How to set resolution and seperate PPI on laptop and external monitor?
Hi guys
I recently bought a Huawei Mateview GT 34-inch, which is ultra wide view monitor with max 3440*1440 resolution. I normally use Manjaro on my Macbook Pro 2015 13-inch laptop, in order to use the Retina screen of Macbook Pro, I have to set resolution to 2560*1600 with “Global scale” at 150%, it’s fine, but until I connect the external monitor with HDMI cable. The problem is:
  1. I can’t find 3440*1440 resolution on that monitor, the most wide resolution is 2580*1080
  2. the “Global scale” 150% fits my laptop monitor perfectly, but will make words too huge on the external monitor.
So the question is:
  1. Is there a way to set the correct resolution 3440*1440 for the monitor? I’m not sure if I should use Thunderbolt Port instead of HDMI to connect external monitor.
  2. Is there a way to set “Global scale” separately for different display?
Hi @kamusis, and welcome!
While I have dual monitors, they are identical, so the resolutions are the same and they’re working like a charm. So, I personally wouldn’t be able to help you.
But, I can point you in this direction: xrandr - ArchWiki. Maybe it helps!
