I read some “article” about it but i cant understan.
[i3hunor@HunorT480 xorg.conf.d]$ xinput list-props 12
Device 'Synaptics TM3276-022':
Device Enabled (187): 1
Coordinate Transformation Matrix (189): 1.000000, 0.000000, 0.000000, 0.000000, 1.000000, 0.000000, 0.000000, 0.000000, 1.000000
Device Accel Profile (323): 1
Device Accel Constant Deceleration (324): 2.500000
Device Accel Adaptive Deceleration (325): 1.000000
Device Accel Velocity Scaling (326): 12.500000
Synaptics Edges (327): 77, 1863, 70, 1227
Synaptics Finger (328): 25, 30, 0
Synaptics Tap Time (329): 180
Synaptics Tap Move (330): 102
Synaptics Tap Durations (331): 180, 180, 100
Synaptics ClickPad (332): 1
Synaptics Middle Button Timeout (333): 0
Synaptics Two-Finger Pressure (334): 282
Synaptics Two-Finger Width (335): 7
Synaptics Scrolling Distance (336): 46, 46
Synaptics Edge Scrolling (337): 0, 0, 0
Synaptics Two-Finger Scrolling (338): 1, 1
Synaptics Move Speed (339): 1.000000, 1.750000, 0.085727, 0.000000
Synaptics Off (340): 1
Synaptics Locked Drags (341): 0
Synaptics Locked Drags Timeout (342): 5000
Synaptics Tap Action (343): 0, 0, 0, 0, 0, 0, 0
Synaptics Click Action (344): 1, 3, 2
Synaptics Circular Scrolling (345): 0
Synaptics Circular Scrolling Distance (346): 0.100000
Synaptics Circular Scrolling Trigger (347): 0
Synaptics Circular Pad (348): 0
Synaptics Palm Detection (349): 0
Synaptics Palm Dimensions (350): 10, 200
Synaptics Coasting Speed (351): 20.000000, 50.000000
Synaptics Pressure Motion (352): 30, 160
Synaptics Pressure Motion Factor (353): 1.000000, 1.000000
Synaptics Grab Event Device (354): 0
Synaptics Gestures (355): 1
Synaptics Capabilities (356): 1, 0, 0, 1, 1, 1, 0
Synaptics Pad Resolution (357): 20, 20
Synaptics Area (358): 0, 0, 0, 0
Synaptics Soft Button Areas (359): 970, 0, 1063, 0, 0, 0, 0, 0
Synaptics Noise Cancellation (360): 11, 11
Device Product ID (315): 1739, 0
Device Node (314): "/dev/input/event8"
inix Fazy
[i3hunor@HunorT480 xorg.conf.d]$ inxi -Fazy
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=cc7be21e-d9d4-4881-841a-b047d2a1253a rw quiet
udev.log_priority=3
Desktop: i3 4.20.1 info: xfce4-panel vt: 7 dm: LightDM 1.30.0
Type: Laptop System: LENOVO product: 20L6S1LV2F v: ThinkPad T480
Mobo: LENOVO model: 20L6S1LV2F v: SDK0J40697 WIN
serial: <superuser required> UEFI: LENOVO v: N24ET67W (1.42 )
date: 11/17/2021
ID-1: BAT0 charge: 14.8 Wh (79.6%) condition: 18.6/23.9 Wh (77.6%)
volts: 12.3 min: 11.4 model: LGC 01AV489 type: Li-poly serial: <filter>
status: Not charging cycles: 83
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEC
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 1700 high: 1701 min/max: 400/3600 scaling:
driver: intel_pstate governor: performance cores: 1: 1700 2: 1700 3: 1700
4: 1701 5: 1700 6: 1700 7: 1700 8: 1700 bogomips: 30409
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: Chicony Integrated Camera (1280x720@30) type: USB
driver: uvcvideo bus-ID: 1-8:3 chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Display: x11 server: X.Org 1.21.1.3 driver: loaded: modesetting
alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3")
s-diag: 583mm (23")
Monitor-1: eDP-1 res: 1920x1080 dpi: 158 size: 309x174mm (12.2x6.9")
diag: 355mm (14")
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo ThinkPad T480
driver: snd_hda_intel v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel
bus-ID: 03:00.0 chip-ID: 8086:24fd class-ID: 0280
Local Storage: total: 238.47 GiB used: 52.21 GiB (21.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKKF256G8L
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: L15P temp: 30.9 C scheme: GPT
ID-1: / raw-size: 118.93 GiB size: 116.5 GiB (97.96%)
used: 52.18 GiB (44.8%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
used: 25.3 MiB (26.3%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 8 GiB used: 41.8 MiB (0.5%) priority: -2
file: /swapfile
System Temperatures: cpu: 44.0 C pch: 39.5 C mobo: N/A
Processes: 233 Uptime: 3d 47m wakeups: 33 Memory: 7.51 GiB
used: 3.59 GiB (47.7%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1219 lib: 328 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.12
I dont quite understand that now im using synaptics or libinput or what driver?
How could i slow down the two finger scroll speed?
