Booting to black screen after latest update. Seems to be due to [FAILED] Failed to start Light Display Manager
2 days ago I updated via pamac GUI, suspended to RAM and when starting the system it gets stuck on a black screen. No amount of reboots managed to change this. Removing the quiet option of grub reveals [FAILED] Failed to start Light Display Manager
I know there are a lot of similar threads and I spent a couple of hours yesterday trying to fix it, but with no success. I’ll provide all the things I tried and I’m hoping someone can help me, because I’m out of ideas.
I can access tty via Ctrl + Alt + F2 as well as chrooting from live USB.
inxi --admin --verbosity=7 --filter --width output:
12System:
  12Kernel 5.15.16-1-MANJARO 12arch x86_64 12bits 64 12compiler gcc 12v 11.1.0
    12parameters BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2122 quiet
    systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree
    nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
  12Desktop Xfce 12v 4.16.0 12tk Gtk 12v 3.24.29 12info xfce4-panel 12wm xfwm 12v 4.16.1
    12dm N/A 12Distro Manjaro Linux 12base Arch Linux
12Machine:
  12Type Desktop 12Mobo Micro-Star 12model B450 GAMING PRO CARBON AC (MS-7B85) 12v 1.0
    12serial <filter> 12UEFI American Megatrends 12v 1.C0 12date 06/11/2020
12Battery:
  12Message No system battery data found. Is one present?
12Memory:
  12RAM 12total 15.64 GiB 12used 2.42 GiB (15.4%)
  12Array-1 12capacity 128 GiB 12slots 4 12EC None 12max-module-size 32 GiB 12note est.
  12Device-1 DIMM 0 12type no module installed
  12Device-2 DIMM 1 12type DDR4 12detail synchronous unbuffered (unregistered)
    12size 8 GiB 12speed 2933 MT/s 12volts 12curr 1.2 12min 1.2 12max 1.2 12width (bits)
    12data 64 12total 64 12manufacturer G.Skill 12part-no F4-3000C16-8GISB 12serial N/A
  12Device-3 DIMM 0 12type no module installed
  12Device-4 DIMM 1 12type DDR4 12detail synchronous unbuffered (unregistered)
12CPU:
  12Info 12model AMD Ryzen 5 2600 12socket AM4 12bits 64 12type MT MCP 12arch Zen+ 12gen 2
    12built 2018-21 12process GF 12nm 12family 0x17 (23) 12model-id 8 12stepping 2
    12microcode 0x800820D
  12Topology 12cpus 1x 12cores 6 12tpc 2 12threads 12 12smt enabled 12cache 12L1 576 KiB
    12desc d-6x32 KiB; i-6x64 KiB 12L2 3 MiB 12desc 6x512 KiB 12L3 16 MiB 12desc 2x8 MiB
  12Speed (MHz) 12avg 1550 12min/max 1550/3400 12boost enabled 12base/boost 3400/3900
    12scaling 12driver acpi-cpufreq 12governor schedutil 12volts 1.1 V 12ext-clock 100 MHz
    12cores 121 1550 122 1550 123 1550 124 1550 125 1550 126 1550 127 1550 128 1550 129 1550
    1210 1550 1211 1550 1212 1550 12bogomips 81617
  12Flags 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
    bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb cpuid
    fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm
    mca mce misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc
    nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq
    pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse
    pse36 rapl rdrand rdseed rdtscp rep_good sep sev sev_es sha_ni skinit smap
    smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock
    syscall tce topoext tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
  12Vulnerabilities
  12Type itlb_multihit 12status Not affected
  12Type l1tf 12status Not affected
  12Type mds 12status Not affected
  12Type meltdown 12status Not affected
  12Type spec_store_bypass
