rw-r--r-- 1 root root    0 31.01.2019 23:24 192.168.178.24.log
-rw-r--r-- 1 root root    0 03.10.2018 21:55 log.nmbd
-rw-r--r-- 1 root root    0 03.10.2018 21:55 log.smbd
-rw-r--r-- 1 root root    0 24.03.2019 00:00 nmbd.log
-rw-r--r-- 1 root root 7,3K 24.03.2019 00:00 nmbd.log.1
-rw-r--r-- 1 root root 7,6K 17.03.2019 00:00 nmbd.log.2
-rw-r--r-- 1 root root 7,9K 10.03.2019 00:00 nmbd.log.3
-rw-r--r-- 1 root root  13K 03.03.2019 06:57 nmbd.log.4
-rw-r--r-- 1 root root    0 31.01.2019 23:24 odroid.log
-rw-r--r-- 1 root root    0 24.03.2019 00:00 smbd.log
-rw-r--r-- 1 root root 2,5K 24.03.2019 00:00 smbd.log.1
-rw-r--r-- 1 root root 2,7K 17.03.2019 00:00 smbd.log.2
-rw-r--r-- 1 root root 2,5K 10.03.2019 00:00 smbd.log.3
-rw-r--r-- 1 root root 3,5K 03.03.2019 06:57 smbd.log.4
[global]
   workgroup = WORKGROUP
   dns proxy = no
   max log size = 1000
   client max protocol = NT1
:+1:
Now I see where you are getting at - /log/ - fixed
