System freeze after wake up from suspend
There seems to be other people with the same problem but none provide a solution.
Sometimes when waking up after suspend the system freezes with the CAPS lock LED flashing. There is no way of rebooting the computer. REISUB doesn’t work, power button doesn’t work (even if pressing it for a while) and the only way recover was to unplug the power and wait for the battery to drain. “Fortunately” I discovered I have a small pin opening on the case of the laptop that allows to briefly disconnect the battery.
Tried older kernels (4.19/5.4) but they behave the same.
Crashes seem to be more frequent too. It happened before once in a blue moon but of late it has been once a week and today it has done it twice.
Results of inixi -Fza:
System:    Kernel: 5.8.11-1-MANJARO x86_64 bits: 64 compiler: N/A
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.8-x86_64 root=UUID=4fc9ec4c-2db3-4009-89d9-131f97cbc022 rw quiet
           resume=UUID=12be5ddb-10e3-4ad8-ae1e-164a24687f25 apparmor=1 security=apparmor sysrq_always_enabled=1
           Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.1 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine:   Type: Laptop System: SAMSUNG product: 700Z3C/700Z5C v: 0.1 serial: <filter> Chassis: type: 9 v: 0.1
           serial: <filter>
           Mobo: SAMSUNG model: 700Z3C/700Z5C v: FAB1 serial: <filter> UEFI [Legacy]: Phoenix v: P02AAG date: 04/26/2012
Battery:   ID-1: BAT1 charge: 3.6 Wh condition: 51.8/65.1 Wh (80%) volts: 15.2/14.8 model: SAMSUNG Electronics type: Li-ion
           serial: N/A status: Charging
CPU:       Topology: Dual Core model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge family: 6 model-id: 3A (58)
           stepping: 9 microcode: 21 L2 cache: 3072 KiB
           flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19962
           Speed: 1399 MHz min/max: 1200/3100 MHz Core speeds (MHz): 1: 1380 2: 1349 3: 1197 4: 1198
           Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
           Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: conditional, RSB filling
           Type: srbds status: Vulnerable: No microcode
Graphics:  Device-1: Intel 3rd Gen Core processor Graphics vendor: Samsung Co driver: i915 v: kernel bus ID: 00:02.0
           chip ID: 8086:0166
           Device-2: NVIDIA GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M] vendor: Samsung Co driver: N/A
           alternate: nouveau bus ID: 01:00.0 chip ID: 10de:1140
           Device-3: Silicon Motion type: USB driver: uvcvideo bus ID: 1-1.4:4 chip ID: 2232:1018
           Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: modesetting alternate: fbdev,intel,vesa
           display ID: :0 screens: 1
           Screen-1: 0 s-res: 3520x1080 s-dpi: 96 s-size: 931x285mm (36.7x11.2") s-diag: 974mm (38.3")
           Monitor-1: LVDS-1 res: 1600x900
           Monitor-2: HDMI-1 res: 1920x1080 hz: 60 dpi: 96 size: 509x286mm (20.0x11.3") diag: 584mm (23")
           OpenGL: renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2) v: 4.2 Mesa 20.1.8 compat-v: 3.0 direct render: Yes
Audio:     Device-1: Intel 7 Series/C216 Family High Definition Audio vendor: Samsung Co driver: snd_hda_intel v: kernel
           bus ID: 00:1b.0 chip ID: 8086:1e20
           Sound Server: ALSA v: k5.8.11-1-MANJARO
Network:   Device-1: Intel Centrino Advanced-N 6235 driver: iwlwifi v: kernel port: 3000 bus ID: 02:00.0 chip ID: 8086:088e
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Samsung Co driver: N/A modules: r8169
           port: 2000 bus ID: 03:00.0 chip ID: 10ec:8168
Drives:    Local Storage: total: 938.98 GiB used: 592.11 GiB (63.1%)
           ID-1: /dev/sda vendor: Seagate model: ST1000LM024 HN-M101MBB size: 931.51 GiB block size: physical: 4096 B
           logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 0002 scheme: MBR
           ID-2: /dev/sdb vendor: SanDisk model: iSSD P4 8GB size: 7.46 GiB block size: physical: 512 B logical: 512 B
           speed: 3.0 Gb/s serial: <filter> rev: 9.14 scheme: MBR
Partition: ID-1: / raw size: 195.31 GiB size: 191.25 GiB (97.92%) used: 140.59 GiB (73.5%) fs: ext4 dev: /dev/sda3
Swap:      Kernel: swappiness: 60 (default) cache pressure: 100 (default)
           ID-1: swap-1 type: partition size: 7.72 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda8
Sensors:   System Temperatures: cpu: 71.0 C mobo: N/A
Info:      Processes: 210 Uptime: 4m Memory: 7.56 GiB used: 1.47 GiB (19.4%) Init: systemd v: 246 Compilers: gcc: 10.2.0
           alt: 8 clang: 10.0.1 Packages: pacman: 1935 lib: 456 flatpak: 0 Shell: Bash v: 5.0.18 running in: konsole
           inxi: 3.1.05
Latest crash Journalctl logs around the event:
-- Logs begin at Sat 2020-03-28 18:13:38 GMT, end at Wed 2020-10-28 19:33:39 GMT. --
Oct 28 18:00:01 Chronos7 audit[64663]: USER_ACCT pid=64663 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_time acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 audit[64663]: CRED_ACQ pid=64663 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_env acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 kernel: audit: type=1101 audit(1603908001.730:354): pid=64663 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_time acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 kernel: audit: type=1103 audit(1603908001.730:355): pid=64663 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_env acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 kernel: audit: type=1006 audit(1603908001.730:356): pid=64663 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=11 res=1
Oct 28 18:00:01 Chronos7 crond[64663]: pam_unix(crond:session): session opened for user sebastien(uid=1000) by (uid=0)
Oct 28 18:00:01 Chronos7 audit[64663]: USER_START pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_limits,pam_unix acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 audit[64663]: CRED_REFR pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_env acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 kernel: audit: type=1105 audit(1603908001.730:357): pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:session_open grantors=pam_loginuid,pam_limits,pam_unix acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 kernel: audit: type=1110 audit(1603908001.730:358): pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_env acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:01 Chronos7 CROND[64664]: (sebastien) CMD (/usr/bin/nice -n19 /usr/bin/ionice -c2 -n7 /usr/bin/backintime backup-job >/dev/null)
Oct 28 18:00:02 Chronos7 audit[64663]: CRED_DISP pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_env acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:02 Chronos7 audit[64663]: USER_END pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_limits,pam_unix acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:02 Chronos7 CROND[64663]: pam_unix(crond:session): session closed for user sebastien
Oct 28 18:00:02 Chronos7 kernel: audit: type=1104 audit(1603908002.307:359): pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:setcred grantors=pam_unix,pam_env acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:02 Chronos7 kernel: audit: type=1106 audit(1603908002.307:360): pid=64663 uid=0 auid=1000 ses=11 subj==unconfined msg='op=PAM:session_close grantors=pam_loginuid,pam_limits,pam_unix acct="sebastien" exe="/usr/bin/crond" hostname=? addr=? terminal=cron res=success'
Oct 28 18:00:02 Chronos7 python[64673]: backintime (sebastien/1): INFO: Lock
Oct 28 18:00:02 Chronos7 org_kde_powerdevil[1587]: powerdevil: Scheduling inhibition from ":1.254" "/usr/share/backintime/common/backintime.py" with cookie 15 and reason "take snapshot"
Oct 28 18:00:03 Chronos7 kdeinit5[64682]: Qt: Session management error: networkIdsList argument is NULL
Oct 28 18:00:07 Chronos7 org_kde_powerdevil[1587]: powerdevil: Enforcing inhibition from ":1.254" "/usr/share/backintime/common/backintime.py" with cookie 15 and reason "take snapshot"
Oct 28 18:00:07 Chronos7 org_kde_powerdevil[1587]: powerdevil: Added interrupt session
Oct 28 18:00:07 Chronos7 org_kde_powerdevil[1587]: powerdevil: Can't contact ck
Oct 28 18:00:13 Chronos7 python[64673]: backintime (sebastien/1): ERROR: Ping 92.1.206.193 failed. Host is down or wrong address.
Oct 28 18:00:13 Chronos7 python[64673]: backintime (sebastien/1): INFO: Unlock
Oct 28 18:00:15 Chronos7 org_kde_powerdevil[1587]: powerdevil: Releasing inhibition with cookie  15
Oct 28 18:00:15 Chronos7 org_kde_powerdevil[1587]: powerdevil: Can't contact ck
Oct 28 18:01:01 Chronos7 CROND[64755]: (root) CMD (run-parts /etc/cron.hourly)
Oct 28 18:01:31 Chronos7 dolphin[61130]: Cannot initialize model with data QJsonObject() . missing: QJsonValue(string, "urls")
Oct 28 18:01:31 Chronos7 kdeinit5[64832]: kf.kio.slaves.tags: tag fetch failed: "Failed to open the database"
Oct 28 18:01:31 Chronos7 kdeinit5[64832]: kf.kio.slaves.tags: "tags:/" list() invalid url
Oct 28 18:01:35 Chronos7 systemd[1407]: Started app-emacs-010bdfee5afc42bd90ef9f96fc511da5.scope.
