Hello buddy, Recently I converted in Manjaro from Ubuntu.
On ubuntu I was using imwheel smothly but I’m not familiar with manjaro,
does know someone how will setup imwheel also with startup application?
Hi @Imran,
imwheel
is in the community
repository:
$ pamac search imwheel
imwheel 1.0.0pre12-6 community
Mouse wheel configuration tool for XFree86/Xorg
So it can be installed using:
pamac install imwheel
Regarding automatic startup, if it doesn’t already do it automatically you should be able to add it via Launcher → System settings → Workplace → Startup and shutdown → Autostart, and clicking the Add in the bottom.
Hope it helps!
