4-5 times a day I rebooting my pinephone.
5 No localization - I installed Pure Maps, and I can’t use this app
There is no Bulgarian language and keyboard layout for Bulgarian (for example traditional phonetic ). Now I use a Russian keyboard for Cyrillic.
Manjaro ARM
KDE Plasma Verison : 5.21.5
KDE Fframeworks Version : 5.82.0
Kernel Version : 5.12.7-2 - MANJARO-ARM
I installed latest dev image. No missed calls, no alarm sound, no Bulgarian keyboard and finally after update by Discover… after logging – black screen…I will reinstall again.
With plasma mobile I have same problems
(PinePhone not showing me name, only number of incoming calls, with Spacebar I can write SMS messages only to people that already sent me one - or I have to use something like ofonoctl sms and write it in nano - which I can’t do without an external keyboard because I don’t know how to use Ctrl key on a virtual keyboard…)
I actually can’t get my cellular data working even if I try all ofonoctl commands (e.g. sudo ofonoctl wan --connect --append-dns)
I have also a problem with my external keyboard - it is just in English and I can’t find a way to change it to Czech layout like I did easily with the virtual keyboard - It would be great If it was automatically the same layout as the virtual keyboard…
I found a workaround to get log of missed calls that were notified (NOT which didn’t notify or ring):
Create a file to store call logs: touch Calls.log.
Enter in terminal: kcmshell5 kcm_notifications.
Go to Applications:Configure….
Go to Phone.
Go to Configure Events….
Chose Ringing option at the top.
Mark Log to a file and chose the “Calls.log” file you created.
Note, this also logs answered calls together without distinguishing, you may get confused. There is also Missed Call event there but that doesn’t seem working. Maybe wait until the upstream fixes it…