Oct 28 18:01:35 Chronos7 kwin_x11[1505]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 51591, resource id: 85983617, major code: 18 (ChangeProperty), minor code: 0
Oct 28 18:01:35 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:02:57 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:02:57 Chronos7 kwin_x11[1505]: qt.qpa.xcb: Unhandled client message:  "_NET_CURRENT_DESKTOP"
Oct 28 18:02:58 Chronos7 kwin_x11[1505]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 17122, resource id: 14774324, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 28 18:03:01 Chronos7 kwin_x11[1505]: qt.qpa.xcb: Unhandled client message:  "_NET_CURRENT_DESKTOP"
Oct 28 18:03:01 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:03:02 Chronos7 kwin_x11[1505]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 20168, resource id: 14850543, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 28 18:03:05 Chronos7 plasmashell[1537]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:26:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:03:05 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:03:05 Chronos7 systemd[1407]: Started app-thunderbird-3729197cd04a45b5a0159a367a0cd99f.scope.
Oct 28 18:03:18 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:03:25 Chronos7 plasmashell[1537]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:03:25 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:60:9: QML QQuickTextEdit: Binding loop detected for property "width"
Oct 28 18:03:25 Chronos7 plasmashell[1537]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:03:25 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:03:25 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:117:15: QML QQuickItem: Binding loop detected for property "height"
Oct 28 18:04:02 Chronos7 systemd-logind[1171]: Lid closed.
Oct 28 18:04:02 Chronos7 org_kde_powerdevil[1587]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("Type", QVariant(uint, 1)))
Oct 28 18:04:02 Chronos7 org_kde_powerdevil[1587]: powerdevil: Suspend session triggered with QMap(("Explicit", QVariant(bool, true))("SkipFade", QVariant(bool, true))("Type", QVariant(uint, 1)))
Oct 28 18:04:02 Chronos7 org_kde_powerdevil[1587]: powerdevil: Starting Login1 suspend job
Oct 28 18:04:02 Chronos7 org_kde_powerdevil[1587]: powerdevil: Pausing all media players before sleep
Oct 28 18:04:02 Chronos7 ModemManager[1194]: <info>  [sleep-monitor] system is about to suspend
Oct 28 18:04:02 Chronos7 NetworkManager[1168]: <info>  [1603908242.4841] manager: sleep: sleep requested (sleeping: no  enabled: yes)
Oct 28 18:04:02 Chronos7 NetworkManager[1168]: <info>  [1603908242.5439] manager: NetworkManager state is now ASLEEP
Oct 28 18:04:02 Chronos7 NetworkManager[1168]: <info>  [1603908242.5976] device (wlp2s0): state change: activated -> deactivating (reason 'sleeping', sys-iface-state: 'managed')
Oct 28 18:04:02 Chronos7 dbus-daemon[1167]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=1168 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 28 18:04:02 Chronos7 kded5[1501]: plasma-nm: Unhandled active connection state change:  3
Oct 28 18:04:02 Chronos7 systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 28 18:04:03 Chronos7 dbus-daemon[1167]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 28 18:04:03 Chronos7 systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 28 18:04:03 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 18:04:03 Chronos7 kernel: audit: type=1130 audit(1603908243.066:361): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 18:04:03 Chronos7 kernel: wlp2s0: deauthenticating from 34:db:9c:f7:10:e0 by local choice (Reason: 3=DEAUTH_LEAVING)
Oct 28 18:04:03 Chronos7 wpa_supplicant[1199]: wlp2s0: CTRL-EVENT-DISCONNECTED bssid=34:db:9c:f7:10:e0 reason=3 locally_generated=1
Oct 28 18:04:03 Chronos7 NetworkManager[1168]: <info>  [1603908243.4084] device (wlp2s0): state change: deactivating -> disconnected (reason 'sleeping', sys-iface-state: 'managed')
Oct 28 18:04:03 Chronos7 NetworkManager[1168]: <info>  [1603908243.4337] dhcp4 (wlp2s0): canceled DHCP transaction
Oct 28 18:04:03 Chronos7 NetworkManager[1168]: <info>  [1603908243.4338] dhcp4 (wlp2s0): state changed bound -> done
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Withdrawing address record for fdaa:bbcc:ddee:0:fa8:8cfc:4abe:4da4 on wlp2s0.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fdaa:bbcc:ddee:0:fa8:8cfc:4abe:4da4.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::70e3:564f:f231:868e.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Registering new address record for fe80::70e3:564f:f231:868e on wlp2s0.*.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Withdrawing address record for fe80::70e3:564f:f231:868e on wlp2s0.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::70e3:564f:f231:868e.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Interface wlp2s0.IPv6 no longer relevant for mDNS.
Oct 28 18:04:03 Chronos7 wpa_supplicant[1199]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=CORE type=WORLD
Oct 28 18:04:03 Chronos7 NetworkManager[1168]: <info>  [1603908243.5526] dhcp6 (wlp2s0): canceled DHCP transaction
Oct 28 18:04:03 Chronos7 NetworkManager[1168]: <info>  [1603908243.5527] dhcp6 (wlp2s0): state changed bound -> done
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.11.
Oct 28 18:04:03 Chronos7 avahi-daemon[1164]: Withdrawing address record for 192.168.1.11 on wlp2s0.
Oct 28 18:04:03 Chronos7 NetworkManager[1168]: <info>  [1603908243.7498] device (wlp2s0): set-hw-addr: set MAC address to 36:11:C7:BC:48:B5 (scanning)
Oct 28 18:04:03 Chronos7 kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
Oct 28 18:04:03 Chronos7 kscreenlocker_greet[65110]: Qt: Session management error: networkIdsList argument is NULL
Oct 28 18:04:04 Chronos7 kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
Oct 28 18:04:04 Chronos7 avahi-daemon[1164]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.11.
Oct 28 18:04:04 Chronos7 avahi-daemon[1164]: New relevant interface wlp2s0.IPv4 for mDNS.
Oct 28 18:04:04 Chronos7 avahi-daemon[1164]: Registering new address record for 192.168.1.11 on wlp2s0.IPv4.
Oct 28 18:04:04 Chronos7 avahi-daemon[1164]: Withdrawing address record for 192.168.1.11 on wlp2s0.
Oct 28 18:04:04 Chronos7 avahi-daemon[1164]: Leaving mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.11.
Oct 28 18:04:04 Chronos7 avahi-daemon[1164]: Interface wlp2s0.IPv4 no longer relevant for mDNS.
Oct 28 18:04:04 Chronos7 NetworkManager[1168]: <info>  [1603908244.6555] device (wlp2s0): supplicant interface state: completed -> disconnected
Oct 28 18:04:04 Chronos7 NetworkManager[1168]: <info>  [1603908244.6569] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
Oct 28 18:04:04 Chronos7 NetworkManager[1168]: <info>  [1603908244.6571] device (wlp2s0): supplicant interface state: interface_disabled -> disconnected
Oct 28 18:04:04 Chronos7 NetworkManager[1168]: <info>  [1603908244.6574] device (wlp2s0): state change: disconnected -> unmanaged (reason 'sleeping', sys-iface-state: 'managed')
Oct 28 18:04:04 Chronos7 systemd[1]: Stopping Network Time Service...
Oct 28 18:04:04 Chronos7 ntpd[1835]: ntpd exiting on signal 15 (Terminated)
Oct 28 18:04:04 Chronos7 ntpd[1835]: 162.159.200.123 local addr 192.168.1.11 -> <null>
Oct 28 18:04:04 Chronos7 ntpd[1835]: 129.250.35.250 local addr 192.168.1.11 -> <null>
Oct 28 18:04:04 Chronos7 ntpd[1835]: 46.227.200.70 local addr 192.168.1.11 -> <null>
Oct 28 18:04:04 Chronos7 ntpd[1835]: 51.155.16.62 local addr 192.168.1.11 -> <null>
Oct 28 18:04:04 Chronos7 systemd[1]: ntpd.service: Succeeded.
Oct 28 18:04:04 Chronos7 systemd[1]: Stopped Network Time Service.
Oct 28 18:04:04 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ntpd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 18:04:04 Chronos7 kernel: audit: type=1131 audit(1603908244.936:362): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ntpd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 18:04:05 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/look-and-feel/org.kde.breath.desktop/contents/lockscreen/LockScreen.qml:52:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:04:05 Chronos7 kscreenlocker_greet[65110]: kf.package: No metadata file in the package, expected it at: "/media/ssaury1/BUF/Work/Aessent/Marketing/Logo/"
Oct 28 18:04:05 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:76:9: Unable to assign [undefined] to QStringList
Oct 28 18:04:05 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/wallpapers/org.kde.image/contents/ui/main.qml:75:9: Unable to assign [undefined] to int
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: Error sending REPLY_SCAN_ABORT_CMD: time out after 2000ms.