    12mitigation Speculative Store Bypass disabled via prctl and seccomp
  12Type spectre_v1
    12mitigation usercopy/swapgs barriers and __user pointer sanitization
  12Type spectre_v2 12mitigation Full AMD retpoline, IBPB: conditional, STIBP:
    disabled, RSB filling
  12Type srbds 12status Not affected
  12Type tsx_async_abort 12status Not affected
12Graphics:
  12Device-1 AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
    12vendor Micro-Star MSI 12driver amdgpu 12v kernel 12arch GCN 4 12process GF 14nm
    12built 2016-20 12pcie 12gen 3 12speed 8 GT/s 12lanes 16 12ports
    12active HDMI-A-1,HDMI-A-2 12empty DP-1,DP-2,DVI-D-1 12bus-ID 26:00.0
    12chip-ID 1002:67df 12class-ID 0300
  12Device-2 Microsoft LifeCam Cinema 12type USB 12driver snd-usb-audio,uvcvideo
    12bus-ID 1-2:2 12chip-ID 045e:075d 12class-ID 0102
  12Display 12server X.Org 12v 21.1.3 12compositor xfwm 12v 4.16.1 12driver 12X
    12loaded amdgpu,modesetting 12alternate fbdev,vesa 12gpu amdgpu 12display-ID :0.0
    12screens 1
  12Screen-1 0 12s-res 3840x1080 12s-dpi 96 12s-size 1016x285mm (40.00x11.22")
    12s-diag 1055mm (41.54")
  12Monitor-1 HDMI-A-1 12mapped HDMI-A-0 12pos primary,left 12model AOC 2590G5
    12serial <filter> 12built 2021 12res 1920x1080 12hz 60 12dpi 90 12gamma 1.2
    12size 544x303mm (21.42x11.93") 12diag 623mm (24.5") 12ratio 16:9 12modes
    12max 1920x1080 12min 720x400
  12Monitor-2 HDMI-A-2 12mapped HDMI-A-1 12pos right 12model AOC 2590G5
    12serial <filter> 12built 2019 12res 1920x1080 12hz 60 12dpi 90 12gamma 1.2
  12Message GL data unavailable for root.
12Audio:
  12Device-1 AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
    12vendor Micro-Star MSI 12driver snd_hda_intel 12bus-ID 1-2:2 12v kernel
    12chip-ID 045e:075d 12pcie 12gen 1 12class-ID 0102 12speed 2.5 GT/s 12lanes 16
    12link-max 12gen 3 12speed 8 GT/s 12bus-ID 26:00.1 12chip-ID 1002:aaf0 12class-ID 0403
  12Device-2 AMD Family 17h HD Audio 12vendor Micro-Star MSI
    12driver snd_hda_intel 12v kernel 12pcie 12gen 3 12speed 8 GT/s 12lanes 16
    12bus-ID 28:00.3 12chip-ID 1022:1457 12class-ID 0403
  12Device-3 Microsoft LifeCam Cinema 12type USB 12driver snd-usb-audio,uvcvideo
  12Sound Server-1 ALSA 12v k5.15.16-1-MANJARO 12running yes
  12Sound Server-2 JACK 12v 1.9.21 12running no
  12Sound Server-3 PulseAudio 12v 16.1 12running yes
  12Sound Server-4 PipeWire 12v 0.3.52 12running no
12Network:
  12Device-1 Intel Wireless-AC 9260 12driver iwlwifi 12v kernel 12pcie 12gen 2
    12speed 5 GT/s 12lanes 1 12bus-ID 21:00.0 12chip-ID 8086:2526 12class-ID 0280
  12IF wlo1 12state down 12mac <filter>
  12Device-2 Intel I211 Gigabit Network 12vendor Micro-Star MSI 12driver igb
    12v kernel 12pcie 12gen 1 12speed 2.5 GT/s 12lanes 1 12port f000 12bus-ID 22:00.0
    12chip-ID 8086:1539 12class-ID 0200
  12IF enp34s0 12state up 12speed 100 Mbps 12duplex full 12mac <filter>
  12IP v4 <filter> 12type noprefixroute 12scope global 12broadcast <filter>
  12IP v6 <filter> 12type noprefixroute 12scope link
  12WAN IP <filter>
12Bluetooth:
  12Device-1 Intel Wireless-AC 9260 Bluetooth Adapter 12type USB 12driver btusb
    12v 0.8 12bus-ID 3-4:4 12chip-ID 8087:0025 12class-ID e001
  12Report rfkill 12ID hci0 12rfk-id 1 12state down 12bt-service N/A 12rfk-block
    12hardware no 12software yes 12address see --recommends
12Logical:
  12Message No logical block device data found.
12RAID:
  12Message No RAID data found.
