How to use Preformated text ? other than ``` I think im using it wrong
In which context?
when i click on it i get
this indent preformatted text by 4 spaces
yep - that is correct
you can prepend lines - multiple lines with 4 spaces - this equals a fence of 3 back ticks before first line and after last line.
if you fence a block of space indented lines the spaces are treated are as literal chars - thus indenting the lines inside the fence.
its not working
where should my text be ?
This is a 4 space indented line
This is a 4 space indented block
With multiple lines
This is a fenced block
With multiple lines
With multiple lines
but with code fence three back ticks
**before** first line and **after** last line
And as you can see everything is fenced.
To see the raw version of the this comment
Thank you for explaining that
but its not working for me
so i will just use ```
If it is not working for you - then you do not have four spaces - and code fence vs. indent will behave differently if not placed on separate lines.
You can also use single backtick to make
a single word in a sentence stand as code.
Thank u very useful Link
so i can understand better
