How to set touchscreen moves, gestures
Hi,
I want to set touchscreen gestures, for example moving finger over page instead of scrolling ( similar like it was on phone) .
Also long press on desktop for menu (like on mouse right click)
It worked on Xfce but now on KDE no.
[marko@marko-hpenvyx360convertible13ar0xxx ~]$ inxi --full --verbosity=7 --filter --no-host
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
        LANGUAGE = "",
        LC_ALL = (unset),
        LANG = "hr_HR.UTF-8"
    are supported and installed on your system.
perl: warning: Falling back to the standard locale ("C").
System:    Kernel: 5.8.6-1-MANJARO x86_64 bits: 64 compiler: N/A Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11
           dm: SDDM Distro: Manjaro Linux
Machine:   Type: Convertible System: HP product: HP ENVY x360 Convertible 13-ar0xxx v: N/A serial: <filter> Chassis: type: 31
           serial: <filter>
           Mobo: HP model: 85DE v: 41.36 serial: <filter> UEFI: AMI v: F.19 date: 12/26/2019
Battery:   ID-1: BAT0 charge: 30.7 Wh condition: 52.7/52.7 Wh (100%) volts: 15.4/15.4 model: 333-2B-49-A KC04053XL
           type: Li-ion serial: <filter> status: Discharging
           Device-1: hid-0018:04F3:23B9.0001-battery model: ELAN2514:00 04F3:23B9 serial: N/A charge: N/A status: N/A
Memory:    RAM: total: 5.74 GiB used: 1.61 GiB (28.1%)
CPU:       Topology: Quad Core model: AMD Ryzen 5 3500U with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen+ rev: 1
           L2 cache: 2048 KiB bogomips: 33548
           Speed: 1610 MHz min/max: 1400/2100 MHz boost: enabled Core speeds (MHz): 1: 1610 2: 1841 3: 1642 4: 1551 5: 2303
           6: 2292 7: 1976 8: 1464
           Flags: 3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1 bmi2 bpext clflush clflushopt clzero cmov
           cmp_legacy constant_tsc cpb cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c flushbyasid fma fpu
           fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr
           mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb
           perfctr_core perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rdrand rdseed rdtscp rep_good sep sev
           sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext
           tsc tsc_scale v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Picasso vendor: Hewlett-Packard driver: amdgpu v: kernel bus ID: 04:00.0
           chip ID: 1002:15d8
           Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo bus ID: 3-1:2 chip ID: 04ca:709d
           Display: x11 server: X.Org 1.20.9 compositor: kwin_x11 driver: amdgpu FAILED: ati unloaded: modesetting
           alternate: fbdev,vesa s-res: 1920x1080 s-dpi: 96
           OpenGL: renderer: AMD RAVEN (DRM 3.38.0 5.8.6-1-MANJARO LLVM 10.0.1) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
           driver: snd_hda_intel v: kernel bus ID: 04:00.1 chip ID: 1002:15de
           Device-2: Advanced Micro Devices [AMD] Raven/Raven2/FireFlight/Renoir Audio Processor vendor: Hewlett-Packard
           driver: snd_rn_pci_acp3x v: kernel bus ID: 04:00.5 chip ID: 1022:15e2
           Device-3: Advanced Micro Devices [AMD] Family 17h HD Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
           bus ID: 04:00.6 chip ID: 1022:15e3
           Sound Server: ALSA v: k5.8.6-1-MANJARO
Network:   Device-1: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter vendor: Hewlett-Packard driver: rtw_8822be v: N/A
           port: f000 bus ID: 02:00.0 chip ID: 10ec:b822
           IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
           IP v6: <filter> scope: link
Drives:    Local Storage: total: 476.94 GiB used: 14.15 GiB (3.0%)
           ID-1: /dev/nvme0n1 vendor: Intel model: SSDPEKNW512G8H size: 476.94 GiB speed: 31.6 Gb/s lanes: 4 serial: <filter>
           rev: HPS0 scheme: GPT
RAID:      Message: No RAID data was found.
Partition: ID-1: / size: 179.60 GiB used: 13.55 GiB (7.5%) fs: ext4 dev: /dev/nvme0n1p2 label: N/A
           uuid: eed94378-b9a0-4f7f-b088-1981c19d78d5
           ID-2: /boot/efi size: 499.0 MiB used: 280 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 label: N/A uuid: 2626-639F
           ID-3: /home size: 287.37 GiB used: 615.2 MiB (0.2%) fs: ext4 dev: /dev/nvme0n1p3 label: N/A
           uuid: cb514ec5-c327-4b9d-9eea-118bcd96e6fc
Swap:      Alert: No Swap data was found.
Unmounted: Message: No unmounted partitions found.
USB:       Hub: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 1-3:2 info: Xenta 2.4GHz Receiver (Keyboard and Mouse) type: Keyboard,Mouse,HID
           driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 1.5 Mb/s chip ID: 1d57:32da
           Device-2: 1-4:3 info: Synaptics type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
           chip ID: 06cb:00d2 serial: <filter>
           Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
           Hub: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
           Device-1: 3-1:2 info: Lite-On HP Wide Vision HD Camera type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s chip ID: 04ca:709d
           Device-2: 3-2:3 info: Realtek Realtek Bluetooth 4.2 Adapter type: Bluetooth driver: btusb interfaces: 2 rev: 1.1
           speed: 12 Mb/s chip ID: 0bda:b00b serial: <filter>
           Hub: 4-0:1 info: Full speed (or root) Hub ports: 1 rev: 3.1 speed: 10 Gb/s chip ID: 1d6b:0003
Sensors:   System Temperatures: cpu: 33.9 C mobo: 32.0 C gpu: amdgpu temp: 33 C
Info:      Processes: 242 Uptime: 1h 06m Init: systemd v: 246 Compilers: gcc: N/A Packages: pacman: 1065 Shell: Bash v: 5.0.18
           running in: konsole inxi: 3.1.05
2 question, can I somehow disable touchscreen ? Sometimes I dont need it, to save battery :slight_smile:
Install xinput-toggle, firstly. Then you can add following command in Keyboard Shortcut Setting.
xinput-toggle -r <Your_Touchscreen_Name>
Is this a answer for the first or for the second question?