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: Current CMD queue read_ptr 32 write_ptr 33
Oct 28 18:04:06 Chronos7 NetworkManager[1168]: <info>  [1603908246.9383] device (wlp2s0): set-hw-addr: reset MAC address to C4:85:08:5B:6A:D0 (unmanage)
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: Loaded firmware version: 18.168.6.1 6000g2b-6.ucode
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | OK
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | uPc
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | branchlink1
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | branchlink2
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | interruptlink1
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | interruptlink2
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | data1
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | data2
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | line
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | beacon time
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | tsf low
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | tsf hi
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp1
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp2
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | time gp3
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | uCode version
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | hw version
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | board version
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | hcmd
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr0
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr1
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr2
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr3
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr4
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | isr_pref
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | wait_event
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | l2p_control
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | l2p_duration
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | l2p_mhvalid
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | l2p_addr_match
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | lmpm_pmg_sel
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | timestamp
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: 0x00000000 | flow_handler
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: Start IWL Event Log Dump: nothing in log
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: Command REPLY_RXON failed: FW Error
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: Error clearing ASSOC_MSK on BSS (-5)
Oct 28 18:04:06 Chronos7 kernel: ieee80211 phy0: Hardware restart was requested
Oct 28 18:04:06 Chronos7 kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
Oct 28 18:04:07 Chronos7 kscreenlocker_greet[65110]: UdevQt: unable to create udev monitor connection
Oct 28 18:04:07 Chronos7 kscreenlocker_greet[65110]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:04:07 Chronos7 kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
Oct 28 18:04:07 Chronos7 kscreenlocker_greet[65110]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Oct 28 18:04:07 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/look-and-feel/org.kde.breath.desktop/contents/lockscreen/MainBlock.qml:79:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:04:07 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/look-and-feel/org.kde.breath.desktop/contents/lockscreen/LockScreenUi.qml:35:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:04:07 Chronos7 systemd-logind[1171]: Delay lock is active (UID 0/root, PID 1168/NetworkManager) but inhibitor timeout is reached.
Oct 28 18:04:07 Chronos7 systemd[1]: Reached target Sleep.
Oct 28 18:04:07 Chronos7 systemd[1]: Starting Suspend...
Oct 28 18:04:07 Chronos7 systemd-sleep[65148]: Going to suspend...
Oct 28 18:04:08 Chronos7 kscreenlocker_greet[65110]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:04:08 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/look-and-feel/org.kde.breath.desktop/contents/lockscreen/MainBlock.qml:79:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:04:08 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/look-and-feel/org.kde.breath.desktop/contents/lockscreen/LockScreenUi.qml:35:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 18:04:08 Chronos7 kscreenlocker_greet[65110]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:807:9: QML QQuickItem: Binding loop detected for property "width"
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: Failed to load firmware chunk!
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: iwlwifi transaction failed, dumping registers
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: iwlwifi device config registers:
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000000: 088e8086 00100406 02800024 00000010 f1500004 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000020: 00000000 00000000 00000000 40608086 00000000 000000c8 00000000 0000010b
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000040: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000060: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000080: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 000000a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 000000c0: 00000000 00000000 c823d001 0d000000 0081e005 fee04004 00000000 00004024
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 000000e0: 00010010 10008ec0 00190810 0006ec11 10110143 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000100: 14010001 00000000 00000000 00062011 00002000 00002000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000140: 00010003 ff5b6ad0 c48508ff 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: iwlwifi device memory mapped registers:
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000000: 00484b00 00000040 08000000 00000000 00000001 00000000 00000030 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000020: 00000001 080403c5 000000b0 00000000 90000801 00030001 80008040 00080046
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: iwlwifi device AER capability structure:
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: 00000000: 14010001 00000000 00000000 00062011 00002000 00002000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: iwlwifi parent port (0000:00:1c.0) config registers:
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000000: 1e108086 00100407 060400c4 00810010 00000000 00000000 00020200 200000f0
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000020: f150f150 0001fff1 00000000 00000000 00000000 00000040 00000000 0002010b
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000040: 01428010 00008000 00100000 01123c12 70110042 0004b200 01400000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000060: 00000000 00000016 00000000 00000000 00010002 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000080: 00019005 fee08004 00004021 00000000 0000a00d c0d5144d 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 000000a0: c8020001 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 000000c0: 00000000 00000000 00000000 00000000 01000000 00000b02 81118000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 000000e0: 00003f00 00000000 00000001 00000000 00000000 00000000 08040f87 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000100: 00000000 00000000 00000000 00060011 00000000 00002000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000120: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000140: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000160: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000180: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 000001a0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 000001c0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 000001e0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:00:1c.0: 00000200: 00000000 00000000 00000000
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: Could not load the [0] uCode section
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: Failed to run INIT ucode: -110
Oct 28 18:04:12 Chronos7 kernel: iwlwifi 0000:02:00.0: Unable to initialize device.
Oct 28 18:04:12 Chronos7 kernel: ------------[ cut here ]------------
Oct 28 18:04:12 Chronos7 kernel: Hardware became unavailable during restart.
