I accidentally deleted /bin/zsh, and then konsol’s configuration scheme became /bin/bash/. I tried to reinstall Zsh, but it could not become manjaro’s own configuration scheme at the beginning.
And now it’s like this.
So is there any way to restore konsol to its default appearance? I really like his original configuration scheme.
If the process was deleting zsh using the package manager then you have also removed the package manjaro-zsh-config which then needs to be restored as well.
If you have changed your local .zshrc you can copy the original from /etc/skel (if you use a file manager - remember to show hidden files)
I didn’t run zsh with sudo,and it still appera every time.
Then I ran the code according to your statement, but it still had no effect, and it was the same as the original.
Need I reboot or something?
