Hello all!
I have a notebook that has both a gtx1060 GPU and some basic intel one. To be honest I’m not even sure what is the point of having two GPUs in a notebook but it seem to be quite trendy, so that would be my first question, just why? If you have a gtx1060 why on earth would you need some basic GPU next to it?
My other question would be I tried playing CS:GO but even on the lowest settings it runs incredibly poor, under 30 fps, even though I believe the system should not have any problems running this game even with high settings on stabil 60FPS. So I guess that the intel gpu is being used with CS:GO. How could I check this and set the nvidia card as a default? I mean globally, I just really don’t see a point in using the intel card for anything.
Also there seem to be tons of drivers available both open-source and proprietary ones, and I have no idea which should be installed.
I saw some wiki posts about something like dri_prime that is about this, but i didn’t really understand what should I do. Any help would be much appreciated!
