Yesterday i have installed Manjaro alongside my Win11 installation on my notebook: Dell Latitude 5530
I did this in the following manner:
Disabled Bitlocker
Shrink Partition
Boot LiveUSB
Partition Free-Space for:
4.1) ~500MB FAT32 → Mount /boot/efi
4.2) ~60GB linuxswap encrypted → Mount /swap
4.3) ~500GB ext4 encrypted → Mount /
Install
Reboot into Windows
Reactivate Bitlocker
Everything worked fine. I was able to decrypt the disk on startup and then choose my OS in the Manjaro Bootloader.
Today i wanted to continue setting up my Manjaro.
During the installation of Microsoft Teams, the desktop froze. Trying to switch into another tty did not work. After a cold shutdown i was greeted with the “Boot over IPv4” screen of the notebook.
In the BIOS, i am no longer able to see the disk (M.2 Slots are empty)
I do see the Manjaro bootloader, but starting it prompts me with the error message that no harddrive is installed.
Booting in from a LiveUSB, lsblk does not list any harddrives other than the USB-Stick itself.
Has anybody else experienced any issues like this or does anybody have any ideas whether or not this is recoverable?
fastboot should be disabled, if you have the fastboot option in bios… so set it to thorough, save changes, exit bios, enter bios again, and check if the drive is detected, if not do the same with the auto option…if its still not detected, reset bios to defaults, save changes, exit bios, enter bios, and check …
your disk is not being detected in bios, but you can enter into manjaro grub?
boot into live usb and post output from: lspci sudo dmesg | grep sda sudo dmesg | grep nvm
thank you for the welcome!
I have encountered the issue previously, however that was when i wiped the whole disk and tried a “clean” install of Manjaro. Same procedure, but there it failed during the installation of manjaro itself.
I tried reseating the SSD but with no luck as well (on the “old” one). I thought this might have something to do with Bitlocker somehow. But being able to dual-boot and then failing after the installation of literally 3 programs?
I was not expecting it to fail like again to be honest.
@brahma
Manjaro is being listed in the “Boot Configuration” yeah. I cannot enter into it as it prompts me with the “No Harddrive installed” BIOS screen.
Edit After resetting BIOS defaults, it no longer shows under “Boot Configuration”
that makes sense, i was thinking that the manjaro grub was shown, but you meant that in bios under boot options it was still shown…
this doesnt look good, the disk is probably dead…
The issues i had were with a different disk in a different laptop of the same model.
I just find it hard to believe in coincidence with 2 laptops failing within the timespan of a week.
I thought so too, but then again, booting and installing the other apps worked as expected.
Anyways, i ordered another SSD and will try my luck with that one…
Sorry there wasn’t any better news. The only other thing I can think of, is that it’s the nVME controller…you can try running a SMART test o the disk and see what happens, but I doubt it will point you in any specific direction, to be honest. To run the test, execute the following:
sudo smartctl -t short /dev/nvme0
And/or:
sudo smartctl --all /dev/nvme0
Note: That last one can take very long to complete.
Edit:
Just thought of this, but what if the crash was because of the controller/drive? There could be something in the logs, even. Let’s try and see. Please provide the output of:
journalctl --boot=-1 --priotrity=3
…run from a chroot environment. I’m assuming you know how to enter a chroot environment. If not:
How to enter a chroot environment:
Ensure you’ve got an ISO.
Write/copy/dd the ISO to a USB thumb drive.
When done, boot with the above mentioned USB thumb drive into the live environment.
Once booted, open a terminal and enter the following command to enter the chroot environment:
manjaro-chroot -a
If you have more than one Linux installation, select the correct one to use from the list provided.
When done, you should now be in the chroot environment.
But, be careful, as you’re now in an actualroot environment oon your computer, so any changes you make will persist after a restart.
