[HowTo] Install Manjaro using UEFI, systemd-boot and btrfs
Manjaro UEFI using systemd-boot and btrfs
This document is the result of reading a guide linked by @TomZ in this topic How to install Arch on btrfs with systemd boot.
The following is my notes while reading and the changes I made to the subsequent installation to fit into a Manjaro system installation.
NOTE: Before you dive into btrfs - be sure to read the entire article - including the documentation linked at the end of this document.
Overview
  • UEFI using systemd-boot
  • btrfs with subvolumes
  • Sources is listed at the end of this document
You can boot from any Manjaro ISO - open a terminal - and follow this guide.
For a similar guide but using LUKS read here
Assuming you know how to identify your disk devices and can replace the example device name /dev/sdy with the device for your system.
All commands written is assuming your are logged in as root. On Manjaro ISOs the root login is root : manjaro
General
Connect to your network and ensure your time is corret
# systemctl enable --now systemd-timesyncd
Update the mirrorlist and download databases
# pacman-mirrors -f
# pacman -Syy
Partitioning and File System Creation
Partition
Clear the disk of any existing file systems
# dd if=/dev/urandom of=/dev/sdy bs=1M count=100
Use cdisk to create the boot partition and the main partition
# cfdisk /dev/sdy
  1. boot
    • 512M
    • EFI system partition type
  2. root
    • remaining space
    • default type Linux file system
Format
Format to FAT32 for the boot and btrfs for root
# mkfs.vfat -F32 /dev/sdy1
# mkfs.btrfs /dev/sdy2
The author of the original guide has some reasonable suggestions which also matches the defaults used by Manjaro Architect.
  • / subvolume
  • /home subvolume in case a root snapshot needs to be restored
  • /var changes often so also a separate subvolume.
  • noatime and nodiratime are used to prevent a write every time a file or directory is accessed (not great for a COW filesystem like btrfs).
  • zstd is used for compression because it's fast and provides compression similar to xz.
  • Don't use discard . Issue manual trim commands with fstrim or enable the fstrim.timer.
Subvolumes
# mount /dev/sdy2 /mnt
# btrfs subvolume create /mnt/@
# btrfs subvolume create /mnt/@home
# btrfs subvolume create /mnt/@var
# umount /mnt
# mount -o subvol=@,ssd,compress=zstd,noatime,nodiratime /dev/sdy2 /mnt
# mkdir /mnt/{boot,home,var}
# mount -o subvol=@home,ssd,compress=zstd,noatime,nodiratime /dev/sdy2 /mnt/home
# mount -o subvol=@var,ssd,compress=zstd,noatime,nodiratime /dev/sdy2 /mnt/var
# mount /dev/sdy1 /mnt/boot
Installation
Install base Manjaro
# basestrap /mnt base btrfs-progs sudo manjaro-zsh-config intel-ucode networkmanager linux54 nano vim systemd-boot-manager mkinitcpio
Generate fstab and verify
# fstabgen -U /mnt >> /mnt/etc/fstab
# cat /mnt/etc/fstab
Configure system
Chroot
# manjaro-chroot /mnt /bin/zsh
Hostname
# echo manjaro > /etc/hostname
Edit /etc/hosts
# nano /etc/hosts
127.0.0.1   localhost
::1     localhost
127.0.1.1   manjaro.localdomain   manjaro
Shell
# chsh -s /bin/zsh
Timezone
Example for Denmark
# ln -sf /usr/share/zoneinfo/Europe/Copenhagen /etc/localtime
# hwclock --systohc
Network Manager
Enable network connection
# systemctl enable NetworkManager
Enable ntp client
# systemctl enable systemd-timesyncd
Locale
Example for Danish locale
  • uncomment en_DK.UTF-8 and en_US.UTF-8
# nano /etc/locale.gen
# locale-gen
/etc/locale.conf
Locale.conf example for Denmark
# echo LANG=en_DK.UTF-8 > /etc/locale.conf
Root password
# passwd
/etc/mkinitcpio.conf
Add btrfs
HOOKS="base udev autodetect modconf block btrfs filesystems keyboard fsck"
# mkinitcpio -p linux54
systemd-boot
Setup the boot loader
# bootctl --path=/boot install
Create Manjaro entries
# sdboot-manage gen
Verify the config
Navigate to /boot/loader/entries and check the configurations sdboot-manager has created (there will be two)
  • Default
  • Fallback
Base config done
# exit
# umount -R /mnt
# reboot
Customizing
You should have a fully functioning Manjaro system. What comes next is your personal preferences. The example is a very basic vanilla Gnome desktop.
Gnome desktop
# pacman -Syu xorg-server xorg-server-common xorg-xinit xorg-drivers accountsservice gnome-keyring gnome-session gnome-shell gnome-desktop gnome-terminal gdm
Add a user and set password
# useradd -mUG lp,network,power,sys,wheel -s /bin/zsh newuser
# passwd newuser
Admin user
Add user to wheel group
# EDITOR=nano visudo
Uncomment and save
%wheel ALL=(ALL) ALL
Enable display manager
# systemctl enable gdm
Reboot
# reboot
Trouble shooting
If something went wrong and you need to get back in from the live image:
# mount -o subvol=@,ssd /dev/sdy2 /mnt
# mount -o subvol=@home,ssd /dev/sdy2 /mnt/home
# mount -o subvol=@var,ssd /dev/sdy2 /mnt/var
btrfs resources
Credits
Sources listed in primary source
@torvic9 @eugen-b
I have noticed your experience with btrfs - if you have any improvements with relation to btrfs - I will appreciate your input or direct improvements.
I am neither one of the two :slight_smile: but how about a BTRFS sub- section in the customizing section covering some BTRFS best practice?
Optional but recomended
Mount drive root for easy access to subvolumes. Add the following to /etc/fstab:
UUID=Your-drives-UUID /mnt btrfs defaults,ssd,noatime 0 2
Create Snapshot directory
mkdir /mnt/snapshots
Create initial snapshots of your root (@) and home (@home) folders
sudo btrfs subvolume snapshot -r /mnt/@ /mnt/snapshots/clean@
sudo btrfs subvolume snapshot -r /mnt/@home /mnt/snapshots/clean@home
Good idea - my first experiences with btrfs was a couple of years ago and not a positive one - so these writings are my getting-my-feet-weet experience using the btrfs filesystem.
I have nil experience so I can't judge what is good and what is bad.
I have added @torvic9's tips and tricks to the original topic
it depends on what you use to create snapshots
timeshift has its own way
snapper also has its different way
I think I need to have a closer look at timeshift at some point
So far I didn't bother because creating snapshots manually is a oneliner and restores are just 4 commands or so, I am not sure what useful things it can add.
But maybe there is stuff I will really value...
i tried snapper
manual way
and
timeshift
so far only timeshift is hassle free.
i use timeshift-autosnap and grub-btrfs.
and its enough for me.
Looks like systemd-boot is not supported?
  • GRUB2 - Bootloader must be GRUB2. GRUB legacy and other bootloaders are not supported.
I think - what is not supported is the timeshift ability to restore the bootloader.
Of course I cannot know - but I don't think the bootloader part has any influence on the ability to restore the root partition itself.