12Drives:
  12Local Storage 12total 1.6 TiB 12used 404.53 GiB (24.8%)
  12SMART Message Required tool smartctl not installed. Check --recommends
  12ID-1 /dev/sda 12maj-min 8:0 12vendor Samsung 12model SSD 860 EVO 500GB
    12size 465.76 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 6.0 Gb/s
    12type SSD 12serial <filter> 12rev 4B6Q
  12ID-2 /dev/sdb 12maj-min 8:16 12vendor Samsung 12model SSD 860 EVO 250GB
    12size 232.89 GiB 12block-size 12physical 512 B 12logical 512 B 12speed 6.0 Gb/s
    12type SSD 12serial <filter> 12rev 2B6Q
  12ID-3 /dev/sdc 12maj-min 8:32 12vendor Seagate 12model ST1000DM010-2EP102
    12size 931.51 GiB 12block-size 12physical 4096 B 12logical 512 B 12speed 6.0 Gb/s
    12type N/A 12serial <filter> 12rev CC43
  12ID-4 /dev/sdd 12maj-min 8:48 12type USB 12vendor A-Data 12model USB Flash Drive
    12size 3.67 GiB 12block-size 12physical 512 B 12logical 512 B 12type SSD
    12serial <filter> 12rev 0.00
  12Message No optical or floppy data found.
12Partition:
  12ID-1 / 12raw-size 99.23 GiB 12size 97.11 GiB (97.87%) 12used 78.94 GiB (81.3%)
    12fs ext4 12block-size 4096 B 12dev /dev/sdb5 12maj-min 8:21 12label N/A
    12uuid 7db9012f-57c7-4cbb-b90a-ccbd264c565f
  12ID-2 /boot/efi 12raw-size 100 MiB 12size 96 MiB (96.00%) 12used 26.6 MiB (27.7%)
    12fs vfat 12block-size 512 B 12dev /dev/sdb3 12maj-min 8:19 12label N/A 12uuid 6A3F-F697
  12ID-3 /home 12raw-size 465.76 GiB 12size 457.38 GiB (98.20%)
    12used 325.57 GiB (71.2%) 12fs ext4 12block-size 4096 B 12dev /dev/sda1 12maj-min 8:1
    12label Home Partition 12uuid 4e06bcc0-6bcf-405f-9bbf-524cbceed6d0
12Swap:
  12Alert No swap data was found.
12Unmounted:
  12ID-1 /dev/sdb1 12maj-min 8:17 12size 579 MiB 12fs ntfs 12label System Reserved
    12uuid 3438C85038C812B2
  12ID-2 /dev/sdb2 12maj-min 8:18 12size 132.5 GiB 12fs ntfs 12label N/A
    12uuid 82C2C92DC2C9266F
  12ID-3 /dev/sdb4 12maj-min 8:20 12size 512 MiB 12fs fat (32 bit) 12label BOOTLOADER
    12uuid 9D4C-03ED
  12ID-4 /dev/sdc1 12maj-min 8:33 12size 931.51 GiB 12fs ntfs 12label HDD 3.5
    12uuid D85CF88F5CF869A0
  12ID-5 /dev/sdd1 12maj-min 8:49 12size 3.43 GiB 12fs N/A 12label MANJARO_XFCE_2122
    12uuid 2022-01-23-13-29-58-00
  12ID-6 /dev/sdd2 12maj-min 8:50 12size 4 MiB 12fs N/A 12label MISO_EFI
    12uuid 01C9-8517
12USB:
  12Hub-1 1-0:1 12info Hi-speed hub with single TT 12ports 10 12rev 2.0 12speed 480 Mb/s
    12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 1-2:2 12info Microsoft LifeCam Cinema 12type Video,Audio
    12driver snd-usb-audio,uvcvideo 12interfaces 4 12rev 2.0 12speed 480 Mb/s
    12power 500mA 12chip-ID 045e:075d 12class-ID 0102
  12Device-2 1-3:3 12info A-DATA C906 Flash Drive 12type Mass Storage
    12driver usb-storage 12interfaces 1 12rev 2.0 12speed 480 Mb/s 12power 480mA
    12chip-ID 125f:c96a 12class-ID 0806 12serial <filter>
  12Device-3 1-9:4 12info Razer USA DeathAdder Elite 12type Mouse,Keyboard
    12driver hid-generic,usbhid 12interfaces 3 12rev 2.0 12speed 12 Mb/s 12power 500mA
    12chip-ID 1532:005c 12class-ID 0300
  12Hub-2 2-0:1 12info Super-speed hub 12ports 4 12rev 3.1 12speed 10 Gb/s