Oct 28 18:04:12 Chronos7 kernel: WARNING: CPU: 1 PID: 63566 at net/mac80211/util.c:2260 ieee80211_reconfig+0xd4/0x1530 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: Modules linked in: ftdi_sio ccm bnep fuse uvcvideo videobuf2_vmalloc videobuf2_memops videobuf2_v4l2 videobuf2_common videodev mc btusb btrtl btbcm btintel bluetooth ecdh_generic ecc squashfs loop snd_hda_codec_hdmi snd_hda_codec_realtek snd_hda_codec_generic intel_rapl_msr ledtrig_audio intel_rapl_common i915 x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel joydev i2c_algo_bit kvm mousedev drm_kms_helper cec mei_hdcp rc_core iTCO_wdt intel_pmc_bxt drm irqbypass intel_gtt crct10dif_pclmul agpgart iTCO_vendor_support crc32_pclmul at24 ghash_clmulni_intel syscopyarea snd_hda_intel sysfillrect sysimgblt iwldvm mac80211 aesni_intel fb_sys_fops snd_intel_dspcfg snd_hda_codec crypto_simd snd_hda_core libarc4 snd_hwdep cryptd snd_pcm glue_helper snd_timer rapl intel_cstate iwlwifi samsung_laptop pktcdvd intel_uncore cfg80211 mei_me mei acpi_als psmouse snd soundcore kfifo_buf input_leds rfkill industrialio i2c_i801 lpc_ich i2c_smbus battery evdev mac_hid pcspkr ac uinput sg
Oct 28 18:04:12 Chronos7 kernel:  crypto_user ip_tables x_tables ext4 crc32c_generic crc16 mbcache jbd2 hid_generic usbhid hid serio_raw atkbd libps2 crc32c_intel sr_mod xhci_pci cdrom xhci_hcd ehci_pci ehci_hcd i8042 serio
Oct 28 18:04:12 Chronos7 kernel: CPU: 1 PID: 63566 Comm: kworker/1:1 Not tainted 5.8.16-2-MANJARO #1
Oct 28 18:04:12 Chronos7 kernel: Hardware name: SAMSUNG ELECTRONICS CO., LTD. 700Z3C/700Z5C/700Z3C/700Z5C, BIOS P02AAG 04/26/2012
Oct 28 18:04:12 Chronos7 kernel: Workqueue: events_freezable ieee80211_restart_work [mac80211]
Oct 28 18:04:12 Chronos7 kernel: RIP: 0010:ieee80211_reconfig+0xd4/0x1530 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: Code: 1e 00 0f 85 3a 03 00 00 c6 85 34 05 00 00 00 48 89 ef e8 ef 52 fc ff 41 89 c7 85 c0 74 14 48 c7 c7 60 5a 84 c0 e8 e2 ea 29 ef <0f> 0b eb c2 88 5c 24 1e 48 8b 45 40 44 8b a8 98 00 00 00 0f 1f 44
Oct 28 18:04:12 Chronos7 kernel: RSP: 0018:ffff9a9c035b7df8 EFLAGS: 00010282
Oct 28 18:04:12 Chronos7 kernel: RAX: 0000000000000000 RBX: ffff88f2a8a518d0 RCX: 0000000000000000
Oct 28 18:04:12 Chronos7 kernel: RDX: 0000000000000001 RSI: ffffffffb0d748fa RDI: 00000000ffffffff
Oct 28 18:04:12 Chronos7 kernel: RBP: ffff88f2a8a507e0 R08: 0000000000000512 R09: 0000000000000001
Oct 28 18:04:12 Chronos7 kernel: R10: 0000000000000000 R11: 0000000000000001 R12: ffff88f2a8a518d0
Oct 28 18:04:12 Chronos7 kernel: R13: ffff88f2a8a507e0 R14: 0000000000000000 R15: 00000000ffffff92
Oct 28 18:04:12 Chronos7 kernel: FS:  0000000000000000(0000) GS:ffff88f2b7240000(0000) knlGS:0000000000000000
Oct 28 18:04:12 Chronos7 kernel: CS:  0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Oct 28 18:04:12 Chronos7 kernel: CR2: 00007f4308451000 CR3: 000000009700a004 CR4: 00000000001606e0
Oct 28 18:04:12 Chronos7 kernel: Call Trace:
Oct 28 18:04:12 Chronos7 kernel:  ieee80211_restart_work+0xb7/0xe0 [mac80211]
Oct 28 18:04:12 Chronos7 kernel:  process_one_work+0x1da/0x3d0
Oct 28 18:04:12 Chronos7 kernel:  worker_thread+0x4d/0x3d0
Oct 28 18:04:12 Chronos7 kernel:  ? rescuer_thread+0x410/0x410
Oct 28 18:04:12 Chronos7 kernel:  kthread+0x142/0x160
Oct 28 18:04:12 Chronos7 kernel:  ? __kthread_bind_mask+0x60/0x60
Oct 28 18:04:12 Chronos7 kernel:  ret_from_fork+0x22/0x30
Oct 28 18:04:12 Chronos7 kernel: ---[ end trace 262dd3e9620503a2 ]---
Oct 28 18:04:12 Chronos7 kernel: wlp2s0:  Failed check-sdata-in-driver check, flags: 0x0
Oct 28 18:04:12 Chronos7 kernel: WARNING: CPU: 1 PID: 63566 at net/mac80211/driver-ops.h:17 drv_remove_interface+0x121/0x130 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: CPU: 1 PID: 63566 Comm: kworker/1:1 Tainted: G        W         5.8.16-2-MANJARO #1
Oct 28 18:04:12 Chronos7 kernel: RIP: 0010:drv_remove_interface+0x121/0x130 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: Code: 74 b2 24 ef e9 49 ff ff ff 48 8b 86 80 04 00 00 48 8d b6 a0 04 00 00 48 c7 c7 e0 4a 84 c0 48 85 c0 48 0f 45 f0 e8 c5 91 2d ef <0f> 0b 5b 5d 41 5c c3 0f 1f 84 00 00 00 00 00 0f 1f 44 00 00 41 57
Oct 28 18:04:12 Chronos7 kernel: RSP: 0018:ffff9a9c035b7c90 EFLAGS: 00010286
Oct 28 18:04:12 Chronos7 kernel: RAX: 0000000000000000 RBX: ffff88f2a94c4900 RCX: 0000000000000000
Oct 28 18:04:12 Chronos7 kernel: RBP: ffff88f2a8a51930 R08: 000000000000052e R09: 0000000000000001
Oct 28 18:04:12 Chronos7 kernel: R10: 0000000000000000 R11: 0000000000000001 R12: ffff88f2a8a507e0
Oct 28 18:04:12 Chronos7 kernel: R13: ffff88f2a8a51000 R14: ffff88f2a8a50ca0 R15: ffff88f2a94c54d8
Oct 28 18:04:12 Chronos7 kernel:  ieee80211_do_stop+0x569/0x8b0 [mac80211]
Oct 28 18:04:12 Chronos7 kernel:  ieee80211_stop+0x16/0x20 [mac80211]
Oct 28 18:04:12 Chronos7 kernel:  __dev_close_many+0xaa/0x120
Oct 28 18:04:12 Chronos7 kernel:  dev_close_many+0x92/0x140
Oct 28 18:04:12 Chronos7 kernel:  dev_close+0x6d/0x90
Oct 28 18:04:12 Chronos7 kernel:  cfg80211_shutdown_all_interfaces+0x71/0xd0 [cfg80211]
Oct 28 18:04:12 Chronos7 kernel:  ieee80211_reconfig+0xa2/0x1530 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: ---[ end trace 262dd3e9620503a3 ]---
Oct 28 18:04:12 Chronos7 kernel: WARNING: CPU: 1 PID: 63566 at net/mac80211/driver-ops.c:36 drv_stop+0x120/0x130 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: RIP: 0010:drv_stop+0x120/0x130 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: Code: c5 18 48 89 de e8 90 77 04 f0 48 8b 45 00 48 85 c0 75 e7 65 ff 0d 40 e7 85 3f 0f 85 1e ff ff ff e8 44 b6 24 ef e9 14 ff ff ff <0f> 0b c3 66 66 2e 0f 1f 84 00 00 00 00 00 66 90 0f 1f 44 00 00 41
Oct 28 18:04:12 Chronos7 kernel: RSP: 0018:ffff9a9c035b7ca8 EFLAGS: 00010246
Oct 28 18:04:12 Chronos7 kernel: RDX: ffff88f2538c8000 RSI: 0000000000000292 RDI: ffff88f2a8a507e0
Oct 28 18:04:12 Chronos7 kernel: RBP: ffff88f2a8a51930 R08: ffff88f2b6010c00 R09: ffffffffb104c978
Oct 28 18:04:12 Chronos7 kernel: R10: 0000000000000000 R11: 0000000000000000 R12: ffff88f2a8a507e0
Oct 28 18:04:12 Chronos7 kernel:  ieee80211_do_stop+0x59d/0x8b0 [mac80211]
Oct 28 18:04:12 Chronos7 kernel: ---[ end trace 262dd3e9620503a4 ]---
Oct 28 18:04:12 Chronos7 NetworkManager[1168]: <warn>  [1603908252.4718] device (wlp2s0): device not up after timeout!
Oct 28 18:04:12 Chronos7 kded5[1501]: plasma-nm: Not emitting connection deactivated notification as we're about to suspend
Oct 28 18:04:12 Chronos7 systemd-sleep[65144]: Suspending system...
Oct 28 18:04:12 Chronos7 kernel: PM: suspend entry (deep)
Oct 28 18:04:12 Chronos7 wpa_supplicant[1199]: nl80211: deinit ifname=wlp2s0 disabled_11b_rates=0
Oct 28 18:04:13 Chronos7 kernel: Filesystems sync: 0.698 seconds
Oct 28 19:02:32 Chronos7 kernel: Freezing user space processes ... (elapsed 0.002 seconds) done.
Oct 28 19:02:32 Chronos7 kernel: OOM killer disabled.
Oct 28 19:02:32 Chronos7 kernel: Freezing remaining freezable tasks ... (elapsed 0.001 seconds) done.
Oct 28 19:02:32 Chronos7 kernel: printk: Suspending console(s) (use no_console_suspend to debug)
Oct 28 19:02:32 Chronos7 kernel: sd 1:0:0:0: [sdb] Synchronizing SCSI cache
Oct 28 19:02:32 Chronos7 kernel: sd 1:0:0:0: [sdb] Stopping disk
Oct 28 19:02:32 Chronos7 kernel: sd 0:0:0:0: [sda] Synchronizing SCSI cache
Oct 28 19:02:32 Chronos7 kernel: sd 0:0:0:0: [sda] Stopping disk
Oct 28 19:02:32 Chronos7 kernel: ACPI: EC: interrupt blocked
Oct 28 19:02:32 Chronos7 kernel: ACPI: Preparing to enter system sleep state S3
Oct 28 19:02:32 Chronos7 kernel: ACPI: EC: event blocked
Oct 28 19:02:32 Chronos7 kernel: ACPI: EC: EC stopped
Oct 28 19:02:32 Chronos7 kernel: PM: Saving platform NVS memory
Oct 28 19:02:32 Chronos7 kernel: Disabling non-boot CPUs ...
Oct 28 19:02:32 Chronos7 kernel: smpboot: CPU 1 is now offline
Oct 28 19:02:32 Chronos7 kernel: smpboot: CPU 2 is now offline
Oct 28 19:02:32 Chronos7 kernel: smpboot: CPU 3 is now offline
Oct 28 19:02:32 Chronos7 kernel: ACPI: Low-level resume complete
Oct 28 19:02:32 Chronos7 kernel: ACPI: EC: EC started
Oct 28 19:02:32 Chronos7 kernel: PM: Restoring platform NVS memory
Oct 28 19:02:32 Chronos7 kernel: Enabling non-boot CPUs ...
Oct 28 19:02:32 Chronos7 kernel: x86: Booting SMP configuration:
Oct 28 19:02:32 Chronos7 kernel: smpboot: Booting Node 0 Processor 1 APIC 0x1
Oct 28 19:02:32 Chronos7 kernel: smpboot: Scheduler frequency invariance went wobbly, disabling!
Oct 28 19:02:32 Chronos7 kernel: CPU1 is up
Oct 28 19:02:32 Chronos7 kernel: smpboot: Booting Node 0 Processor 2 APIC 0x2
Oct 28 19:02:32 Chronos7 kernel: CPU2 is up
Oct 28 19:02:32 Chronos7 kernel: smpboot: Booting Node 0 Processor 3 APIC 0x3
Oct 28 19:02:32 Chronos7 kernel: CPU3 is up
Oct 28 19:02:32 Chronos7 kernel: ACPI: Waking up from system sleep state S3
Oct 28 19:02:32 Chronos7 kernel: ACPI: EC: interrupt unblocked
Oct 28 19:02:32 Chronos7 kernel: pci 0000:01:00.0: Enabling HDA controller
Oct 28 19:02:32 Chronos7 kernel: ACPI: EC: event unblocked
Oct 28 19:02:32 Chronos7 kernel: iwlwifi 0000:02:00.0: RF_KILL bit toggled to enable radio.
