Since the last update to the Steam-client I’m running into issues with certain games because of a missing ‘steamservice.so’ file. Because this got introduced in version 1.0.0.78-5, I’d like to try to downgrade the ‘steam’ package to an older version I still have locally cached on disk (version 1.0.0.78-4 to be specific).
But when I try to downgrade steam, it refers to dependency ‘steam-devices’ being unresolved. What I can find about that package is that it doesn’t exist (anymore). Apparently it’s been replaced by the ‘game-devices-udev’ package which I found out via: How to install or uninstall "game-devices-udev" on Manjaro ?, where it says:
Repository : community
Provides : steam-devices
Depends On : udev
Optional Deps : None
Conflicts With : steam-devices
Replaces : steam-devices
I do have that ‘game-devices-udev’ package installed:
% sudo pacman -Q game-devices-udev
game-devices-udev 0.22-2
When I try to downgrade steam, I get this output:
% sudo pacman -U /var/cache/pacman/pkg/steam-1.0.0.78-4-x86_64.pkg.tar.zst
loading packages...
resolving dependencies...
warning: cannot resolve "steam-devices", a dependency of "steam"
:: The following package cannot be upgraded due to unresolvable dependencies:
steam
:: Do you want to skip the above package for this upgrade? [y/N] n
:: unable to satisfy dependency 'steam-devices' required by steam
I’m not sure what the error is here.
- Should ‘steam-devices’ still be available? or,
- Should the ‘steam’ package not depend on ‘steam-devices’ anymore?
Is it possible to fix this locally by some hack in the ‘steam’ package registry so it doesn’t depend on ‘steam-devices’ anymore? Or can I fake that package by building some dummy thing locally and package it as ‘steam-devices’?
I understand downgrading is frowned upon and for good reason. But since the steam-client is a typical ‘leaf’-package (I don’t expect other packages depending on ‘steam’), I’m willing to take the risk for this specific experiment
