I found upnppc command.
upnpc --help
upnpc : miniupnpc library test client, version 2.1.
(c) 2005-2019 Thomas Bernard.
Go to http://miniupnp.free.fr/ or https://miniupnp.tuxfamily.org/
for more information.
Usage : upnpc [options] -a ip port external_port protocol [duration] [remote host]
Add port redirection
upnpc [options] -d external_port protocol [remote host]
Delete port redirection
upnpc [options] -s
Get Connection status
upnpc [options] -l
List redirections
upnpc [options] -L
List redirections (using GetListOfPortMappings (for IGD:2 only)
upnpc [options] -n ip port external_port protocol [duration] [remote host]
Add (any) port redirection allowing IGD to use alternative external_port (for IGD:2 only)
upnpc [options] -N external_port_start external_port_end protocol [manage]
Delete range of port redirections (for IGD:2 only)
upnpc [options] -r port1 [external_port1] protocol1 [port2 [external_port2] protocol2] [...]
Add all redirections to the current host
upnpc [options] -A remote_ip remote_port internal_ip internal_port protocol lease_time
Add Pinhole (for IGD:2 only)
upnpc [options] -U uniqueID new_lease_time
Update Pinhole (for IGD:2 only)
upnpc [options] -C uniqueID
Check if Pinhole is Working (for IGD:2 only)
upnpc [options] -K uniqueID
Get Number of packets going through the rule (for IGD:2 only)
upnpc [options] -D uniqueID
Delete Pinhole (for IGD:2 only)
upnpc [options] -S
Get Firewall status (for IGD:2 only)
upnpc [options] -G remote_ip remote_port internal_ip internal_port protocol
Get Outbound Pinhole Timeout (for IGD:2 only)
upnpc [options] -P
Get Presentation url
protocol is UDP or TCP
Options:
-e description : set description for port mapping.
-6 : use ip v6 instead of ip v4.
-u url : bypass discovery process by providing the XML root description url.
-m address/interface : provide ip address (ip v4) or interface name (ip v4 or v6) to use for sending SSDP multicast packets.
-z localport : SSDP packets local (source) port (1024-65535).
-p path : use this path for MiniSSDPd socket.
-t ttl : set multicast TTL. Default value is 2.
This my output
upnpc -s
List of UPNP devices found on the network :
desc: http://10.0.0.1:48916/rootDesc.xml
st: urn:schemas-upnp-org:device:InternetGatewayDevice:1
Found a (not connected?) IGD : http://10.0.0.1:48916/ctl/IPConn
Trying to continue anyway
Local LAN ip address : 10.0.0.26
Connection Type : IP_Routed
Status : Connected, uptime=1018256s, LastConnectionError : ERROR_NONE
Time started : Fri Oct 9 10:55:31 2020
MaxBitRateDown : 4200000 bps (4.2 Mbps) MaxBitRateUp 4200000 bps (4.2 Mbps)
GetExternalIPAddress failed. (errorcode=501)
Bytes: Sent: 3603332544 Recv: 530729392
Packets: Sent: 78366515 Recv: 175263519
upnpc -S
FirewallEnabled: 0 & Inbound Pinhole Allowed: 0
GetFirewallStatus:
Firewall Enabled: No
Inbound Pinhole Allowed: No
Bytes: Sent: 3604454301 Recv: 597229218
Packets: Sent: 78381251 Recv: 175311150
upnpc -l
Status : Connected, uptime=1018363s, LastConnectionError : ERROR_NONE
i protocol exPort->inAddr:inPort description remoteHost leaseTime
GetGenericPortMappingEntry() returned 713 (SpecifiedArrayIndexInvalid)
When I try ton open ports I get this:
upnpc -a 10.0.0.26 4955 4955 UDP
AddPortMapping(4955, 4955, 10.0.0.26) failed with code 501 (Action Failed)
