[HowTo] Google Chrome Tweaks for 83.0.4103.61 (or newer) | 20200527
s
This is my recommendation for best experience with Google Chrome. Feel free debate about options.
For some reason --enable-features and --disable-features are not to be applied properly from chrome-flags.conf file. Then enable it properly flags in chrome://flags page. See URLs below.
Create FILE ~/.config/chrome-flags.conf
nano ~/.config/chrome-flags.conf
with SINGLE LINE CMD:
--flag-switches-begin --force-dark-mode --high-dpi-support=1 --force-device-scale-factor=1.2 --ignore-gpu-blacklist --enable-smooth-scrolling --flag-switches-end
Disable Media key controls applet and keyboard binding handling. Disable QUIC protocol against connections issues
SET DISABLED IN
chrome://flags/#hardware-media-key-handling
chrome://flags/#global-media-controls
chrome://flags/#enable-quic
SET ENABLED IN
chrome://flags/#tab-groups
chrome://flags/#privacy-settings-redesign
chrome://flags/#omnibox-context-menu-show-full-urls
SET ENABLED (mark as actively dangerous) IN
chrome://flags/#enable-mark-http-as
I like it, ‘cause there’s nuthin’ like tryin’ to tweak a “proprietary/closed/blob” app.?
Thanks, bspwm edition uses chromium by default, and this might be helpful in developing settings for it.
Ooh, I discovered that you can also set overlay scrollbars from here. It’s going to take me a while to find out how to package these :smiley:
How do we feel about
#num-raster-threads
(can speed loading of images?)
And TCP Fast Open?
#enable-tcp-fast-open
"… enables the option to send some extra authentication information in the initial SYN packet for a previously connected client, allowing faster data send start"
I also use
#enable-fast-unload
"… runs a tab’s onunload js handler independently of the GUI."
  • following original descriptions.
  • added new flags
EDIT 20180212
  • removed #overlayscrollbars due issues with text areas.
Can all of these switches be enabled via --arguments in front of the executable?
Yep. For example:
/opt/google/chrome/google-chrome --flag-switches-begin --enable-experimental-canvas-features --enable-fast-unload --javascript-harmony --enabled-new-style-notification --enable-quic --site-per-process --enable-tcp-fastopen --ignore-gpu-blacklist --save-page-as-mhtml --enable-smooth-scrolling --enable-features=MaterialDesignExtensions,OmniboxDisplayTitleForCurrentUrl,OmniboxTailSuggestions,OmniboxUIExperimentShowSuggestionFavicons,OmniboxUIExperimentVerticalLayout,SecondaryUiMd --disable-features=MaterialDesignBookmarks --flag-switches-end
Do you know how to enable them with a settings file? I would like to package some of them
See
https://wiki.archlinux.org/index.php/Chromium/Tips_and_tricks#Making_flags_persistent
In my previous post I shared command line options from chrome://version site.
See (wiersz poleceń = command line):
I found that to have all the remaining options green enabled in chrome://gpu requires:
–enable-zero-copy
–enable-gpu-rasterization
–enable-native-gpu-memory-buffers
features=CheckerImaging
@ryanmusante I followed by this:
--flag-switches-begin --enable-experimental-canvas-features --enable-fast-unload --javascript-harmony --enabled-new-style-notification --enable-quic --site-per-process --enable-tcp-fastopen --ignore-gpu-blacklist --save-page-as-mhtml --enable-smooth-scrolling -–enable-zero-copy -–enable-gpu-rasterization --enable-native-gpu-memory-buffers --enable-features=CheckerImaging,MaterialDesignExtensions,OmniboxDisplayTitleForCurrentUrl,OmniboxTailSuggestions,OmniboxUIExperimentShowSuggestionFavicons,OmniboxUIExperimentVerticalLayout,SecondaryUiMd --disable-features=MaterialDesignBookmarks --flag-switches-end
aaaaand:
So, for ENABLE full GPU boost you need add CheckerImaging in enable-features flag:
And Other flags:
Regards
EDIT:
I updated 1st main topic with GPU tweaks
How do I enable a similar conf file for Vivaldi browser?
Please ask directly here: https://forum.vivaldi.net/category/35/vivaldi-browser-for-linux
I found JSON database with settings, but this is HARDCORE :scream:
Oh gosh. I’ll just put the arguments in front of the executable, much easier. :smile:
Updated, revised. Please follow NEW guide in 1st comment.
See this funny bug for a funny flag:
https://bugs.chromium.org/p/chromium/issues/detail?id=824153#c39
Specifically:
OK, I think I see why the flag has no effect. By default, subpixel positioning was enabled: https://chromium.googlesource.com/codesearch/chromium/src/+/bcaef32a5863/ui/gfx/font_render_params.h#58
Next, if no command line flag was supplied, font_render_params_linux.cc was overwriting that default value for desktop Linux case using the device scale factor check result: https://chromium.googlesource.com/codesearch/chromium/src/+/bcaef32a5863/ui/gfx/font_render_params_linux.cc#289
With the command line flag it would do nothing in this block and use the default value (true), so funnily, in the current release of Chromium/Chrome, adding the --disable-font-subpixel-positioning flag has the effect of enabling subpixel positioning (aka same effect as my patches), the complete opposite to flag's name, for all the wrong reasons :smiley:
  • Compatibility for Chrome 83.0.4103.61 2020-05-27
