The first result:
Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ec779e91-f4d7-494e-925a-dd52a1046a8c rw quiet apparmor=1
Desktop: Cinnamon v: 6.0.4 tk: GTK v: 3.24.42 wm: Muffin v: 6.0.1
tools: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
base: Arch Linux
Type: Laptop System: Micro-Star product: GF63 Thin 10SCXR v: REV:1.0
Mobo: Micro-Star model: MS-16R4 v: REV:1.0 serial: <superuser required>
part-nu: 16R4.1 uuid: <superuser required> UEFI: American Megatrends
v: E16R4IMS.105 date: 04/17/2020
ID-1: BAT1 charge: 34.7 Wh (100.0%) condition: 34.7/51.3 Wh (67.6%)
volts: 12.7 min: 11.4 model: MSI Corp. MS-16R4 type: Li-ion serial: N/A
status: full
System RAM: total: 32 GiB available: 31.17 GiB used: 2.24 GiB (7.2%)
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
speed: 2667 MT/s volts: note: check curr: 1 min: 1 max: 1 width (bits):
data: 64 total: 64 manufacturer: Crucial part-no: CT16G4SFRA266.C8FE
serial: <filter>
Device-2: ChannelB-DIMM0 type: DDR4 detail: synchronous size: 16 GiB
serial: <filter>
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
gen: core 10 level: v3 note: check built: 2020 process: Intel 14nm family: 6
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 809 high: 912 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 912 4: 800
5: 800 6: 800 7: 800 8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs
ibrs_enhanced ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: retbleed mitigation: Enhanced IBRS
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
ports: active: HDMI-A-2 off: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Micro-Star MSI driver: nvidia v: 550.90.07
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-06; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1f99 class-ID: 0302
Display: x11 server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0 driver: X:
loaded: modesetting,nvidia alternate: fbdev,nouveau,nv,vesa dri: iris
gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-size: <missing: xdpyinfo>
Monitor-1: HDMI-A-2 mapped: HDMI-2 pos: primary model: Samsung S24E650
serial: <filter> built: 2016 res: 1920x1200 hz: 60 dpi: 94 gamma: 1.2
size: 518x324mm (20.39x12.76") diag: 611mm (24.1") ratio: 16:10 modes:
max: 1920x1200 min: 640x480
Monitor-2: eDP-1 note: disabled model: AU Optronics 0xaf90 built: 2020
res: 1920x1200 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6")
diag: 394mm (15.5") ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: kms_swrast
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.9-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (CML GT2)
device-ID: 8086:9bc4 memory: 30.44 GiB unified: yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci_intel_cnl
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: GN Netcom Lenovo Pro Wired Stereo VoIP Headset
driver: jabra,snd-usb-audio,usbhid type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 1-3.1.1:6 chip-ID: 0b0e:a800 class-ID: 0300
serial: <filter>
API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.0.7 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:3 chip-ID: 8087:0026
class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
hardware: no software: no address: see --recommends
Local Storage: total: 1.38 TiB used: 8.19 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3512GJ5 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: E8FK12.D temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
tech: HDD rpm: 5400 serial: <filter> fw-rev: 0001 scheme: GPT
ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 8.19 GiB (1.7%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: ec779e91-f4d7-494e-925a-dd52a1046a8c
used: 296 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: C0AF-3B99
ID-1: /dev/sda1 maj-min: 8:1 size: 300 MiB fs: vfat label: N/A
uuid: FF3C-41DF
ID-2: /dev/sda2 maj-min: 8:2 size: 238.42 GiB fs: ext4 label: N/A
uuid: 8c572459-880d-4989-b5e0-96ed99d23fa6
ID-3: /dev/sda3 maj-min: 8:3 size: 8.8 GiB fs: swap label: N/A
uuid: 42569afe-0e3a-49ef-9c01-93d866fdac4a
ID-4: /dev/sda4 maj-min: 8:4 size: 684 GiB fs: ext4 label: misc
uuid: f417ae0c-6b9f-45d7-affb-827b6ad26286
Hub-2: 1-3:2 info: Genesys Logic Hub ports: 4 rev: 2.1
Hub-3: 1-3.1:4 info: Genesys Logic Hub ports: 4 rev: 2.1
Device-1: 1-3.1.1:6 info: GN Netcom Lenovo Pro Wired Stereo VoIP Headset
type: audio,HID driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
chip-ID: 0b0e:a800 class-ID: 0300 serial: <filter>
Device-2: 1-3.1.2:7 info: Lenovo Traditional USB Keyboard
type: keyboard,HID driver: hid-generic,usbhid interfaces: 2 rev: 2.0
chip-ID: 17ef:6099 class-ID: 0300
Device-3: 1-3.3:5 info: Logitech Optical Wheel Mouse type: mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 046d:c016 class-ID: 0301
Device-4: 1-14:3 info: Intel AX201 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0026 class-ID: e001
Hub-4: 2-0:1 info: super-speed hub ports: 8 rev: 3.1
Hub-5: 2-3:2 info: Genesys Logic Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0626
Hub-6: 2-3.1:3 info: Genesys Logic Hub ports: 4 rev: 3.2
System Temperatures: cpu: 45.0 C pch: 52.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 320 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: csd-power,upowerd
Init: systemd v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1044 libs: 293 tools: pamac pm: flatpak pkgs: 0
Compilers: N/A Shell: Bash v: 5.2.26 running-in: gnome-terminal inxi: 3.3.35
The second:
echo $XDG_SESSION_TYPE && glxinfo | grep server
x11
server glx vendor string: SGI
server glx version string: 1.4
server glx extensions:
