In “System Settings”, I set “Colors” to “Breeze Dark”, and that changed most of the green coloring to blue. So far, so good.
However, the panel icon for Dolphin, and also the Manjaro icon for Application launcher, is still green.
Anything to do about that?
Set global theme to Breeze Dark. It will apply default Plasma coloring/theming to the whole desktop, not apps only.
you can set it to any custom icon from right clicking it > configure application launcher > icon
Breeze Dark definitely works. It has a minor side effect that the package manager icon on the panel becomes invisible, at least when there are no updates. I don’t know what it will look like when updates are available. If it becomes visible, that would actually be ideal.
Strangely enough, I came back to my computer and found that the package manager icon became visible.
I think you should relogin so it will be visible or something like that.