Oct 28 19:02:32 Chronos7 kernel: sd 0:0:0:0: [sda] Starting disk
Oct 28 19:02:32 Chronos7 kernel: sd 1:0:0:0: [sdb] Starting disk
Oct 28 19:02:32 Chronos7 kernel: ACPI: EC: 2 stale EC events cleared
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.2: reset high-speed USB device number 3 using ehci-pci
Oct 28 19:02:32 Chronos7 kernel: ata3: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
Oct 28 19:02:32 Chronos7 kernel: ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Oct 28 19:02:32 Chronos7 kernel: ata2.00: configured for UDMA/133
Oct 28 19:02:32 Chronos7 kernel: ata3.00: configured for UDMA/100
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.4: reset high-speed USB device number 4 using ehci-pci
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.2.2: reset low-speed USB device number 5 using ehci-pci
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.2.4: reset high-speed USB device number 6 using ehci-pci
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.2.4.4: reset low-speed USB device number 7 using ehci-pci
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.2.4.3: reset high-speed USB device number 8 using ehci-pci
Oct 28 19:02:32 Chronos7 kernel: ftdi_sio ttyUSB1: FTDI USB Serial Device converter now disconnected from ttyUSB1
Oct 28 19:02:32 Chronos7 kernel: ftdi_sio 1-1.2.4.3:1.1: device disconnected
Oct 28 19:02:32 Chronos7 kernel: OOM killer enabled.
Oct 28 19:02:32 Chronos7 kernel: Restarting tasks ... done.
Oct 28 19:02:32 Chronos7 kernel: ftdi_sio 1-1.2.4.3:1.1: FTDI USB Serial Device converter detected
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.2.4.3: Detected FT2232H
Oct 28 19:02:32 Chronos7 kernel: usb 1-1.2.4.3: FTDI USB Serial Device converter now attached to ttyUSB0
Oct 28 19:02:32 Chronos7 kernel: PM: suspend exit
Oct 28 19:02:32 Chronos7 systemd-logind[1171]: Lid opened.
Oct 28 19:02:32 Chronos7 systemd-sleep[65144]: System resumed.
Oct 28 19:02:32 Chronos7 systemd-sleep[65384]: Waking up from suspend...
Oct 28 19:02:33 Chronos7 kernel: ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
Oct 28 19:02:33 Chronos7 kernel: ata1.00: LPM support broken, forcing max_power
Oct 28 19:02:33 Chronos7 kernel: ata1.00: configured for UDMA/133
Oct 28 19:02:33 Chronos7 NetworkManager[1168]: <info>  [1603911753.4440] radio killswitch /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/ieee80211/phy0/rfkill2 disappeared
Oct 28 19:02:33 Chronos7 systemd[1]: Starting Load/Save RF Kill Switch Status...
Oct 28 19:02:33 Chronos7 systemd[1]: Started Load/Save RF Kill Switch Status.
Oct 28 19:02:33 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:33 Chronos7 kernel: audit: type=1130 audit(1603911753.693:363): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:33 Chronos7 kernel: Intel(R) Wireless WiFi driver for Linux
Oct 28 19:02:33 Chronos7 kernel: iwlwifi 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
Oct 28 19:02:33 Chronos7 kernel: iwlwifi 0000:02:00.0: loaded firmware version 18.168.6.1 6000g2b-6.ucode op_mode iwldvm
Oct 28 19:02:33 Chronos7 kernel: iwlwifi 0000:02:00.0: Direct firmware load for iwl-debug-yoyo.bin failed with error -2
Oct 28 19:02:34 Chronos7 kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUG enabled
Oct 28 19:02:34 Chronos7 kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEBUGFS enabled
Oct 28 19:02:34 Chronos7 kernel: iwlwifi 0000:02:00.0: CONFIG_IWLWIFI_DEVICE_TRACING enabled
Oct 28 19:02:34 Chronos7 kernel: iwlwifi 0000:02:00.0: Detected Intel(R) Centrino(R) Advanced-N 6235 AGN, REV=0xB0
Oct 28 19:02:34 Chronos7 kernel: ieee80211 phy1: Selected rate control algorithm 'iwl-agn-rs'
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.1161] device (wlan0): driver supports Access Point (AP) mode
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.1188] manager: (wlan0): new 802.11 Wi-Fi device (/org/freedesktop/NetworkManager/Devices/3)
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.1220] rfkill3: found Wi-Fi radio killswitch (at /sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0/ieee80211/phy1/rfkill3) (driver iwlwifi)
Oct 28 19:02:34 Chronos7 systemd[1]: systemd-suspend.service: Succeeded.
Oct 28 19:02:34 Chronos7 systemd[1]: Finished Suspend.
Oct 28 19:02:34 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:34 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:34 Chronos7 systemd[1]: Stopped target Sleep.
Oct 28 19:02:34 Chronos7 systemd[1]: Reached target Suspend.
Oct 28 19:02:34 Chronos7 systemd[1]: Stopped target Suspend.
Oct 28 19:02:34 Chronos7 kernel: audit: type=1130 audit(1603911754.123:364): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:34 Chronos7 kernel: audit: type=1131 audit(1603911754.123:365): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-suspend comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:34 Chronos7 systemd-logind[1171]: Operation 'sleep' finished.
Oct 28 19:02:34 Chronos7 ModemManager[1194]: <info>  [sleep-monitor] system is resuming
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.1373] manager: sleep: wake requested (sleeping: yes  enabled: yes)
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.1375] manager: NetworkManager state is now DISCONNECTED
Oct 28 19:02:34 Chronos7 systemd-udevd[65367]: Using default interface naming scheme 'v245'.
Oct 28 19:02:34 Chronos7 org_kde_powerdevil[1587]: powerdevil: set kbd backlight value:  4
Oct 28 19:02:34 Chronos7 systemd-udevd[65367]: ethtool: autonegotiation is unset or enabled, the speed and duplex are not writable.
Oct 28 19:02:34 Chronos7 kernel: iwlwifi 0000:02:00.0 wlp2s0: renamed from wlan0
Oct 28 19:02:34 Chronos7 org_kde_powerdevil[1587]: powerdevil: Keyboard brightness changed!!
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.2309] device (wlan0): interface index 3 renamed iface from 'wlan0' to 'wlp2s0'
Oct 28 19:02:34 Chronos7 systemd-udevd[65373]: Using default interface naming scheme 'v245'.
Oct 28 19:02:34 Chronos7 dolphin[61130]: UdevQt: unhandled device action "move"
Oct 28 19:02:34 Chronos7 dolphin[59176]: UdevQt: unhandled device action "move"
Oct 28 19:02:34 Chronos7 org_kde_powerdevil[1587]: UdevQt: unhandled device action "move"
Oct 28 19:02:34 Chronos7 kded5[1501]: UdevQt: unhandled device action "move"
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.4496] device (wlp2s0): state change: unmanaged -> unavailable (reason 'managed', sys-iface-state: 'external')
Oct 28 19:02:34 Chronos7 kdeconnectd[1564]: UdevQt: unhandled device action "move"
Oct 28 19:02:34 Chronos7 plasmashell[1537]: UdevQt: unhandled device action "move"
Oct 28 19:02:34 Chronos7 kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
Oct 28 19:02:34 Chronos7 NetworkManager[1168]: <info>  [1603911754.8891] device (wlp2s0): set-hw-addr: set MAC address to 8A:C6:8B:0D:E9:C7 (scanning)
Oct 28 19:02:34 Chronos7 ModemManager[1194]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1a.0/usb1/1-1/1-1.2/1-1.2.4/1-1.2.4.3': not supported by any plugin
Oct 28 19:02:35 Chronos7 kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
Oct 28 19:02:35 Chronos7 wpa_supplicant[1199]: dbus: fill_dict_with_properties dbus_interface=fi.w1.wpa_supplicant1.Interface.P2PDevice dbus_property=P2PDeviceConfig getter failed
Oct 28 19:02:35 Chronos7 NetworkManager[1168]: <info>  [1603911755.3780] device (wlp2s0): supplicant interface state: internal-starting -> disconnected
Oct 28 19:02:35 Chronos7 NetworkManager[1168]: <info>  [1603911755.3782] device (wlp2s0): state change: unavailable -> disconnected (reason 'supplicant-available', sys-iface-state: 'managed')
Oct 28 19:02:36 Chronos7 ModemManager[1194]: <info>  [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:1c.0/0000:02:00.0': not supported by any plugin
Oct 28 19:02:39 Chronos7 systemd[1]: systemd-rfkill.service: Succeeded.
