Are the free driver installed?
mhwd -li
mhwd -li
@megavolt output of mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
but… should be:
blacklist nouveau
nouveau = Name of free driver (… sorry
Remove this
from the the kernel parameter. ![]()
No change
cough how would one remove nomodeset from the kernel parameters?
In /etc/default/grub remove it and then sudo update-grub.
should I change
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3 nomodeset"
to
GRUB_CMDLINE_LINUX_DEFAULT="quiet apparmor=1 security=apparmor udev.log_priority=3"
No change in behavior
So these files does not exist correct? at least in xorg.conf.d/ there should be only 00-keyboard.conf
currently just that and the 20-radeon.conf suggested earlier
xorg.conf exists:
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig: version 450.80.02
# nvidia-settings: X configuration file generated by nvidia-settings
# nvidia-settings: version 440.100
Section "ServerLayout"
Identifier "Layout0"
Screen 0 "Screen0" 0 0
InputDevice "Keyboard0" "CoreKeyboard"
InputDevice "Mouse0" "CorePointer"
Option "Xinerama" "0"
EndSection
Section "Files"
EndSection
Section "InputDevice"
# generated from default
Identifier "Mouse0"
Driver "mouse"
Option "Protocol" "auto"
Option "Device" "/dev/psaux"
Option "Emulate3Buttons" "no"
Option "ZAxisMapping" "4 5"
EndSection
Identifier "Keyboard0"
Driver "kbd"
EndSection
Section "Monitor"
Identifier "Monitor0"
VendorName "Unknown"
ModelName "ViewSonic XG2402 SERIES"
HorizSync 160.0 - 160.0
VertRefresh 48.0 - 146.0
Option "DPMS"
EndSection
Section "Device"
Identifier "Device1"
Driver "vesa"
VendorName "AMD"
BoardName "RX 580"
EndSection
Section "Screen"
Identifier "Screen0"
Device "Device0"
Monitor "Monitor0"
DefaultDepth 24
Option "Stereo" "0"
Option "nvidiaXineramaInfoOrder" "DFP-2"
Option "metamodes" "DP-0: 1920x1080_144 +1920+0, DVI-D-0: nvidia-auto-select +0+0, HDMI-0: 1920x1080 +3840+0"
Option "SLI" "Off"
Option "MultiGPU" "On"
Option "BaseMosaic" "off"
SubSection "Display"
Depth 24
EndSubSection
EndSection
R-E-M-O-V-E
I am not mad… the conversation is just very fast for a forum where you have to think… xD
LOL, I’m still a lamb… okay I removed both /etc/X11/xorg.conf and /etc/X11/xorg.conf.d/20-radeon.conf and NOW IT WORKS!!!
thanks @megavolt <3
p.s. for others like me (very naive) you can, from the command line / ssh do the following for easier debugging
sudo su // enter super user state
xinit // which logs to /etc/logs/Xorg.0.log
Btw… LOL … here is the problem… You used nvidia options with the amd gpu… no wonder it does not work xD On top you used vesa as driver… it is a generic driver for every gpu with very basic functionality… means only the terminal ![]()
