How to start with Manjaro minimal
#1
I just flashed Manjaro Raspberry Pi 3 minimal, and got the prompt screen, how to start! how to setup the Wifi, and static IP, and connect SSH from my PC?
#2
You can use wifi-menu to set up the Wifi.
SSH is through normal means, like any other distro. It is already enabled for your user though.
Static IP, is that with ethernet?
If so, that is defined in /etc/systemd/network/20-wired.network
#3
How to get into the wifi- menu?
#4
Run the command wifi-menu...