Oct 28 19:02:39 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:39 Chronos7 kernel: audit: type=1131 audit(1603911759.190:366): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:41 Chronos7 NetworkManager[1168]: <info>  [1603911761.6157] policy: auto-activating connection 'TALKTALKF710E2' (98689504-1afa-4f2d-9307-b3b660ef065b)
Oct 28 19:02:41 Chronos7 NetworkManager[1168]: <info>  [1603911761.6187] device (wlp2s0): Activation: starting connection 'TALKTALKF710E2' (98689504-1afa-4f2d-9307-b3b660ef065b)
Oct 28 19:02:41 Chronos7 NetworkManager[1168]: <info>  [1603911761.6497] device (wlp2s0): state change: disconnected -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:41 Chronos7 NetworkManager[1168]: <info>  [1603911761.6516] manager: NetworkManager state is now CONNECTING
Oct 28 19:02:41 Chronos7 NetworkManager[1168]: <info>  [1603911761.6671] device (wlp2s0): set-hw-addr: reset MAC address to C4:85:08:5B:6A:D0 (preserve)
Oct 28 19:02:41 Chronos7 kernel: iwlwifi 0000:02:00.0: Radio type=0x2-0x1-0x0
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.0659] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.0664] device (wlp2s0): Activation: (wifi) access point 'TALKTALKF710E2' has security, but secrets are required.
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.0664] device (wlp2s0): state change: config -> need-auth (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.0994] device (wlp2s0): supplicant interface state: disconnected -> interface_disabled
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1007] device (wlp2s0): supplicant interface state: interface_disabled -> inactive
Oct 28 19:02:42 Chronos7 kded5[1501]: plasma-nm: Unhandled active connection state change:  1
Oct 28 19:02:42 Chronos7 kded5[1501]: plasma-nm: virtual NMVariantMapMap SecretAgent::GetSecrets(const NMVariantMapMap&, const QDBusObjectPath&, const QString&, const QStringList&, uint)
Oct 28 19:02:42 Chronos7 kded5[1501]: plasma-nm: Path: "/org/freedesktop/NetworkManager/Settings/13"
Oct 28 19:02:42 Chronos7 kded5[1501]: plasma-nm: Setting name: "802-11-wireless-security"
Oct 28 19:02:42 Chronos7 kded5[1501]: plasma-nm: Hints: ()
Oct 28 19:02:42 Chronos7 kded5[1501]: plasma-nm: Flags: 1
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1950] device (wlp2s0): state change: need-auth -> prepare (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1962] device (wlp2s0): state change: prepare -> config (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1970] device (wlp2s0): Activation: (wifi) connection 'TALKTALKF710E2' has security, and secrets exist.  No new secrets needed.
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1971] Config: added 'ssid' value 'TALKTALKF710E2'
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1971] Config: added 'scan_ssid' value '1'
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1971] Config: added 'bgscan' value 'simple:30:-70:86400'
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1972] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK'
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1972] Config: added 'auth_alg' value 'OPEN'
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.1972] Config: added 'psk' value '<hidden>'
Oct 28 19:02:42 Chronos7 NetworkManager[1168]: <info>  [1603911762.2212] device (wlp2s0): supplicant interface state: inactive -> scanning
Oct 28 19:02:45 Chronos7 wpa_supplicant[1199]: wlp2s0: SME: Trying to authenticate with 34:db:9c:f7:10:e0 (SSID='TALKTALKF710E2' freq=5240 MHz)
Oct 28 19:02:45 Chronos7 kernel: wlp2s0: authenticate with 34:db:9c:f7:10:e0
Oct 28 19:02:45 Chronos7 NetworkManager[1168]: <info>  [1603911765.4055] device (wlp2s0): supplicant interface state: scanning -> authenticating
Oct 28 19:02:45 Chronos7 kernel: wlp2s0: send auth to 34:db:9c:f7:10:e0 (try 1/3)
Oct 28 19:02:45 Chronos7 kernel: audit: type=1131 audit(1603911765.423:367): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:45 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:45 Chronos7 systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Oct 28 19:02:45 Chronos7 wpa_supplicant[1199]: wlp2s0: Trying to associate with 34:db:9c:f7:10:e0 (SSID='TALKTALKF710E2' freq=5240 MHz)
Oct 28 19:02:45 Chronos7 kernel: wlp2s0: authenticated
Oct 28 19:02:45 Chronos7 kernel: wlp2s0: associate with 34:db:9c:f7:10:e0 (try 1/3)
Oct 28 19:02:45 Chronos7 NetworkManager[1168]: <info>  [1603911765.4532] device (wlp2s0): supplicant interface state: authenticating -> associating
Oct 28 19:02:45 Chronos7 kernel: wlp2s0: RX AssocResp from 34:db:9c:f7:10:e0 (capab=0x11 status=0 aid=5)
Oct 28 19:02:45 Chronos7 kernel: wlp2s0: associated
Oct 28 19:02:45 Chronos7 wpa_supplicant[1199]: wlp2s0: Associated with 34:db:9c:f7:10:e0
Oct 28 19:02:45 Chronos7 wpa_supplicant[1199]: wlp2s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 28 19:02:45 Chronos7 wpa_supplicant[1199]: wlp2s0: CTRL-EVENT-REGDOM-CHANGE init=COUNTRY_IE type=COUNTRY alpha2=GB
Oct 28 19:02:45 Chronos7 NetworkManager[1168]: <info>  [1603911765.4784] device (wlp2s0): supplicant interface state: associating -> associated
Oct 28 19:02:45 Chronos7 kernel: wlp2s0: Limiting TX power to 23 (23 - 0) dBm as advertised by 34:db:9c:f7:10:e0
Oct 28 19:02:46 Chronos7 wpa_supplicant[1199]: wlp2s0: WPA: Key negotiation completed with 34:db:9c:f7:10:e0 [PTK=CCMP GTK=CCMP]
Oct 28 19:02:46 Chronos7 wpa_supplicant[1199]: wlp2s0: CTRL-EVENT-CONNECTED - Connection to 34:db:9c:f7:10:e0 completed [id=0 id_str=]
Oct 28 19:02:46 Chronos7 kernel: IPv6: ADDRCONF(NETDEV_CHANGE): wlp2s0: link becomes ready
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.4541] device (wlp2s0): supplicant interface state: associated -> completed
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.4541] device (wlp2s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "TALKTALKF710E2"
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.4543] device (wlp2s0): state change: config -> ip-config (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.4547] dhcp4 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Oct 28 19:02:46 Chronos7 wpa_supplicant[1199]: wlp2s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-35 noise=9999 txrate=6000
Oct 28 19:02:46 Chronos7 avahi-daemon[1164]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fe80::70e3:564f:f231:868e.
Oct 28 19:02:46 Chronos7 avahi-daemon[1164]: New relevant interface wlp2s0.IPv6 for mDNS.
Oct 28 19:02:46 Chronos7 avahi-daemon[1164]: Registering new address record for fe80::70e3:564f:f231:868e on wlp2s0.*.
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6998] dhcp4 (wlp2s0): option dhcp_lease_time      => '86400'
Oct 28 19:02:46 Chronos7 avahi-daemon[1164]: Joining mDNS multicast group on interface wlp2s0.IPv4 with address 192.168.1.11.
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6998] dhcp4 (wlp2s0): option domain_name          => 'lan'
Oct 28 19:02:46 Chronos7 avahi-daemon[1164]: New relevant interface wlp2s0.IPv4 for mDNS.
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6999] dhcp4 (wlp2s0): option domain_name_servers  => '192.168.1.1'
Oct 28 19:02:46 Chronos7 avahi-daemon[1164]: Registering new address record for 192.168.1.11 on wlp2s0.IPv4.
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6999] dhcp4 (wlp2s0): option expiry               => '1603998166'
Oct 28 19:02:46 Chronos7 dbus-daemon[1167]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service' requested by ':1.6' (uid=0 pid=1168 comm="/usr/bin/NetworkManager --no-daemon " label="unconfined")
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6999] dhcp4 (wlp2s0): option ip_address           => '192.168.1.11'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6999] dhcp4 (wlp2s0): option requested_broadcast_address => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6999] dhcp4 (wlp2s0): option requested_domain_name => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.6999] dhcp4 (wlp2s0): option requested_domain_name_servers => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_domain_search => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_host_name  => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_interface_mtu => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_ms_classless_static_routes => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_nis_domain => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_nis_servers => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_ntp_servers => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7000] dhcp4 (wlp2s0): option requested_rfc3442_classless_static_routes => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7001] dhcp4 (wlp2s0): option requested_root_path  => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7001] dhcp4 (wlp2s0): option requested_routers    => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7001] dhcp4 (wlp2s0): option requested_static_routes => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7001] dhcp4 (wlp2s0): option requested_subnet_mask => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7001] dhcp4 (wlp2s0): option requested_time_offset => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7001] dhcp4 (wlp2s0): option requested_wpad       => '1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7001] dhcp4 (wlp2s0): option routers              => '192.168.1.1'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7002] dhcp4 (wlp2s0): option subnet_mask          => '255.255.255.0'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7002] dhcp4 (wlp2s0): state changed unknown -> bound
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7026] device (wlp2s0): state change: ip-config -> ip-check (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:46 Chronos7 systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 28 19:02:46 Chronos7 dbus-daemon[1167]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 28 19:02:46 Chronos7 systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 28 19:02:46 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:46 Chronos7 kernel: audit: type=1130 audit(1603911766.720:368): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7880] device (wlp2s0): state change: ip-check -> secondaries (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7886] device (wlp2s0): state change: secondaries -> activated (reason 'none', sys-iface-state: 'managed')
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7896] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7931] manager: NetworkManager state is now CONNECTED_SITE
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.7939] policy: set 'TALKTALKF710E2' (wlp2s0) as default for IPv4 routing and DNS
Oct 28 19:02:46 Chronos7 NetworkManager[1168]: <info>  [1603911766.9339] device (wlp2s0): Activation: successful, device activated.
