I have tried three distributions:
Fedora
Linuxfx
Endeavors
With all three I get it to boot, but in the boot process an error always appears and does not complete.
What I have learned is that the custom.cfg file has to look something like this:
menuentry 'Endeavoros Live' --class os --class gnu-linux --class gnu --class os --group group_main {
set isofile = "/ live / Endeavouros.iso"
set dri = "free"
set lang = "es_ES"
set keytable = "es"
set timezone = "Europe / Madrid"
search --no-floppy -f --set = root $ isofile
probe -u $ root --set = abc
insmod gzio
insmod part_gpt
insmod xfs
insmod loopback
insmod iso9660
loopback loop ($ root) $ isofile
search --no-floppy --fs-uuid --set = root 9144410b-9b1b-48b5-909b-0195a8dd1f94
linux (loop) / arch / boot / x86_64 / vmlinuz-linux boot = live fromiso = / dev / nvme0n1p6 / $ isofile noconfig = sudo username = root hostname = endeavouros
initrd (loop) /arch/boot/x86_64/archiso.img
You have to take into account the file system where you have the iso file, to put the corresponding insmod and the type of partition as well. First you have to find out what the grub.cfg file of the iso file is like, to know in which path and what binary (usually vmlinuz) it uses to boot, but as you can see, Endeavoros uses vmlinuz-linux and what image it uses. What I have done is mount the iso file in the file manager and thus be able to see all this that I just mentioned. I also advise you to put this line like this: loopback loop ($ root) $ isofile
Because if you have several HD on the computer, as is my case, you will not have to find out if it is (hd5, gpt6) as is my case, or another, this way you can forget.
I have not managed to get any of the three start, but I will continue investigating and if I discover something interesting or od I will comment on it.
Thanks everyone for your help.
Anyone had a try at adding the Hiren Boot CD as a menu entry? I tried but failed as I don’t understand what I’m doing. I can boot it from USB when needed (for motherboard Windows tool for example), but it would be cool to be able to add it to GRUB directly for convenience and performance.
“insmod” does not seem to work and the help says it wants a filename and args.and is probably why it doesn’t work.
Any other commands to tell it about file systems?
It still works, but would like to get rid of the warnings.
:: Mounting '' to /run/miso/img_dev'
Waiting 30 seconds for device ...
ERROR: '' device did not show up after 30 seconds...
Apparently this set pqr="/dev/disk/by-uuid/$abc" bit fails, but I don’t know how to fix it.
I figured it out. It’s no longer possible to boot from an ntfs drive, because there is no ntfs driver since kernel 5.15 - it’s called ntfs3 now and that causes issues like this.
