Hi, I bought a foot button for transcription purposes. When I press it, it writes a “B”. How can I set up the button, that he presses like F4 or F5?
Thx!
Thx!
a foot button?
You can only hope that someone knows what that specifically is.
Google needs one second bro
… well, lets see who wants to guess what device your issue is with
“A foot button” is a pretty generic statement. There are many makes and models, so you would need to be much more specific about what button it is, for any hope of help.
I will say this though. The foot buttons I have worked with, is hardware defined output. Usually between Enter, Spacebar, ESC and a few other keys.
Thank you, I used a generel 10 euro foot button from ebay.
Your post is very useful. So I can not change the outpot on the computer, I have to look for a foot button with the output I want to use before I buy it
There seem to be some options to get these things to work, check out this thread on how to approach it: [SOLVED] Configuring a Philips Speech Footcontrol USB device / Kernel & Hardware / Arch Linux Forums
If the device can send something that can be mapped you can change it, it all depends on what the device can do.
Maybe key binding works?
https://wiki.archlinux.org/title/Libinput
https://wiki.archlinux.org/title/Xmodmap
I share this experience, altho I had to support a user with a device on windows more then a decade ago, things might be better now
Well, they can now be connected via Bluetooth and such, but other than that, it’s about the same.
