How to set linux-kernel version when building ISO? For example, I only need linux-515 ISO, do not need linux-54 and linux-510 ISO. If I can build linux-517 ISO I will be glad to.
Thanks!
Thanks!
It’s in “manjaro-tools.conf”
$ buildiso -h ✔
Usage: buildiso [options]
-a <arch> Arch [default: x86_64]
-b <branch> Branch [default: stable]
-c Disable clean work dir
-d <comp> Compression used for build ISO: gzip, lzma, lz4, lzo, xz, zstd
[default: zstd]
-f Build full ISO (extra=true)
-g <key> The gpg key for sfs signing
[default: ]
-i Initialize iso-profiles repo [default: v18.0]
-k <name> Kernel to use
[default: linux54]
-l Create permalink
-m Set SquashFS image mode to persistence
-p <profile> Buildset or profile [default: default]
-o Enable office installer module
-q Query settings and pretend build
-r <dir> Chroots directory
[default: /var/lib/manjaro-tools/buildiso]
-t <dir> Target directory
[default: /var/cache/manjaro-tools/iso]
-v Verbose output to log file, show profile detail (-q)
-x Build images only
-z Generate iso only
Requires pre built images (-x)
-h This help
buildiso -k linux515
It seems that linux-517 also works.
PS: the default mirror is https://manjaro.moson.eu/testing/$repo/$arch and it can also be edited in /etc/manjaro-tools/manjaro-tools.conf
, like Index of /manjaro/ | 清华大学开源软件镜像站 | Tsinghua Open Source Mirror
Don’t add the dash - it will not work - the kernel of the -k argument is a reference to the kernel package - which does not contain a dash - and if used will cause the build to fail.