    12chip-ID 1d6b:0003 12class-ID 0900
  12Hub-3 3-0:1 12info Hi-speed hub with single TT 12ports 4 12rev 2.0
    12speed 480 Mb/s 12chip-ID 1d6b:0002 12class-ID 0900
  12Device-1 3-2:2 12info Cooler Master MasterKeys Pro M Single
    12type Keyboard,HID 12driver hid-generic,usbhid 12interfaces 3 12rev 1.1
    12speed 12 Mb/s 12power 100mA 12chip-ID 2516:0048 12class-ID 0300
  12Device-2 3-3:3 12info Micro Star PRO CARBON 12type HID
    12driver hid-generic,usbhid 12interfaces 1 12rev 1.1 12speed 12 Mb/s 12power 500mA
    12chip-ID 1462:7b85 12class-ID 0300 12serial <filter>
  12Device-3 3-4:4 12info Intel Wireless-AC 9260 Bluetooth Adapter
    12type Bluetooth 12driver btusb 12interfaces 2 12rev 2.0 12speed 12 Mb/s 12power 100mA
  12Hub-4 4-0:1 12info Super-speed hub 12ports 4 12rev 3.0 12speed 5 Gb/s
12Sensors:
  12System Temperatures 12cpu N/A 12mobo N/A 12gpu amdgpu 12temp 50.0 C
  12Fan Speeds (RPM) N/A 12gpu amdgpu 12fan 230
12Info:
  12Processes 331 12Uptime 20m 12wakeups 0 12Init systemd 12v 251 12default graphical
  12tool systemctl 12Compilers 12gcc 12.1.0 12clang 13.0.1 12Packages 12pacman 1492
  12lib 452 12flatpak 0 12Client Unknown Client: systemd 12inxi 3.3.19
mhwd -li output:
           video-linux            2018.05.04                true            PCI
cat /var/log/Xorg.0.log output:
[     7.625]
X.Org X Server 1.21.1.3
[     7.625] Current Operating System: Linux GLinux 5.15.49-1-MANJARO #1 SMP PREEMPT Wed Jun 22 14:15:49 UTC 2022 x86_64
[     7.625] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=7db9012f-57c7-4cbb-b90a-ccbd264c565f rw apparmor=1 security=apparmor udev.log_priority=3
[     7.625]
[     7.625] Current version of pixman: 0.40.0
[     7.625] 	Before reporting problems, check http://wiki.x.org
[     7.625] Markers: (--) probed, (**) from config file, (==) default setting,
[     7.625] (==) Log file: "/var/log/Xorg.0.log", Time: Thu Jun 30 11:22:14 2022
[     7.626] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     7.626] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     7.626] (==) No Layout section.  Using the first Screen section.
[     7.626] (==) No screen section available. Using defaults.
[     7.626] (**) |-->Screen "Default Screen Section" (0)
[     7.626] (**) |   |-->Monitor "<default monitor>"
[     7.626] (==) No monitor specified for screen "Default Screen Section".
[     7.626] (==) Automatically adding devices
[     7.626] (==) Automatically enabling devices
[     7.626] (==) Automatically adding GPU devices
[     7.626] (==) Automatically binding GPU devices
[     7.626] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     7.626] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     7.626] 	Entry deleted from font path.
[     7.626] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     7.626] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     7.626] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     7.626] (==) FontPath set to:
	/usr/share/fonts/misc,
	/usr/share/fonts/TTF
[     7.626] (==) ModulePath set to "/usr/lib/xorg/modules"
[     7.626] (II) The server relies on udev to provide the list of input devices.
