My laptop heats up and drains the battery on suspend mode in linux but I noticed similar battery draining in Windows but no heating of the laptop.
Here is inxi --admin --verbosity=7 --filter --width
Kernel: 5.19.0-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=dae9727b-8cef-4e55-b5e1-9f5533258a08 rw quiet splash
vt.global_cursor_default=0 udev.log_priority=3
Desktop: KDE Plasma v: 5.24.6 tk: Qt v: 5.15.5 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-dw3xxx v: Type1ProductConfigId
Mobo: HP model: 881D v: 50.29 serial: <superuser required> UEFI: Insyde
v: F.54 date: 05/11/2022
ID-1: BAT1 charge: 40.2 Wh (100.0%) condition: 40.2/41.0 Wh (98.0%)
volts: 12.9 min: 11.3 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
RAM: total: 7.51 GiB used: 3.47 GiB (46.3%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: 11th Gen Intel Core i3-1125G4 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 built: 2020 process: Intel 10nm family: 6
model-id: 0x8C (140) stepping: 1 microcode: 0xA4
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB desc: 4x1.2 MiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 2000 min/max: 400/3700 scaling: driver: intel_pstate
governor: powersave cores: 1: 2000 2: 2000 3: 2000 4: 2000 5: 2000 6: 2000
7: 2000 8: 2000 bogomips: 31960
arch_capabilities arch_perfmon art avx avx2 avx512_bitalg avx512_vbmi2
avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
avx512dq avx512f avx512ifma avx512vbmi avx512vl bmi1 bmi2 bts cat_l2
cdp_l2 clflush clflushopt clwb cmov constant_tsc cpuid cpuid_fault cx16
cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fsrm fxsr gfni ht hwp hwp_act_window hwp_epp
hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe movdir64b
movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq pdcm
rdt_a rdtscp rep_good sdbg sep sha_ni smap smep split_lock_detect ss ssbd
sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
tsc_adjust tsc_deadline_timer tsc_known_freq umip vaes vme vmx vnmi
vpclmulqdq vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel vendor: Hewlett-Packard driver: i915 v: kernel
arch: Gen-12.1 process: Intel 10nm built: 2020-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 0000:00:02.0
chip-ID: 8086:9a78 class-ID: 0300
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:2 chip-ID: 0408:5365 class-ID: 0e02
Display: x11 server: X.Org v: 21.1.4 compositor: kwin_x11 driver: X:
loaded: modesetting unloaded: fbdev alternate: vesa gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: AU Optronics 0x3791 built: 2020 res: 1920x1080
hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64") diag: 395mm (15.5")
ratio: 16:9 modes: 1920x1080
OpenGL: renderer: Mesa Intel UHD Graphics (TGL GT2) v: 4.6 Mesa 22.1.4
direct render: Yes
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
chip-ID: 8086:a0c8 class-ID: 0401
Sound Server-1: ALSA v: k5.19.0-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.56 running: yes
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 0000:00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
vendor: Hewlett-Packard driver: r8168 v: 8.050.03-NAPI modules: r8169
port: 3000 bus-ID: 0000:01:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-10:4 chip-ID: 8087:0026 class-ID: e001
Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
Local Storage: total: 238.47 GiB used: 22.43 GiB (9.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN530
SDBPNPZ-256G-1006 size: 238.47 GiB block-size: physical: 512 B
rev: HPS2 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 64 GiB size: 62.44 GiB (97.57%) used: 22.35 GiB (35.8%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: dae9727b-8cef-4e55-b5e1-9f5533258a08
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%) used: 81.4 MiB
(31.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: SYSTEM
uuid: 60E2-68A1
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 173.68 GiB fs: bitlocker
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 529 MiB fs: ntfs label: Windows
RE tools uuid: 762C89132C88D013
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Quanta HP TrueVision HD Camera type: Video
Device-2: 1-6:3 info: Elan Micro ELAN:ARM-M4 type: <vendor specific>
driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s power: 100mA
chip-ID: 04f3:0c00 class-ID: 0000
Device-3: 1-10:4 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 258 Uptime: 15m wakeups: 4701 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.1.1 clang: 14.0.6
Packages: 1281 pacman: 1279 lib: 335 flatpak: 0 snap: 2 Shell: Zsh v: 5.9
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.20
Any help will be appreciated.
