How to setup Preload?
how to setup preload. 2 days ago downloaded form pamac store. but how to setup and how to check working or not?
https://wiki.archlinux.org/title/Preload
personal opinion:
One thing I noticed - which is unavoidable on a distro like Manjaro or Arch with it’s ever changing files, because it’s frequently updated -
is that the effect will be rather small (timewise)
and the “learning” phase of that program will have to be repeated often
because the files that the program “learned” to preload
do frequently change.
It does not seem to be a good use of time (for me - in my opinion) to spend the time “teaching” the program
when that step has to be repeated fairly regularly in order for the program to get you some minor gain in loading time.
See the forum post linked to in the pkgbuild of gopreload-git:
Gentoo Forums :: View topic - GOPreload