[     7.626] (II) Module ABI versions:
[     7.626] 	X.Org ANSI C Emulation: 0.4
[     7.626] 	X.Org Video Driver: 25.2
[     7.626] 	X.Org XInput driver : 24.4
[     7.626] 	X.Org Server Extension : 10.0
[     7.627] (++) using VT number 7
[     7.627] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[     7.629] (II) xfree86: Adding drm device (/dev/dri/card0)
[     7.629] (II) Platform probe for /sys/devices/pci0000:00/0000:00:03.1/0000:26:00.0/drm/card0
[     7.640] (--) PCI:*(38@0:0:0) 1002:67df:1462:3418 rev 231, Mem @ 0xe0000000/268435456, 0xf0000000/2097152, 0xfcf00000/262144, I/O @ 0x0000e000/256, BIOS @ 0x????????/131072
[     7.640] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     7.640] (II) LoadModule: "glx"
[     7.641] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     7.643] (II) Module glx: vendor="X.Org Foundation"
[     7.643] 	compiled for 1.21.1.3, module version = 1.0.0
[     7.643] 	ABI class: X.Org Server Extension, version 10.0
[     7.643] (II) Applying OutputClass "AMDgpu" to /dev/dri/card0
[     7.643] 	loading driver: amdgpu
[     7.643] (==) Matched amdgpu as autoconfigured driver 0
[     7.643] (==) Matched ati as autoconfigured driver 1
[     7.643] (==) Matched modesetting as autoconfigured driver 2
[     7.643] (==) Matched fbdev as autoconfigured driver 3
[     7.643] (==) Matched vesa as autoconfigured driver 4
[     7.643] (==) Assigned the driver to the xf86ConfigLayout
[     7.643] (II) LoadModule: "amdgpu"
[     7.643] (II) Loading /usr/lib/xorg/modules/drivers/amdgpu_drv.so
[     7.644] (II) Module amdgpu: vendor="X.Org Foundation"
[     7.644] 	compiled for 1.21.1.3, module version = 22.0.0
[     7.644] 	Module class: X.Org Video Driver
[     7.644] 	ABI class: X.Org Video Driver, version 25.2
[     7.644] (II) LoadModule: "ati"
[     7.644] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[     7.644] (II) Module ati: vendor="X.Org Foundation"
[     7.644] 	compiled for 1.21.1.1, module version = 19.1.0
[     7.649] (II) LoadModule: "modesetting"
[     7.650] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[     7.650] (II) Module modesetting: vendor="X.Org Foundation"
[     7.650] 	compiled for 1.21.1.3, module version = 1.21.1
[     7.650] 	Module class: X.Org Video Driver
[     7.650] 	ABI class: X.Org Video Driver, version 25.2
[     7.650] (II) LoadModule: "fbdev"
[     7.650] (WW) Warning, couldn't open module fbdev
[     7.650] (EE) Failed to load module "fbdev" (module does not exist, 0)
[     7.650] (II) LoadModule: "vesa"
[     7.650] (WW) Warning, couldn't open module vesa
[     7.650] (EE) Failed to load module "vesa" (module does not exist, 0)
[     7.650] (II) AMDGPU: Driver for AMD Radeon:
	All GPUs supported by the amdgpu kernel driver
[     7.650] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[     7.651] (WW) Falling back to old probe method for modesetting
[     7.652] (II) AMDGPU(0): Creating default Display subsection in Screen section
	"Default Screen Section" for depth/fbbpp 24/32
[     7.652] (==) AMDGPU(0): Depth 24, (--) framebuffer bpp 32
[     7.652] (II) AMDGPU(0): Pixel depth = 24 bits stored in 4 bytes (32 bpp pixmaps)
[     7.652] (==) AMDGPU(0): Default visual is TrueColor
