Hello everyone!
I just loaded the module with sudo modprobe snd-dummy
But when I wanna unload it with sudo modprobe -r snd-dummy
modprobe: FATAL: Module snd_dummy is in use.
I searched a lot and tried lots of things. No luck…
Hello everyone!
option “-r” shall unload it, what you intended to say?
Sorry I edited it
Please post output of the follwong command:
lsmod | grep snd_dummy
You will get a list like this:
module size used_by
Try unloading the “used_by” modules before or together with the module you want to unload.
If you want to prevent a module from loading at the next boot, add it to a blacklist:
/etc/modprobe.d/blacklist.conf
Thanks!
Output:
snd_dummy 28672 4
snd_pcm 147456 6 snd_hda_intel,snd_hda_codec,snd_hda_core,snd_dummy
snd 114688 20 snd_hda_codec_generic,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm,snd_dummy
Unfortunately, I can’t unload them. When I type sudo modprobe -r snd_hda_codec_generic
Use this command to blacklist the module
echo 'blacklist snd_dummy' | sudo tee -a /etc/modprobe.d/blacklist.conf
and reboot system
The module is not loaded on the next boot
My problem is to unload it on the current session
