How to uninstall .run file?
#1
I downloaded xampp-*.run file the last time because I had problem installing it in aur…but the last update has a graphical interface that can change the build dir…so my first problem has been solved…I’ve installed it…but I forgot that I still have the .run file installed in the system…so yeah…now… that’s my another problem…how to remove it completely in the system including its folders and files?..sorry for my grammar
#2
You can check if the installer has an option to uninstall via checking help (-h or --help) or simply remove /opt/lampp folder. See also here.
#3