[     7.652] (==) AMDGPU(0): RGB weight 888
[     7.652] (II) AMDGPU(0): Using 8 bits per RGB (8 bit DAC)
[     7.652] (--) AMDGPU(0): Chipset: "AMD Radeon RX 580 Series" (ChipID = 0x67df)
[     7.652] (II) Loading sub module "fb"
[     7.652] (II) LoadModule: "fb"
[     7.652] (II) Module "fb" already built-in
[     7.652] (II) Loading sub module "dri2"
[     7.652] (II) LoadModule: "dri2"
[     7.652] (II) Module "dri2" already built-in
[     7.679] (EE)
[     7.679] (EE) Backtrace:
[     7.679] (EE) 0: /usr/lib/Xorg (xorg_backtrace+0x2dd) [0x558a8a8510ed]
[     7.680] (EE) 1: /usr/lib/libc.so.6 (__sigaction+0x50) [0x7f4641f248e0]
[     7.680] (EE) 2: /usr/lib/dri/radeonsi_dri.so (nouveau_drm_screen_create+0x4bdb40) [0x7f4640550130]
[     7.680] (EE) unw_get_proc_name failed: no unwind info found [-10]
[     7.680] (EE) 3: /usr/lib/dri/radeonsi_dri.so (?+0x0) [0x7f463f87e314]
[     7.680] (EE) 4: /lib64/ld-linux-x86-64.so.2 (__nptl_change_stack_perm+0x127e) [0x7f4642524f3e]
[     7.680] (EE) 5: /lib64/ld-linux-x86-64.so.2 (__nptl_change_stack_perm+0x136c) [0x7f464252502c]
[     7.681] (EE) 6: /usr/lib/libc.so.6 (_dl_catch_exception+0xd4) [0x7f464203f4d4]
[     7.681] (EE) 7: /lib64/ld-linux-x86-64.so.2 (_dl_rtld_di_serinfo+0x2e07) [0x7f464252c097]
[     7.681] (EE) 8: /usr/lib/libc.so.6 (_dl_catch_exception+0x7e) [0x7f464203f47e]
[     7.681] (EE) 9: /lib64/ld-linux-x86-64.so.2 (_dl_find_dso_for_object+0x17d) [0x7f464252c42d]
[     7.681] (EE) 10: /usr/lib/libc.so.6 (dlmopen+0xfc) [0x7f4641f6e63c]
[     7.682] (EE) 11: /usr/lib/libc.so.6 (_dl_catch_exception+0x7e) [0x7f464203f47e]
[     7.682] (EE) 12: /usr/lib/libc.so.6 (_dl_catch_error+0x33) [0x7f464203f533]
[     7.682] (EE) 13: /usr/lib/libc.so.6 (dlerror+0x29f) [0x7f4641f6e10f]
[     7.682] (EE) 14: /usr/lib/libc.so.6 (dlopen+0x71) [0x7f4641f6e6f1]
[     7.682] (EE) unw_get_proc_name failed: no unwind info found [-10]
[     7.682] (EE) 15: /usr/lib/libgbm.so.1 (?+0x0) [0x7f464128c6b0]
[     7.683] (EE) 16: /usr/lib/libgbm.so.1 (gbm_create_device+0x1e00) [0x7f464128e710]
[     7.683] (EE) 17: /usr/lib/libgbm.so.1 (gbm_create_device+0x1f7e) [0x7f464128e88e]
[     7.683] (EE) 18: /usr/lib/libgbm.so.1 (gbm_create_device+0x283f) [0x7f464128f14f]
[     7.683] (EE) unw_get_proc_name failed: no unwind info found [-10]
[     7.683] (EE) 19: /usr/lib/libgbm.so.1 (?+0x0) [0x7f464128c8ec]
[     7.683] (EE) 20: /usr/lib/libgbm.so.1 (gbm_create_device+0x119) [0x7f464128ca29]
[     7.683] (EE) 21: /usr/lib/xorg/modules/drivers/amdgpu_drv.so (?+0x0) [0x7f464250933b]
[     7.683] (EE) 22: /usr/lib/Xorg (InitOutput+0x18dd) [0x558a8a87610d]
[     7.683] (EE) 23: /usr/lib/Xorg (SProcXkbDispatch+0x17ec) [0x558a8a73a077]
[     7.684] (EE) 24: /usr/lib/libc.so.6 (__libc_init_first+0x90) [0x7f4641f0f290]
[     7.684] (EE) 25: /usr/lib/libc.so.6 (__libc_start_main+0x8a) [0x7f4641f0f34a]
[     7.684] (EE) 26: /usr/lib/Xorg (_start+0x25) [0x558a8a73b4b5]
[     7.684] (EE)
[     7.684] (EE) Segmentation fault at address 0x0
[     7.684] (EE)
Fatal server error:
[     7.684] (EE) Caught signal 11 (Segmentation fault). Server aborting
[     7.684] (EE)
[     7.684] (EE)
Please consult the The X.Org Foundation support
	 at http://wiki.x.org
 for help.
