How to restore win10 in grub menu
First English is not my native language. I might make some mistakes in grammar.I try to express what I mean.
I got win10 in SSD(Samsung 850), and split about 110G block from HDD to make majaro installing.
But when I finishing my installing and reboot my machine. I miss my win10 menu in grub(Manjaro and Manjaro xxxxxx).
I’ve been looking for a solution for a long time in manjaro forum and wiki. Still failed.
Here are some command show like:
cat /etc/fstab
/etc/fstab: static file system information.
Use ‘blkid’ to print the universally unique identifier for a device; this may
be used with UUID= as a more robust way to name devices that works even if
disks are added and removed. See fstab(5).
UUID=8E83-358B /boot/efi vfat defaults,noatime 0 2
UUID=dabc7289-4f20-455a-b1e8-ad259a0e7527 / ext4 defaults,noatime,discard 0 1
UUID=b6f6202b-fa20-41a0-820e-2bdd9fed5668 swap swap defaults,noatime,discard 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
blkid
/dev/sda1: UUID=“8E83-358B” TYPE=“vfat” PARTUUID=“09485484-4df1-47ba-9dda-ad666081cbac”
/dev/sda2: UUID=“dabc7289-4f20-455a-b1e8-ad259a0e7527” TYPE=“ext4” PARTUUID=“2991af47-a16f-4545-b12d-f952c42ca8be”
/dev/sda3: UUID=“b6f6202b-fa20-41a0-820e-2bdd9fed5668” TYPE=“swap” PARTUUID=“303a5b41-5e5a-43d5-af80-d3388e6bd586”
/dev/sdb1: UUID=“C14D581BDA18EBFA” TYPE=“ntfs” PTTYPE=“atari” PARTUUID=“4617ef7f-01”
lsblk -f
NAME FSTYPE LABEL UUID MOUNTPOINT
sda
├─sda1 vfat 8E83-358B /boot/efi
├─sda2 ext4 dabc7289-4f20-455a-b1e8-ad259a0e7527 /
└─sda3 swap b6f6202b-fa20-41a0-820e-2bdd9fed5668 [SWAP]
sdb udf GSP1RMCULXFRER_CN_DVD 436925804d532055
└─sdb1 ntfs GSP1RMCULXFRER_CN_DVD C14D581BDA18EBFA
parted -l
Model: ATA Samsung SSD 850 (scsi)
Disk /dev/sda: 120GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 2098kB 317MB 315MB fat32 boot, esp
2 317MB 111GB 110GB ext4
3 111GB 120GB 9449MB linux-swap(v1)
Model: ATA WDC WD10EZEX-21M (scsi)
Disk /dev/sdb: 1000GB
Sector size (logical/physical): 512B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 871GB 871GB primary ntfs boot
efibootmgr
BootCurrent: 0004
Timeout: 1 seconds
BootOrder: 0004,0002
Boot0002* Hard Drive
Boot0004* UEFI: Samsung SSD 850 EVO 120GB
findmnt -s
TARGET SOURCE FSTYPE OPTIONS
/boot/efi UUID=8E83-358B vfat defaults,noatime
/ UUID=dabc7289-4f20-455a-b1e8-ad259a0e7527 ext4 defaults,noatime,discard
swap UUID=b6f6202b-fa20-41a0-820e-2bdd9fed5668 swap defaults,noatime,discard
/tmp tmpfs tmpfs defaults,noatime,mode=1777
Try these:
https://forum.manjaro.org/search?q=restore%20grub
Take a look at this.
You may have a difficult UEFI set up.
Do step 6 with the [(2) Additional UEFI commands]
And if still having problems, look at links in [Some difficult UEFI setups] for the computer you have.
If need further help, don’t forget to provide computer make and model
& the output required (which is not provided above).
A cosmetic thing but important:
Repair the post output text to be easily readable and bug-proof, reading this guide:
Looks to me as if you used your whole Samsung Disk for Manjaro. 110G ext4 10GB swap and the /efi/boot partition. The only ntfs is on the WD TB drive.
And so… why would this be a problem?
It is a problem if OP use windows bcd to boot Manjaro, but he is not.
he said he has win10 installed on the samsung SSD and split a block from it for Manjaro. The Disk has only 120GB and the ex4 plus swap is already that size. Leaves us with the WD spinner for Win10 but I think it’s just data. Why should someone install an OS on an spinner, when there is a SSD?
and some unallocated space maybe, or a hidden partition.
Until OP @mclubing clarifies we can wait…
I too have OS’s in both spinner and ssd :grinning:
Not noticing any (significant) difference.
Oh, I think I missed his data info.
One disk on gpt and the other on msdos (presumably one on uefi and the other on bios-legacy).
No wonder his grub cannot pick up his windows.
Anyway he hasn’t come back since his first post.
What I ment was, the only OS on that system was Win10. Why use the SSD as data and not as boot. Would not make much sense.
@AgentS
He said he has Win10 on Samsung SSD and cut a piece from the HDD, which he did. But then he installed Manjaro on the SSD. Study the parted -l output. Unless you can install Win10 on ext4 or swap, he has just installed Manjaro over the Win10 partition. But let’s wait til he comes back
I agree with your observations. Nice overview!
Let’s wait for final touch!, :grin:
Edit: I am also getting
mirror.philpot.de : SSL certificate problem:
all day.
@gohlip, @AgentS Sorry to trouble guys, I made a terrible mistake. I had erased win10 to install manjaro. I finally found out that.I thought I’d put manjaro in HDD, but not. so sorry, Thx guys.
