what should i do?
i don’t know what any of these mean,but i see the new one is missing : “keymap” & “resume”,and adds “fsck”.
and about this:
# MODULES_DECOMPRESS
# Decompress kernel modules during initramfs creation.
# Enable to speedup boot process, disable to save RAM
# during early userspace. Switch (yes/no).
#MODULES_DECOMPRESS="yes"
i dont’ mind my current boot speed but i also have enough RAM.
any downside to enabling it?
In earlier Manjaro times fsck was skipped, I think shutdown was sometimes a bit faster and less messages, but Arch standard is to have it set. In fresher installs it is set in Manjaro, too.
All the options are commented in the file so its not difficult to understand.
I don’t have fsck option because /usr is not in different block so I don’t need it."
do i need to run this command?and aslo his comment about “/usr is not in different block so I don’t need it.” what does that mean?
You linked yourself to the kernel parameters wiki article, why do you need someone else to tell you what it says there?
Anyhow, you don’t need to change anything, you only need to have commented out #GRUB_ROOT_FS_RO=true in /etc/default/grub which you most probably already have.
(I’m sorry. I just had to use that line after reading through this thread. I kept biting my nails, trying to resist the urge, but the more I kept reading the posts, the stronger the temptation… )