[     7.684] (EE) Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[     7.684] (EE)
[     7.703] (EE) Server terminated with error (1). Closing log file.
cat /var/log/lightdm//lightdm.log output:
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.30.0, UID=0 PID=1116
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /var/lib/flatpak/exports/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.00s] DEBUG: _g_io_module_get_default: Found default implementation local (GLocalVfs) for ‘gio-vfs’
[+0.00s] DEBUG: Monitoring logind for seats
[+0.00s] DEBUG: New seat added from logind: seat0
[+0.00s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.00s] DEBUG: Seat seat0 has property CanMultiSession=no
[+0.00s] DEBUG: Seat seat0: Starting
[+0.00s] DEBUG: Seat seat0: Creating greeter session
[+0.01s] DEBUG: Seat seat0: Creating display server of type x
[+0.01s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.01s] DEBUG: Using VT 7
[+0.01s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.01s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.01s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.01s] DEBUG: XServer 0: Launching X Server
[+0.01s] DEBUG: Launching process 1122: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.01s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.01s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+0.01s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.01s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.29s] DEBUG: Process 1122 terminated with signal 6
[+0.29s] DEBUG: XServer 0: X server stopped
[+0.29s] DEBUG: Releasing VT 7
[+0.29s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+0.29s] DEBUG: Seat seat0: Display server stopped
[+0.29s] DEBUG: Seat seat0: Stopping session
[+0.29s] DEBUG: Seat seat0: Session stopped
[+0.29s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+0.29s] DEBUG: Seat seat0: Stopping; greeter display server failed to start
[+0.29s] DEBUG: Seat seat0: Stopped
[+0.29s] DEBUG: Required seat has stopped
[+0.29s] DEBUG: Stopping display manager
[+0.29s] DEBUG: Display manager stopped
[+0.29s] DEBUG: Stopping daemon
[+0.29s] DEBUG: Exiting with return value 1
sudo systemctl status lightdm.service output:
x lightdm.service - Light Display Manager
      Loaded: loaded (/usr/lib/systemd/lightdm.service; enabled; vendor preset: disabled)
      Active: failed (Result: exit-code) since Thu 2022-06-30 21:21:35 EEST; 43s ago
      Duration: 311ms
      Docs: man: lightdm(1)
      Process: 1289 ExecStart=/usr/bin/lightdm (code=exited, status=1/FAILURE)
      Main PID: 1289(code=exited, status=1/FAILURE)
      CPU: 107ms
systemd[1]: lightdm.service: Scheduled restart job, restart counter is at 5.
systemd[1]: Stopped Light Display Manager.
systemd[1]: lightdm.service: Start request repeated too quickly.
systemd[1]: lightdm.service: Failed with result 'exit-code'.
systemd[1]: Failed to start Light Display Manager.
Things I tried (with no success):
  1. Switching to a different kernel. Tried with 5.10, 5.15 and 5.17.
  2. Adding MODULE=(amdgpu) to /etc/mkinitcpio.conf, running sudo mkinitcpio -p linux515 and rebooting.
  3. Reinstalling lightdm and lightdm-gtk-greeter via pacman -S lightdm lightdm-gtk-greeter.
  4. Changing this in etc/lightdm/lightdm.conf:
[LightDM]
logind-check-graphical=true
  1. Runnign sudo pacman-mirrors -f 5 && sudo pacman -Syyu
Any help will be greatly appreciated and thanks in advance!
so reruning update didnt gave you any errors?
output from:
mhwd-kernel -li
If you mean rerunning pacman -Syu - it says there is nothing to update.
5.15.49-1-MANJARO (linux515)
   * linux510
   * linux 515
   * linux517
uninstall the 517, its EOL:
mhwd-kernel -r linux517
then reinstall video drivers:
uninstall:
sudo mhwd -r pci video-linux
install:
sudo mhwd -i pci video-linux
reinstall xorg:
pacman -S xorg-server
post output from:
find /etc/X11/ -name "*.conf"
Did all the steps above and rebooted with no success. lightdm.service status is still failed.
Output of find /etc/X11/ -name "*.conf":
/etc/X11/xorg.conf.d/00-keyboard.conf
reinstall also these, since they are mentioned in the xorg log:
pacman -S mesa glibc
reboot and see if it helped
Yes it worked! Thanks a lot.
Any idea why they might have caused a problem? I had no problems so far and I just did a pamac update.
after every update you need to reboot, not putting your pc to sleep…
Noted. Thanks again.
