How to type ñ/á/é/í/ó/ú Spanish letters on a US layout keyboard?
Hello everyone,
I’ve recently switched my keyboard layout to the standard US layout (on Manjaro Linux) so I can use a modal editor more effectively. Now I’m running into trouble typing Spanish-specific characters: ñ, Ñ, and accented vowels (á, é, í, ó, ú).
Could you please suggest how to configure my system so I can type those characters while keeping the US layout?
Thanks in advance!
Hi @Individual-Heart-719,
I believe what you’re looking for is the Compose key. Have a look here:
@Individual-Heart-719 use the link that @Mirdarthos linked above and in conjunction with the cinnamon settings for keyboards > select the key you wish to use for the Compose Key, in my case, I use the Right Alt key etc.
Here’s how you can enable a Compose Key in Cinnamon on Manjaro Linux so that you can type Spanish letters (ñ, á, é, etc.) with a US‑layout keyboard. I’ll include a GUI method + a fallback via terminal/config files.
GUI method (simplest)
  1. Open SettingsKeyboard (or Keyboard & Mouse) in Cinnamon.
  2. Go to the Layouts tab (or Input Sources / Layouts depending on version).
  3. Click the Options… button.
  4. Expand the section Position of Compose Key.
  5. Choose a key you don’t normally use (e.g., Right Alt, Right Ctrl, Menu, CapsLock) to act as the Compose key. (Ask Ubuntu)
  6. Apply/OK and close. Now: to type e.g. “á” you press then ' then a. For “ñ” you might press then ~ then n.
Fallback / Terminal method
If the GUI doesn’t work (or you prefer config), you can edit keyboard configuration:
  1. In a terminal, run something like:
    setxkbmap -option compose:ralt
    This sets Right Alt as your Compose key. (Arch Linux Forums)
  2. To make it persistent, edit (or create) a file such as /etc/X11/xorg.conf.d/00-keyboard.conf (or similar) and include something like:
    Section "InputClass"
      Identifier "system-keyboard"
      MatchIsKeyboard "on"
      Option "XkbOptions" "compose:ralt"
    EndSection
    (Manjaro Linux Forum)
  3. Alternatively, you can add it to your user profile login scripts: e.g., in ~/.xprofile etc., but note some display managers may ignore these. (Arch Linux Forums)
Tips specific for Spanish and US layout
  • Using a Compose key lets you keep the US (English) layout for the keyboard but still type accented Spanish letters easily.
  • Example sequences: + ~ + n → ñ ; + ' + a → á ; + " + e → ë ; etc. (see full list of sequences) (It’s FOSS)
  • If you also often type Spanish letters, you might consider using the “US International (with dead keys)” layout instead of plain US, but if you prefer a Compose key, the above works well.
