Hello everyone. I recently installed Manjaro KDE for the first time. I used the XFCE version for years. I have a laptop with a discrete NVIDIA graphics card and the integrated Intel one. The graphics driver I use is the video-hydrid-intel-nvidia-prime.
I want to take advantage of prime-run for certain applications like I did on XFCE. How do I do that on KDE?
When I right click on an application and try to change its command from “app_name %U” to “prime-run app_name %U” i get the following error:
"Could not save properties due to insufficient write access to:
‘/home/username/.local/share/applications/app_name.desktop’.
Thanks for your answer. I tried to change ownership and permissions with 2 ways and none of them worked.
First I right clicked on my home folder and tried to do it from the permissions tab and then I run from the terminal “sudo chown -R pavlidis /home/pavlidis”.
Copy the file of smartcode-stremino.desktop inside your ~/.local/share/applications/ and manually edit the Exec= line, then save it. You can do the same with all applications.
