Hi. KDE Plasma (I guess) starts autoplaying youtube-videos from last active yt-tab or last VLC-track (that were stopped beforhand), after I activated my bluetooth-headset to pick up a phonecall and hang up. When it connects the usual way, there is no issue. I really want to stop that behaviour - and no, closing the yt-tab is not an option, sorry.
Thanks a lot for your help!
System-infos from inxi:
Kernel: 4.14.219-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: \vmlinuz-4.14-x86_64
cryptdevice=UUID=0191ff3e-4c21-4388-8f3b-a0d93a4f6fc6:crypt_dev
root=/dev/mapper/LVM_SSD-root ro initrd=\initramfs-4.14-x86_64.img
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20BVCT01WW v: ThinkPad T450
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20BVCT01WW v: 0B98417 WIN serial: <filter> UEFI: LENOVO
v: JBET64WW (1.28 ) date: 03/16/2017
ID-1: BAT0 charge: 10.1 Wh condition: 10.2/23.5 Wh (43%) volts: 12.4/11.4
model: LGC 45N1113 type: Li-ion serial: <filter> status: Unknown
ID-2: BAT1 charge: 13.2 Wh condition: 13.5/23.5 Wh (57%) volts: 12.6/11.4
model: LGC 45N1127 type: Li-ion serial: <filter> status: Unknown
Info: Dual Core model: Intel Core i5-5200U bits: 64 type: MT MCP
arch: Broadwell family: 6 model-id: 3D (61) stepping: 4 microcode: 24
L2 cache: 3 MiB
bogomips: 17566
Speed: 823 MHz min/max: 500/2700 MHz Core speeds (MHz): 1: 823 2: 840 3: 811
4: 861
Type: l1tf
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT vulnerable
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:1616 class ID: 0300
Device-2: Chicony Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:5
chip ID: 04f2:b449 class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7")
diag: 354mm (13.9")
OpenGL: renderer: llvmpipe (LLVM 11.0.1 256 bits) v: 4.5 Mesa 20.3.4
compat-v: 3.1 direct render: Yes
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:03.0 chip ID: 8086:160c class ID: 0403
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
driver: snd_hda_intel v: kernel bus ID: 00:1b.0 chip ID: 8086:9ca0
class ID: 0403
Sound Server: ALSA v: k4.14.219-1-MANJARO
Device-1: Intel Ethernet I218-V vendor: Lenovo driver: e1000e v: 3.2.6-k
port: 3080 bus ID: 00:19.0 chip ID: 8086:15a3 class ID: 0200
IF: enp0s25 state: down mac: <filter>
Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel port: efa0
bus ID: 03:00.0 chip ID: 8086:095b class ID: 0280
bus ID: 1-7:6 chip ID: 8087:0a2a class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Local Storage: total: 476.94 GiB used: 80.3 GiB (16.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SD7SB2Q512G1001
size: 476.94 GiB block size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
rotation: SSD serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw size: 40 GiB size: 39.12 GiB (97.81%) used: 31.95 GiB (81.7%)
fs: ext4 dev: /dev/dm-1 maj-min: 254:1 mapped: LVM_SSD-root
ID-2: /boot raw size: 511 MiB size: 510.7 MiB (99.95%) used: 199 MiB (39.0%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 420 GiB size: 412.41 GiB (98.19%)
used: 48.16 GiB (11.7%) fs: ext4 dev: /dev/dm-2 maj-min: 254:2
mapped: LVM_SSD-home
System Temperatures: cpu: 50.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0
Processes: 191 Uptime: 3h 01m wakeups: 3 Memory: 15.55 GiB
used: 3.56 GiB (22.9%) Init: systemd v: 247 Compilers: gcc: 10.2.0 Packages:
pacman: 1706 lib: 425 flatpak: 0 Shell: Zsh v: 5.8 running in: yakuake
inxi: 3.3.01
