How do you change the keyboard language on Manjaro Cinnamon?
hello ! since i couldnt find any answers on google or the fourms i have to create a topic because i have no idea how to change the language
UPDATE figured it out to anyone who might not know its Settings=>Keyboard=>Layouts=>[Options] (on the lower right corner of the window)=And look for “Switching to another layout” Click and then you will have option for All kinds of key combinations i chose Left alt+ left shift Thanks to all that tried to help
menu>>settings>>hardware>>keyboard>>layouts
Add or remove languages here. You must have the locale installed and setup.
no that is not what i meant. i meant is there a key shortcut like on windows ? like Alt+Shift
Not AFAIK, but you should be able to set one customly. I just don’t know how to make a shortcut in Cinnamon. Have a look here:
https://wiki.archlinux.org/title/Cinnamon
And here:
https://superuser.com/questions/1291939/shortcut-to-change-keyboard-layout-in-linux-mint-cinnamon
Also:
https://stackoverflow.com/questions/22384513/how-does-one-add-keyboard-languages-and-switch-between-them-in-linux-mint-16
And there’s:
And:
Also:
https://www.reddit.com/r/linuxmint/comments/u3tumo/how_to_change_the_cinnamon_keyboard_layout_with_a/
And:
https://www.reddit.com/r/linuxmint/comments/m2yv2p/defining_shortcut_to_switch_to_a_specific/
Or, if you prefer DDG:
https://is.gd/B68aGa