Oct 28 19:02:46 Chronos7 systemd[1]: Starting Network Time Service...
Oct 28 19:02:47 Chronos7 audit[65549]: AVC apparmor="DENIED" operation="open" profile="ntpd" name="/var/lib/snapd/snap/bin/" pid=65549 comm="ntpd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Oct 28 19:02:47 Chronos7 kernel: audit: type=1400 audit(1603911767.180:369): apparmor="DENIED" operation="open" profile="ntpd" name="/var/lib/snapd/snap/bin/" pid=65549 comm="ntpd" requested_mask="r" denied_mask="r" fsuid=0 ouid=0
Oct 28 19:02:47 Chronos7 ntpd[65549]: ntpd 4.2.8p15@1.3728-o Wed Jul  1 17:02:17 UTC 2020 (1): Starting
Oct 28 19:02:47 Chronos7 ntpd[65549]: Command line: /usr/bin/ntpd -g -u ntp:ntp
Oct 28 19:02:47 Chronos7 ntpd[65549]: ----------------------------------------------------
Oct 28 19:02:47 Chronos7 ntpd[65549]: ntp-4 is maintained by Network Time Foundation,
Oct 28 19:02:47 Chronos7 ntpd[65549]: Inc. (NTF), a non-profit 501(c)(3) public-benefit
Oct 28 19:02:47 Chronos7 ntpd[65549]: corporation.  Support and training for ntp-4 are
Oct 28 19:02:47 Chronos7 ntpd[65549]: available at https://www.nwtime.org/support
Oct 28 19:02:47 Chronos7 NetworkManager[1168]: <info>  [1603911767.2163] manager: NetworkManager state is now CONNECTED_GLOBAL
Oct 28 19:02:47 Chronos7 ntpd[65551]: proto: precision = 0.258 usec (-22)
Oct 28 19:02:47 Chronos7 ntpd[65551]: basedate set to 2020-06-19
Oct 28 19:02:47 Chronos7 ntpd[65551]: gps base set to 2020-06-21 (week 2111)
Oct 28 19:02:47 Chronos7 plasmashell[1537]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ScrollViewStyle.qml:47:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 19:02:47 Chronos7 plasmashell[1537]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/ToolButtonStyle.qml:196:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 19:02:47 Chronos7 ntpd[65551]: Listen and drop on 0 v6wildcard [::]:123
Oct 28 19:02:47 Chronos7 ntpd[65551]: Listen and drop on 1 v4wildcard 0.0.0.0:123
Oct 28 19:02:47 Chronos7 ntpd[65551]: Listen normally on 2 lo 127.0.0.1:123
Oct 28 19:02:47 Chronos7 ntpd[65551]: Listen normally on 3 wlp2s0 192.168.1.11:123
Oct 28 19:02:47 Chronos7 ntpd[65551]: Listen normally on 4 lo [::1]:123
Oct 28 19:02:47 Chronos7 ntpd[65551]: bind(21) AF_INET6 fe80::70e3:564f:f231:868e%3#123 flags 0x11 failed: Cannot assign requested address
Oct 28 19:02:47 Chronos7 ntpd[65551]: unable to create socket on wlp2s0 (5) for fe80::70e3:564f:f231:868e%3#123
Oct 28 19:02:47 Chronos7 ntpd[65551]: failed to init interface for address fe80::70e3:564f:f231:868e%3
Oct 28 19:02:47 Chronos7 ntpd[65551]: Listening on routing socket on fd #21 for interface updates
Oct 28 19:02:47 Chronos7 ntpd[65551]: kernel reports TIME_ERROR: 0x6041: Clock Unsynchronized
Oct 28 19:02:47 Chronos7 audit[65551]: AVC apparmor="DENIED" operation="connect" profile="ntpd" name="/run/dbus/system_bus_socket" pid=65551 comm="ntpd" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=0
Oct 28 19:02:47 Chronos7 audit[65551]: AVC apparmor="DENIED" operation="connect" profile="ntpd" name="/run/systemd/userdb/io.systemd.DynamicUser" pid=65551 comm="ntpd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
Oct 28 19:02:47 Chronos7 kernel: audit: type=1400 audit(1603911767.307:370): apparmor="DENIED" operation="connect" profile="ntpd" name="/run/dbus/system_bus_socket" pid=65551 comm="ntpd" requested_mask="wr" denied_mask="wr" fsuid=0 ouid=0
Oct 28 19:02:47 Chronos7 kernel: audit: type=1400 audit(1603911767.307:371): apparmor="DENIED" operation="connect" profile="ntpd" name="/run/systemd/userdb/io.systemd.DynamicUser" pid=65551 comm="ntpd" requested_mask="w" denied_mask="w" fsuid=0 ouid=0
Oct 28 19:02:47 Chronos7 systemd[1]: Started Network Time Service.
Oct 28 19:02:47 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ntpd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:47 Chronos7 kernel: audit: type=1130 audit(1603911767.307:372): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ntpd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:47 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml:78:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 19:02:47 Chronos7 plasmashell[1537]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationPopup.qml:117:15: QML QQuickItem: Binding loop detected for property "height"
Oct 28 19:02:47 Chronos7 audit[65551]: AVC apparmor="DENIED" operation="connect" profile="ntpd" name="/run/dbus/system_bus_socket" pid=65551 comm="ntpd" requested_mask="wr" denied_mask="wr" fsuid=87 ouid=0
Oct 28 19:02:47 Chronos7 kernel: audit: type=1400 audit(1603911767.347:373): apparmor="DENIED" operation="connect" profile="ntpd" name="/run/dbus/system_bus_socket" pid=65551 comm="ntpd" requested_mask="wr" denied_mask="wr" fsuid=87 ouid=0
Oct 28 19:02:47 Chronos7 kernel: audit: type=1400 audit(1603911767.367:374): apparmor="DENIED" operation="connect" profile="ntpd" name="/run/dbus/system_bus_socket" pid=65551 comm="ntpd" requested_mask="wr" denied_mask="wr" fsuid=87 ouid=0
Oct 28 19:02:47 Chronos7 kernel: audit: type=1400 audit(1603911767.393:375): apparmor="DENIED" operation="connect" profile="ntpd" name="/run/dbus/system_bus_socket" pid=65551 comm="ntpd" requested_mask="wr" denied_mask="wr" fsuid=87 ouid=0
Oct 28 19:02:47 Chronos7 dolphin[59176]: inotify_add_watch(/tmp/systemd-private-33a2b3eba808436da150c0efe705237f-ntpd.service-0egTUh) failed: (Permission denied)
Oct 28 19:02:48 Chronos7 NetworkManager[1168]: <info>  [1603911768.5240] dhcp6 (wlp2s0): activation: beginning transaction (timeout in 45 seconds)
Oct 28 19:02:48 Chronos7 NetworkManager[1168]: <info>  [1603911768.6368] dhcp6 (wlp2s0): option dhcp6_domain_search  => 'lan'
Oct 28 19:02:48 Chronos7 avahi-daemon[1164]: Leaving mDNS multicast group on interface wlp2s0.IPv6 with address fe80::70e3:564f:f231:868e.
Oct 28 19:02:48 Chronos7 NetworkManager[1168]: <info>  [1603911768.6369] dhcp6 (wlp2s0): state changed unknown -> bound
Oct 28 19:02:48 Chronos7 avahi-daemon[1164]: Joining mDNS multicast group on interface wlp2s0.IPv6 with address fdaa:bbcc:ddee:0:fa8:8cfc:4abe:4da4.
Oct 28 19:02:48 Chronos7 avahi-daemon[1164]: Registering new address record for fdaa:bbcc:ddee:0:fa8:8cfc:4abe:4da4 on wlp2s0.*.
Oct 28 19:02:48 Chronos7 avahi-daemon[1164]: Withdrawing address record for fe80::70e3:564f:f231:868e on wlp2s0.
Oct 28 19:02:51 Chronos7 ntpd[65551]: Listen normally on 6 wlp2s0 [fdaa:bbcc:ddee:0:fa8:8cfc:4abe:4da4]:123
Oct 28 19:02:51 Chronos7 ntpd[65551]: Listen normally on 7 wlp2s0 [fe80::70e3:564f:f231:868e%3]:123
Oct 28 19:02:51 Chronos7 ntpd[65551]: new interface(s) found: waking up resolver
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: temperature0 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: iconName0 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: isPast0 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: temperature1 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: iconName1 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: isPast1 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: temperature2 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: iconName2 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:52 Chronos7 plasmashell[1537]: <Unknown File>: isPast2 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:02:53 Chronos7 audit[65588]: USER_AUTH pid=65588 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="sebastien" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:53 Chronos7 kernel: audit: type=1100 audit(1603911773.930:376): pid=65588 uid=1000 auid=1000 ses=2 subj==unconfined msg='op=PAM:unix_chkpwd acct="sebastien" exe="/usr/bin/unix_chkpwd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:53 Chronos7 kscreenlocker_greet[65110]: file:///usr/share/plasma/look-and-feel/org.kde.breath.desktop/contents/components/VirtualKeyboard.qml:27: TypeError: Cannot read property 'width' of null
Oct 28 19:02:54 Chronos7 kwin_x11[1505]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55422, resource id: 90177604, major code: 18 (ChangeProperty), minor code: 0
Oct 28 19:02:54 Chronos7 kwin_x11[1505]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 55538, resource id: 23068698, major code: 2 (ChangeWindowAttributes), minor code: 0
Oct 28 19:02:59 Chronos7 systemd[1]: NetworkManager-dispatcher.service: Succeeded.
Oct 28 19:02:59 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:02:59 Chronos7 kernel: audit: type=1131 audit(1603911779.431:377): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
-- Reboot --
Oct 28 19:14:41 Chronos7 systemd[1]: Starting Rotate log files...
Oct 28 19:14:42 Chronos7 kernel: audit: type=1130 audit(1603912481.383:195): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:42 Chronos7 kernel: audit: type=1131 audit(1603912481.813:196): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:42 Chronos7 kernel: audit: type=1130 audit(1603912482.383:197): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:42 Chronos7 kernel: audit: type=1131 audit(1603912482.383:198): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:41 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:41 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=shadow comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:42 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:42 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=logrotate comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:41 Chronos7 systemd[1]: Starting Daily man-db regeneration...
Oct 28 19:14:41 Chronos7 systemd[1]: Started Verify integrity of password and group files.
Oct 28 19:14:41 Chronos7 systemd[1]: shadow.service: Succeeded.
Oct 28 19:14:42 Chronos7 systemd[1]: logrotate.service: Succeeded.
Oct 28 19:14:42 Chronos7 systemd[1]: Finished Rotate log files.
Oct 28 19:14:46 Chronos7 kio_http_cache_cleaner[1994]: QIODevice::skip (QBuffer): WriteOnly device
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: temperature0 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: iconName0 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: isPast0 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: temperature1 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: iconName1 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: isPast1 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: temperature2 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: iconName2 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:46 Chronos7 plasmashell[1586]: <Unknown File>: isPast2 is undefined. Adding an object with a undefined member does not create a role for it.
Oct 28 19:14:50 Chronos7 systemd[1]: man-db.service: Succeeded.
Oct 28 19:14:50 Chronos7 systemd[1]: Finished Daily man-db regeneration.
Oct 28 19:14:50 Chronos7 audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:50 Chronos7 audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:50 Chronos7 kernel: audit: type=1130 audit(1603912490.336:199): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:14:50 Chronos7 kernel: audit: type=1131 audit(1603912490.336:200): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=man-db comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Oct 28 19:15:01 Chronos7 plasmashell[1586]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:26:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 19:15:01 Chronos7 plasmashell[1586]: file:///usr/share/plasma/plasmoids/org.kde.plasma.taskmanager/contents/ui/Task.qml:285:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Oct 28 19:15:01 Chronos7 kwin_x11[1555]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 26451, resource id: 31457454, major code: 18 (ChangeProperty), minor code: 0
Oct 28 19:15:01 Chronos7 systemd[1457]: Started app-org.kde.konsole-bf8d547a017e4ec699aaaed1f87e2f53.scope.
Oct 28 19:16:38 Chronos7 plasmashell[1586]: file:///usr/lib/qt/qml/QtQuick/Controls/Styles/Plasma/BusyIndicatorStyle.qml:26:9: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
That seems pretty old.
Are any BIOS updates available?
(and with that age you might want to be aiming at kernel 4.4)
What driver profile do you have running?
mhwd -l -d --pci
Hi, thanks for the interest.
I’ll try kernel 4.4. Is there any drawback in running an older kernel?
The date on Samsung website for bios predates the date of the one installed on the laptop.
The driver profile:
e[1me[31m> e[mPCI Device: /devices/pci0000:00/0000:00:1c.3/0000:03:00.0 (0200:10ec:8168)
  Network controller Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
  > INSTALLED:
   ATTACHED:	PCI
   VERSION:	2016.04.20
   INFO:	RealTek RTL-8168 Gigabit Ethernet driver
   PRIORITY:	0
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0200
   VENDORIDS:	1186 10ec
  > AVAILABLE:
   ATTACHED:	PCI
   VERSION:	2016.04.20
   PRIORITY:	0
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0200
e[1me[31m> e[mPCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0302:10de:1140)
  Display controller nVidia Corporation GF117M [GeForce 610M/710M/810M/820M / GT 620M/625M/630M/720M]
  > INSTALLED:
   ATTACHED:	PCI
   VERSION:	2020.10.04
   INFO:	Hybrid prime solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY:	17
   FREEDRIVER:	false
   DEPENDS:	video-modesetting
   CONFLICTS:	video*nvidia-*
   CLASSIDS:	0300 0302 0300
   VENDORIDS:	10de 8086
   ATTACHED:	PCI
   VERSION:	2018.05.04
   INFO:	Standard open source drivers.
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300 0380 0302
   VENDORIDS:	1002 8086 10de
  > AVAILABLE:
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	18
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	17
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	16
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	15
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   INFO:	Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
   PRIORITY:	14
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	13
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	12
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	11
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   INFO:	Closed source NVIDIA drivers for linux.
   PRIORITY:	10
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	9
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	8
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	7
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	6
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	5
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	4
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	3
   FREEDRIVER:	false
   DEPENDS:	-
   CLASSIDS:	0300 0302
   VENDORIDS:	10de
   ATTACHED:	PCI
   VERSION:	2018.05.04
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
e[1me[31m> e[mPCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:0166)
  Display controller Intel Corporation 3rd Gen Core processor Graphics Controller
  > INSTALLED:
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	17
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2018.05.04
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   ATTACHED:	PCI
   VERSION:	2020.01.13
   INFO:	X.org modesetting video driver.
   PRIORITY:	1
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300
   VENDORIDS:	*
  > AVAILABLE:
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	18
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	17
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	16
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	15
   FREEDRIVER:	false
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	14
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	13
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	12
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2020.10.04
   PRIORITY:	11
   FREEDRIVER:	false
   DEPENDS:	-
   ATTACHED:	PCI
   VERSION:	2018.05.04
   PRIORITY:	2
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   ATTACHED:	PCI
   VERSION:	2020.01.13
   PRIORITY:	1
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300
   VENDORIDS:	*
   ATTACHED:	PCI
   VERSION:	2017.03.12
   INFO:	X.org vesa video driver.
   PRIORITY:	0
   FREEDRIVER:	true
   DEPENDS:	-
   CONFLICTS:	-
   CLASSIDS:	0300
   VENDORIDS:	*
Is your laptop fixed ? if not you should look if it is affected by the c-state bug .The case is same for me but harware is different . I solved it by using " intel_idle.max_cstate=1" to the boot parameters . I guess you look the c-state bug more on the internet if it applies to you .
i recommend timeshift before making any changes . inform me if it gets solved or not . Thanks
edit: i think this problem of c-state will not apply to you but u r free to search
I noticed you are using nvidia if i am not wrong . you could also try by installing propriety drivers .
Problem is not fixed yet, kernel 4.4 raises other issues so it is not going to be suitable. Will have a look at the c-state bug when I get a chance. At the moment I am turning wifi manually off and back on after resume as there seem to be errors in the journalctl logs about it and the freeze usually happens a few seconds after resuming and so does wifi restarting. Just wild guess though. Too early to say if it makes a difference or not.
I believe I am using Nvidia prime drivers but I must say I can’t find out how to confirm that. I can see the installed and available drivers but not a confirmation of which one is running.
You are supposedly running a PRIME profile … thats intel by default, and prime-run for using the nvidia.
That’s what I think too but being asked I thought I would double check before answering and realised I don’t know how.
Haven’t got the actual cause yet but I have been disconnecting from the wifi (using the KDE network widget on the panel) before putting the computer to sleep and I haven’t had any freeze since doing so. Not sure what the difference is between doing that manually or having the computer doing automatically before going to sleep (or maybe it doesn’t and hence the errors in jounalctl?).
